Old 12-09-2012, 06:39 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Chrono..why didnt you use the PDX Alpine series. Much more compact and as a class D they generate little heat.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
Old 12-09-2012, 07:36 PM
Cchrono Cchrono is offline
Mein Auto: Bmw
I thought about it but they just don't have the power or level of sq that the zuki amps have
Old 12-15-2012, 09:57 AM
alexsih alexsih is offline
Mein Auto: 2005 X3 3.0i
Finally....
My audio upgrades are finished. Here is what I did:
Audio Control EQX for equalization and crossover with Stock HU speaker lines into EQX hi-level input that drives Vintage Alpine Amps. MRV-F357 (5 channel amp) drives the 4 passenger speakers that were replaced with Alpine SPS-410 and the sub channel driving the JL sub. I left the factory sub below the seats unhooked.
The SPS-410 seems to start to roll off below 300 Hz and with the EQX crossover at 80 Hz, it left a mid-bass hole.
So I procured a MRV-100M and hooked the factory subs back up. The MRV-100M Hi-pass was set at 200 Hz and it seemed to fill in the mid-bass nicely.
Sub details: JL Audio 10WXv2-4 in a custom box sourced from from WickedCAS.
see http://www.wickedcas.com/product.php...&cat=10&page=1
Many thanks to all on this thread, especially to evlengr and x3oiler, for the advise and research captured here... And to ebay and craigslist where all the above were sourced.
BTW, I also added BSW's Soundplicity for the ipod interface. It was very clean, no noise as opposed to DICE.
Pics attached were taken with my iphone (sorry for the low quality).
ID:	353306   Click image for larger version
ID:	353307   Click image for larger version
ID:	353308   Click image for larger version
Old 12-30-2012, 12:47 PM
Epark1013 Epark1013 is offline
Mein Auto: BMW 2004 X3 2.5i
Ok so i am deciding to buy myself a new christmas present which are new door speakers... i have a 2004 with
Kenwood KDC-348U head unit
JL 250/1 amp
JL CP 110-W0v3 Subwoofer
I have looked through this thread and found these speakers on Crutchfield
http://www.crutchfield.com/p_107DB40...01.html?tp=105
http://www.crutchfield.com/p_500SPS4...10.html?tp=105
which would you recommend? and would i need to have a stronger amp if i get these speakers
thanks
Old 12-30-2012, 01:54 PM
Bufalo Bufalo is offline
Mein Auto: 2007 X3
I have the Polk's and I feel they're a great upgrade. You can find them for closer to $50 for the pair on Amazon. Of course the Alpine's are the most popular choice, also. I have not listened to them and thus am not qualified to comment on how they compare to the Polk's. Either choice will perform best with dedicated amplification.
Old 12-30-2012, 02:13 PM
I seem more intrigued by polk and crutchfield has a deal for half price off the second order so that will save me for the back doors as well.
the only question i have is...is my amp powerful enough to have these speakers put in
Old 12-30-2012, 02:33 PM
x3oiler x3oiler is offline
Mein Auto: 2006 X3 3.0d
Funny you should say that. I have an older DICE that I have used for years but it is not compatible with the iPhone 4S so I bought a new - later model - firmware upgradeable DICE unit. After having to return the first unit as defective (no left channel) I found that the replacement unit is very noisy - more apparent with the newer audio - so much so that the older DICE is back in service and I will live without the 4S integration. As an aside, I found the DICE remote control of the ipod (head unit display of track etc) to be useless (so slow) and I switched it off in the older DICE - this is not an option in the newer DICE it seems - another negative point. . . . sorry slight thread hijack here.
X3 3.0d 2006 (MY07)
Old 12-30-2012, 03:02 PM
JL 250/1 amp
thanks
The AMP you mention is for the sub so I assume you refer to the head unit driving the 4x door speakers once upgraded. The Kenwood seems capable of 22W into 4 ohm.
I have the stock business CD head unit driving the door speakers via PXE-650 then a separate Pioneer GM-D9500F AMP that is in theory 4x75watt but then I am not a)driving the amp at full gain (less than 50% gain) and b) not driving the (front only) door speakers to a point much louder than the stock system would have achieved in any case. All very subjective I know but I do wonder about the relative power of the sub compared to how hard you will have to drive the door speakers to "keep up"? You will however be driving all four door speakers it seems so you will be "one up" on my setup wrt volumes (I only have only fronts really powered up - rear set for background volume from the stock head unit only).
One point to note. Adding more power to the door speakers may not be the way to go - the Kenwood alone may be preferable. The SPS410 seem to like being hit hard above 400 to 500Hertz and not lower. Just adding more power to the doors will cause some distortions if you do not cut off the low end. If you simply cutoff the low end to the doors then you will have a midrange hole to fill (sub running with the doors). If you still have the under seat mids installed then they will take over but then you have to consider powering them as well and what crossovers to use for them and the relative sensitivities.
Suck it an see I think is the way to go ie the Kenwood driving the upgraded doors, the mono amp driving the sub.
