E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
G'day guys!
I've recently put in a set of Genuine Philips 35w HIDs, however I have an issue with the fuse.. When I initially installed them, the driver side light didn't go on; sure enough the fuse was blown so I replaced it then they were working fine. Not to long ago, same thing happened. No drive side light and sure enough it was the fuse. However, it seems to be permanent now. Every time I turn the car off and stick in a new fuse, then turn it on and turn them on *boom* another fuse blows. Originally I had 7.5A in the two slots, and I upped to to a 10A (didn't have any 7.5A at the time). I've double checked the connections and they all appear fine. I've mounted the slimline ballast horizontally and that doesn't move. Any ideas on how to fix it? |
Do you have proper ballasts installed? They seem to be drawing too much current.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
What do you mean by proper? They aren't a knock-off Chinese version, if that's what you mean =b They are legit Philips. It makes no sense to me that one side is fine, whilst the other isn't..
Try swapping the bad one to the good side. See if it blows that fuse. Then you know it's a bad ballast.
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
Not a bad idea..pain in the a** seeing as I've put like 4 cable ties per side, very tightly to hold them in xD
So your ballasts (in addition to the bulbs) are also Philips?
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 12-07-2012 at 10:34 PM. |
Correct! I'm sorry..I should have made that much clearer..
Both the ballasts and bulbs are Philips, H1 Bulbs which are fitting into a Hella Projector & Angel Eye headlight. |
Did you mount your ballasts to the car body or bolt them to something metal that's attached to the car body? If not that may be part of the problem and may have killed one of your ballasts. Most of the HID ballasts require mounting to the car body because it provides both a ground connection and heat transfer.
Is this the kit you have? Looks like a pretty good set up......
SoloTech LLCI have attached a picture of their whois street address. I can find no street address on their website. One of their suppliers is reportedly Fuan Jianlong Auto Parts Co., Ltd. Philips Lighting (the huge Dutch company) apparently does not make HID kits, so Solotech must get them from somewhere else. Here's a possiblity to give a flavor of their possible supplier(s): http://www.chinesehid.com/eproductus.asp?id=135 There is also a philips-xenon.com / Xenon Philips who claim they are the only source for German made Philips HID kits. That domain is registered to: Ryan SchloteIt looks to be in a housing development. If I were to buy from these folks, I would not be surprised to get what I paid for. Last edited by johnf; 12-08-2012 at 11:21 AM. |
More on this topic......http://www.candlepowerforums.com/vb/...e-Counterfeits
Sent from my SPH-D710 using Bimmer App
I might have to cut of the cable ties and swap them around to see if its a ballast issue.. |
![]() I pursued your suggestion and found that, indeed, Philips India makes some retrofit kits: http://www.lighting.philips.co.in/v2...p?id=1012984#0 I may have to fly to India and buy one. I have always wanted to visit. (I have been to Oz, although there is plenty more of it I would like to see!)Quote:
I just threw a Philips HID part number at Google, Philips Australia still lists them as well: http://www.lighting.philips.com.au/v...jsp?id=1012984
I wonder why I have not seen them here. Perhaps the headlight washer and auto-leveling requirements? (Although I think the TÜV will at least waive the former.) Or that a car with more than 100 000 km is considered old and decrepit? What are the requirements for Australia? Last edited by johnf; 12-09-2012 at 02:42 AM. |
You could mail order? But an excuse to fly to India - or Australia, for that matter, is a great one! How would you suggest I measure the draw? I *should* have a multimeter around here somewhere.. |
![]() Quote:
If I understand you correctly, the HIDs are blowing both fuses even when they are 10A? How quickly does the fuse blow or the fuses blow? Last edited by johnf; 12-09-2012 at 06:52 AM. |
appriciation
hi
very nice posts,i like this forum very much |
I'm sure you're just maturing with age..just like a fine bottle of wine I had a think after you comments on blowing the fuses..took me back to physics and electronics..what could cause such a sharp spike in A as soon as they are turned on? Well, I tried swapping the ballasts..that was a waste of time. Turns out, they were fine. So racking my brain, the only idea I could come up with, was a short-circuit. I rechecked all the connections and cables and I was just about to give up until..the bulb! I popped off the dust and water protection cap and sure enough the connections to the bulbs were touching each other more than a French couple..so I duct-taped one of them so no metal was exposed and - voila! Problem solved! Thanks for all the help guys! =D |
Thanks for posting the solution.
| Tags |
| blow, fuse, headlight, hid, philips |
