Engine Bay Wiring Help Pleez - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 12-08-2012, 05:58 PM
E36 Phantom's Avatar
I Am The Machine
Hai gaiz. Unfortunately I didn't see where these two wires went when we were (wow 5 words starting with w in a row!) dissembling the engine bay. TIA!
On the drivers side I have this pair of wires with a rubber cover, don't have much slack.
On the pax side I have the ground strap and can't see an obvious place for it to attach.
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 12-08-2012, 06:26 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Hard to see/tell Chad. The top almost looks like starter wires. Are they all hooked up?
If the other one is a ground strap, where is connected, the engine mount? It shouldn't really matter where it goes per say, I think mine may be on the engine block?? Not really positive at the moment though.
Turbo Build Here
Old 12-08-2012, 06:27 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
1st pic looks like the alternator or starter power wire
2nd pic bolts up near the engine mount from the bottom
-Dino
Old 12-08-2012, 06:28 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
I could be mistaken but aren't first pic alternator wires?
Instagram | @randytheus
Old 12-08-2012, 06:36 PM
I Am The Machine
The ground strap is currently connected to the spot on the engine mount arm, where does it mount on the body?
And d'oh, yep alternator wires. Good call. Thanks
// Chad //
You're a derbanana
Old 12-08-2012, 06:38 PM
Needs Boost
Mein Auto: Red Sled
http://www.google.com/imgres?um=1&hl...r:11,s:0,i:120
Turbo Build Here
Old 12-08-2012, 06:43 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
some seriously silly statement, skippy....there's 5 "s's"....count 'em....1...2...3...4...5!!!
so there...
since we have already established the first pic were alt wires, the last pic are ground wires, we just need to verify the location of the mounting.
look around the motor mount. iirc, the strap connects the motor mount bracket to the chassis...
edit:matt beat me to it...
but is still haz teh 'ssssss'....
df
Old 12-08-2012, 07:17 PM
I Am The Machine
Sweet, thanks guys. Found the ground strap after crawling around under there some more. It's a long enough strap I thought it would be visible from the top, didn't think it would be under there.
Thanks erryone!
// Chad //
You're a derbanana
Old 12-09-2012, 01:27 PM
I Am The Machine
New question!
What the hell connects to this blue hard line right next to drivers strut tower.
// Chad //
You're a derbanana
Old 12-09-2012, 01:46 PM
BMRfanatic's Avatar
charcoal canister
-Dino
Old 12-09-2012, 02:03 PM
I Am The Machine
I thought charcoal canister was under the spare tire. Fudge, I just checked the emissions label and it is there, but I don't see it anywhere in the garage. Guess I'm not getting smogged today after all
// Chad //
You're a derbanana
Old 12-09-2012, 02:08 PM
Needs Boost
Mein Auto: Red Sled
Did you fire it up yet?
Sent from my SCH-I605 using Bimmer App
Turbo Build Here
Old 12-09-2012, 02:13 PM
I Am The Machine
Not yet, this and the alternator is basically the last thing before I throw the air box and belts on and turn the key.
// Chad //
You're a derbanana
:3