X3 3.0d 2006 (MY07)
Old 01-04-2013, 03:26 PM
Mein Auto: 2007 X3
I initially powered my Polk's with the X3's OEM amplifier, which provided an acceptable improvement in sound. Soon after that (within a few weeks) I added an aftermarket amp for these (a 50x2 old Rockford Punch 100), and everything about the sound again improved markedly. So yes, you can certainly power these with your current setup, but I would recommend planning for extra power.
Old 03-01-2013, 10:53 AM
WayneGB WayneGB is offline
Mein Auto: x3 3.0SD M Sport
in the process of working out what i need to do to upgrade my x3.
I have single cone speakers in each door, no amp, but i do have the gps & bluetooth modules.
Intending to replace both sets of door speakers (Alpine's) and probably the underseat mids (I expect these are 6" versions as uk spec. do the seats have to be removed to get these out?)
Anyone got any measurements for the size of the 8" underseat speakers? trying to find something to replace them with, maybe one of these?
MB Quart RLP204 or Pioneer TS-SW841D or maybe these would work (without tweeters) Alpine SPE-20SF
Hoping to amp (prob Alpine pmx 640) fronts and underseat speakers from an amp in the boot but my problem is wires....
where is best to pickup the speaker wires? and do I need to rewire back to the speakers or is there a way to be sure theres no caps along the line somewhere?
I cant find any speaker wires in the back or caps wrapped in foam :/
Sorry if I have any bad ideas my knowledge in this area is basic but trying to learn.
anything anyone can add or do to simplify this for me would great - thanks all
better suggestions for kit being used is good too especially if im missing something!
Old 03-01-2013, 03:05 PM
A9ennis A9ennis is offline
Mein Auto: 2009 x3
uk spec upgrade
WayneGB,
I am just about to start exactly the same project. I have purchased all the bits i need, had most of the required bits of the car apart to establish wiring, locations etc.
I have a 2009 X3 3,0D Msport with the standard radio. One thing i have learned is the speaker wiring routing in the uk cars is different from the USA, Aussie or Europe.
The speaker is a 6 speaker system 4 inch in the doors, no tweeters, with 6" or 8" bass unit under the seats (havent removed these yet to confirm)
The speaker cables (Front L&R, Rear L&R) go from the head unit down and along the centre tunnel, at about the hand brake area, the front speaker cables split to supply the front doors and the under seat speakers. All the speaker cables go to the left side rear door sill plastic kick plate, here the left speaker cables head forward along the door sills to the B piller (rear door speaker), the Bass speakers and the a piller (front door speaker). The right speaker cables pass across the front of the rear seat and down the sill in the same manner as the left. I have not found any inline capacitors as yet i have viewed about 80% of the cable runs.
My plan is to cut into the wire at the rear left sill area, route to the under boot storage area. Then back to the cut in point.
The amp i am using is a Mac Audio Attack 600, 6 channel amp with speaker level inputs, channel gain control, and high and low pass filters. This allows a separate amp per speaker location. The doors will be 90Hz up and the under seats 90Hz down.
Door speakers are Mac Audio Star-X 4" components
Main Power supply is easy as the compartment is next to the battery, remote i am intending to use the switched supply to either the bluetooth module or the SatNav disc unit.
feel free to PM me to discuss as i intend to do a write up to help other UK people.
Old 03-17-2013, 11:42 AM
Did you manage to get any further with your project, so far swapped the door speakers out - much better.
next is the amps if i can work the cabling out
Old 03-17-2013, 11:53 AM
Mein Auto: 2009 x3
Wayne,
Got it all sorted, colour codes, tie in points etc. will do a write up, pics etc. it's actually quite straight forward you will be please to know.
Old 03-17-2013, 01:13 PM
Chrisojw Chrisojw is offline
Mein Auto: 2007 X3 3.0d M sport
Progress....
Hi Wayne and Ennis
How are you getting on with your mods? Not had much time recently but hoping to attack my project at Easter. Would be interested to get your info on what size the under seat subs in the standard uk set up are? If they are 8" I might not bother swapping them out, just amp them?
Are you pleased with the results of your mods??
6 CH amp sounds like the way to go for me. From your notes I'm guessing the point to cut and splice in ALL the speaker wiring is at the left hand rear door sill panel correct?
Cheers!
Old 03-20-2013, 04:40 PM
Mein Auto: 2009 x3
I have completed my guide. i just need some one to host it so i can upload it on to the forum....any offers.
Chris, wayne, PM me with your email address and i will send it to you.
Chris, the system sound much much better, but the under seat speaker muddy the bass and spoils the sound. I am going to upgrade them soon. Project 2....
Old 03-22-2013, 08:54 AM
Mein Auto: 2009 x3
UK car audio amp wiring guide
Finished my audio upgrade, completed a guide for all those members with UK cars as the audio harness is a bit different and the info can be hard to find all in one place,
hope it helps
Name:	UK Audio Wiring Guide page 1.jpg
ID:	367593   Click image for larger version
Name:	UK Audio Wiring Guide page 2.jpg
ID:	367594   Click image for larger version
Name:	UK Audio Wiring Guide page 3.jpg
ID:	367595   Click image for larger version
Name:	UK Audio Wiring Guide page 4.jpg
Old 03-22-2013, 09:08 AM
Mein Auto: 2009 x3
For the speaker upgrade i used MAc Audio Star-x 2.10 components, about £100 a pair from Just sounds in germany. Minus having to modify the tweeter mounting they went straight in, depth not a problem.
http://www.just-sound.de/
Sound wise they are really very good, as good as the B&O system in my Audi A5. They give a very clear, airy sounds, excellent detail and very good imaging. I have yet to do the under seat speakers which i intend to do as the bass from them is muddy and thick sounding.
