Old 12-08-2012, 06:28 AM
tissot tissot is offline
Mein Auto: f33
Help! files with green marks disappear from SVT section.
Hi,
I tried to revert to orignal, but something goes wrong.
Now, some files from SVT section disappeared, I haven't got ACSM, KAFAS, and some others...
I have these catalogues (ACSM, KAFAS) but inside are only files with grey mark.
I have many errors on the dash, airbags, seatbelts, ASR, EDC...
I don't know what has happend. Probably I have to go to dealer but I don't even know what to tell them.
I have CAF files backuped, but I can't use them, because I can't right click on file with green mark as I don't have it.
please help.
Old 12-08-2012, 08:45 AM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
http://www.bimmerfest.com/forums/sho...d.php?t=653389
Old 12-08-2012, 10:43 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Originally Posted by tissot View Post
Hi,
please help.
I think I can help you, but just so I am clear, you have many ECU's that are still in your SVT, but they are missing their CAFD, so you can't FDL Code, nor can you right-click => NEW to restore your saved CAFD.
Is that right?
Besides ACSM and KAFAS, what other modules are in this condition? Keep in mind this is normal for RDC and ZGW modules as they do not contain coding data.
Where are you located?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 12-09-2012, 07:58 AM
Mein Auto: f33
Is that right?
Yes, exactly. Even if I could click NEW, I don't know wich CAFD file fits to each ECU.
I attached my SVT view, report after read all ECU's with 1 fault, and view after reading, there is no VIN numer beside missing ECU's files. Also fault list and my backuped CAFD files.
Missing ECU's files: ACSM, AMP, GWS, KAFAS, PDC, RK[a6], SM, ZGW
I think these ECU's that I modified ever, although I don't remember RK, SM.
far, far... Poland.
Shawn you are my last hope
ID:	352456   Click image for larger version
ID:	352457   Click image for larger version
ID:	352458   Click image for larger version
Name:	my CAFD files.jpg
Old 12-09-2012, 08:47 AM
far, far... Poland.
Ok. For each ECU missing a CAFD, I want to to highlight the ECU, and select Detect CAF for SWE. A window will pop up, and you can select a CAFD. Pick anyone of them at this point. It will put CAFD under ECU. Then click on the CAFD, and select NEW, and use you backed up .ncd file, then FDL code the module. Do this for every module you have no CAFD for.
Old 12-09-2012, 09:09 AM
Since you do not know which .ncd goes with each ECU, do you know what I-Level is on your car?
You can go under VCM and read your I-Step. What it shows for your I-Step (Current) is your current Integration Level.
Now when you run "Detect CAF for SWE", each CAFD shown is associated with an I-Level, so select the CAFD file that matches your I-Level.
Old 12-09-2012, 12:57 PM
Mein Auto: f33
Thank you very, very much.
Unfortunatly it works only on AMP, KAFAS, PDC, SM.
In others ACSM, GWS, RK[a6], after "code FDL" I have errors, I attached report. Maybe in this ECU's should be more files? I saw on same printscreens that in ACSM are 3 files with green marks. But I don't know how to load more than 1 file.
I tried load files in diferent sequence. I checked everything twice.
Old 12-09-2012, 01:24 PM
Try this now. VO Code ACSM, GWS, RK[a6]. Right-click on each ECU itself, not the underlying CAFD, and selct CODE.
See if that works.
Old 12-09-2012, 01:32 PM
My ACSM has 3 CAFD's, RK[a6] has 2 CAFD's, but GWS has only 1 CAFD.
When you did "Detect CAF for SWE", you should have used the Ctrl Key and tagged all the needed CAFD's at once for the appropriate I-Level, like attached picture.
If the VO Coding doesn't work, go back and add the missing CAFD's from the same I-Level you used to add the one CAFD.
Old 12-10-2012, 06:31 AM
Mein Auto: f33
I did it
But I wonder if everything is ok. When I tried use "code FDL", I had errors. I highlighted ACSM and then clicked "code". After that I have normal files with green marks.
Then I cleared faults like in this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=662901
They didn't deasapear after coding.
What is the difference between "code FDL" and "code"?
Shawn, what do you think, everything is in order?
Old 12-10-2012, 07:42 AM
I did it
It's not clear to me what you have now.
Do all of your ECU's have CAFD's with Green dot (except non-coding ones)?
Are you getting any errors now in E-Sys when FDL coding any ECU?
What errors are showing on the car?
Old 12-10-2012, 07:53 AM
Mein Auto: f33
All ECU's have CAFD with green dot.
I haven't errors on the car, everything works properly. Faults deasapear after use TOOL32.EXE.
Today, after work, I will check everything carefully. I will try to make some changes (dvd in motion, seat belt ring). Then I will use "code FDL" on all ECUs.
Old 12-10-2012, 08:01 AM
Ok. Sounds to me as if all your problems are solved. PM me your address so I can send an Invoice.
After this "trauma", I would VO Code (CODE), not CODE FDL, every ECU, before I FDL Coded anything.
Old 12-11-2012, 12:36 AM
Mein Auto: f33
!!!!! Shawn THANK YOU VERY MUCH !!!!!!
Everything works perfect, no faults
Old 12-11-2012, 03:26 AM