The amp was a ebay lucky buy, £30, for a 600w 6 channel amp with speaker level inputs built in...works great....
Name:	Aberdeen City-20130306-00626.jpg
ID:	367598   Click image for larger version
Name:	Aberdeen City-20130306-00627.jpg
ID:	367599   Click image for larger version
Name:	Aberdeen City-20130306-00629.jpg
ID:	367600   Click image for larger version
Name:	Aberdeen City-20130307-00635.jpg
ID:	367601   Click image for larger version
Name:	Aberdeen City-20130307-00636.jpg
Name:	Aberdeen City-20130311-00639.jpg
Last edited by A9ennis; 03-22-2013 at 09:11 AM. Reason: Adding PDF version of the guide
Old 04-07-2013, 10:36 PM
badgermanus badgermanus is offline
Mein Auto: X3 E83 3.0i
Alpine SPS-400 $70 all around good sound most popular http://www.crutchfield.com/p_500SPS4...ures_and_specs
Evlengr - thanks for the suggestion.
I've just completed installing 4 Alpine SPS410 ($100 for the set from Amazon) and am pleased with the improvement in sound quality, especially for the price.
The big question is where to go next. I'm thinking:
- JBL MS-8 DSP with 8 channels of (modest) aplicatification
- JL XD/600 6 channel amp
I can get both for a similar price, so very interested in what people think will give most bang for the buck. I'm more interested in sound quality than volume.
Cheers, Jonathan
Old 05-25-2013, 02:38 AM
Kalil147 Kalil147 is offline
Mein Auto: BMW 545i
Hi
I have a BMW X3 and it sounds like crap. I am looking for a little more bass without distortions. My x3 does not come with the factory woofers. Is there a way to install factory woofers by just plug and play? Or would the 4 alpine speakers do the trick?
Old 05-25-2013, 08:49 AM
chewywso chewywso is offline
Mein Auto: 2005 x3 3.0, 2002 325i
Concur with the sound. I went with the Alpines due to this thread, best money you will spend on the X3. It now sounds as it should like many other premium factory sound systems which are sufficient for most.
Old 05-25-2013, 10:50 AM
Mein Auto: 2004 X3 2.5i
Originally Posted by Kalil147 View Post
... My x3 does not come with the factory woofers. Is there a way to install factory woofers by just plug and play?
All U.S. market X3's came with sub-woofers under the front seats, so does this mean that a previous owner removed them?
If they didn't mess with the wiring it would be plug'n'play if you get some surplus ones from the autowreckers.
Or do you mean that the speakers in the door were removed by a previous owner.
In which case, no big loss, as the Alpine SPS-410 coaxials will be better than those "full range" drivers and separate component tweeters (front only unless DSP upgrade).
Old 05-26-2013, 09:12 AM
Mein Auto: BMW 545i
Hi
I purchased my BMW in Germany and had it shipped to Central America. I could have purchased an X3 in El Salvador but they only sell the most basic version X3. I needed a turbo diesel, stick shift, and wanted the tv and moon roof - (these options are not available at the dealer here). I guess I was so focused on those details that the premium sound slipped passed me.
My X3 has no subwoofers under the seats. I dont know if the harnesses are there. Im going to have to take it in. I just feel that my x3 will still sound like sh*t if I buy the alpines and have no woofers to back it up. Suggestions? Should I just buy the alpines anyway? Or should I retrofit some woofers in case the harnesses are missing?
Old 05-27-2013, 11:33 AM
I haven't tried it without the subwoofers, but my guess is that swapping your speakers for the Alpines will give only a modest improvement. A significant portion of the lower-end of the audio comes from the under-seat woofers.
Swapping the amplifier was what made 90% of the improvement in my X3 (I swapped for a JBL MS-8). I did that *after* swapping in the Alpines, so can't comment on what swapping just the amplifier will do, especially without sub-woofers.
Cheers, Jonathan
Hi
Old 06-02-2013, 09:12 AM
sixspeedz sixspeedz is offline
Mein Auto: 2004 X3 3.0i, 6 Speed MT
Hi all, i have a farty rear speaker and am about to replace. Was reading through and just wanted to confirm...
If I go ahead and replace all door speakers with the Alpines, will there be a considerable upgrade to sound quality sticking with the factory setup for the rest (subs, amp, and HU)?
Also, if i add an amp later, do i need to take all the doors off again or can I tap in to the factory wiring somewhere?
Thanks!
Old 06-10-2013, 10:02 PM
Thanks!
No - in my experience you need to upgrade the power amp to get an appreciable difference in sounds quality. Once you've upgraded your speakers, no need to take the door cards off again to replace the amp.
Cheers, Jonathan
