E36 (1991 - 1999)
Old 12-08-2012, 09:17 PM
Eight Thirty Eight Thirty is offline
nothing.
Mein Auto: ItAintUrShtYUCare?
LED lighted headliner
Okay so you guys know that my headliner looks like this:
(not the most recent)
At night i can imagine that the headliner having like a moonlight glow. so i want to achive that.
Im looking to buy 5 blacklight LED's single bulbs.
I have no clue what im looking for here.. and the cheapest i found was 1.99 on amazon each... i though LED's were cheap? f***
Then im looking for a small dimmer switch that i want to install down near the steering wheel.... like below the column but on that lower dash area. so a small black dimmer so i can control the blacklight that is emitting from these.
How do i wire these to make them all the same brightness and run off the dimmer? i cant imagine it... I know it would be a pain... but can you draw a picture? im going to try to draw one too... to see if my idea is right. but would i be wiring up in parellel or in series? series will cause them all to spilt power and parrellel wouldnt right?
would i need any resistors or anything of the sort?
what power line should i be thinking of taping into?
and then the ground.... just anywhere on the chassis?
does either of these look right? sorry if they are terrible or wrong... im just guessing
nothing.
Old 12-08-2012, 10:08 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
First one (parallel circuit) and, yes, you need a dropping resistor unless you buy 12 vdc LEDs. Most of them operate on 1.5 volts.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 12-08-2012, 10:12 PM
nothing.
So the resistor would come in....
and what level of resistor should i buy?
like its measured in Ohms right?
nothing.
Old 12-09-2012, 03:57 AM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
http://www.superbrightleds.com/cat/led-accent-lighting/
ooooops....looked like i dropped something....
have ordered leds fromthese guys, and iirc they had decent prices. (yet *another* project that is on the backburner....)
df
Old 12-09-2012, 05:52 AM
TouTou TouTou is offline
TouTou
Mein Auto: e46
[QUOTE=drivinfaster;7238851]http://www.superbrightleds.com/cat/led-accent-lighting/
I want to change my angel eyes on my X5. I want to change them to the new angel eyes. The bright super white. Any idea on what I should be looking for in this site? I don't want to order the wrong one.
Sent from my SPH-D710 using Bimmer App
Old 12-09-2012, 06:02 AM
jonesin's Avatar
jonesin jonesin is online now
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Tee hee. df, you're so subtle, dropping things under your desk like that...
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.”
- Hunter S. Thompson,
Old 12-09-2012, 06:24 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: '93 ///S50 powr'd 318is
[QUOTE=TouTou;7238915]
Ashlins x5 has white angel eyes in them, I bought them off eBay. There not as bright as the new cars but wayyyyyy better than the yellow. I would figure the new ones are xenon powered or something more than just the bulbs.
Franklyn sounds like a fun project...you need the sunroof motor cover? I may have one.
Jesse
Part out.
http://bimmerfest.com/forums/showthr...67#post7418867
"Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI
Stock 2004 X5 3.0i (Wifes)
E30 87 325e
Old 12-09-2012, 10:38 AM
nothing.
na i have one... just wasnt in this photo
nothing.
Old 12-09-2012, 10:56 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Go find a wiring diagram for the Rolls Royce Drophead Coupe, it was an option on those to have starry sky effect LED headliners.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
You're a derbanana
Old 12-09-2012, 07:49 PM
TouTou
Mein Auto: e46
Good looks I have to look in to that. It would look a lot better if it was super white angel eyes
Old 12-10-2012, 08:28 AM
petriej's Avatar
petriej petriej is online now
Cruising 280 Top Down
Send a message via Skype™ to petriej
Surprised no one brought this up, but a dimmer switch does not work the way you would think on LEDs.
LEDs are like switches, either ON or OFF. To properly dim LEDs you need to modulate the voltage very quickly (called Pulse Width Modulation). Rather than try to give you an LED 101 course, just look up some pre-built LED driver that has what you want on it. It won't be as cheap as your LEDs (yes, $2 for Blacklight LEDs are cheap).
Cool idea, though.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by SCJon View Post
Jared is king of ambiguous comments.
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 12-10-2012, 08:59 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
What you write may apply to the Z3 and Compact. A E36/2/4 dimmer unit, however, does use Pulse Width Modulation, but with a linear, ca. 20-100% dimming curve meant for incandescent lamps. To provide uniform and sufficient dimming, a PWM dimmer for LEDs needs a non-linear (exponential or square-law) dimming curve that ranges from nearly 0 to 100%. I couldn't find a suitable automotive LED dimmer when I looked a few years ago, and ended up designing one to dim a pair of 10 mA LEDs in series.
You face the same issue when you change the interior lights to LED. I square the linear, PWM, ramped lighting signal from the ZKE (and change, say, 10% on to 1% on) which seems to do the trick.
Old 12-10-2012, 09:16 AM
petriej's Avatar
Cool! TIL...
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-10-2012, 10:45 AM
johnf's Avatar
John Firestone
I don't know how good it is, but I found this LED dimmer.
Old 12-10-2012, 10:38 PM
JohnGutmannnn JohnGutmannnn is offline
Mein Auto: White 1995 325i
http://www.ebay.com/itm/DC-12V-8A-LE...item4168bc1f32
Could pull it apart and run an external pot if you wanted to.
http://dceuro.com/forum/
Old 12-13-2012, 09:39 PM
Estorma Estorma is offline
Mein Auto: BMW
Im looking to buy 5 blacklight peimar led lights single bulbs.
Have you got those led lights. Even I am thinking of purchasing some led lights
Old 12-13-2012, 09:51 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Every time this thread gets bumped, the RR DH coupe is exactly what pops into my mind.
1998 BMW 328is
1966 Pontiac GTO
Old 12-13-2012, 11:00 PM
nothing.
no i havent.
I stopped replying in this thread because im not going to do it. not worth it to me. wanted it to be like a 10$ budget project.. and its way more than that. so no me gust
nothing.
Old 12-14-2012, 06:14 PM
bottle of glue: $0.99
jar of glitter: $2.99
pocket flashlight: $4.99
picture of teh lowness e36 with dedazzled headliner in a tiara??
priceless!!
c'mon,...you know ya wanna!!
df
Old 12-14-2012, 08:16 PM
dc_wright's Avatar
Mein Auto: '96 328iC, '04 325Ci
LEDs are like switches, either ON or OFF. To properly dim LEDs you need to modulate the voltage very quickly (called Pulse Width Modulation). .
Cool idea, though.
Sorry but incorrect! The light output from an LED is directly proportional the current through it. You can control the brightness of the LED using PWM also but it's done to reduce the power dissipation of the dimming controller not because of the LED.
If you use a linear control the power NOT delivered to the LED has to be dissipated by the control device. When the LED is fully dimmed the controller dissipates all the power. When you use PWM the only dissipation in the controller is due to the losses in the internal switching circuits. You are actually turning on the LED at full brightness but for a short time and off for a time at a rate fast enough that your eye can't discern the flicker. As you increase the ratio of on to off the LED appears to be brighter and when you decrease the ratio of on to off it appears to be dimmer.
John, you can do the same with an audio taper potentiometer for LED control. The issue when you replace an incandescent with an LED is the huge difference in currents required for illumination. If you put an LED in a circuit design for incandescents your control range for the LED is at the very end of the control so you essentially have none. You can put a resistor in series with the control to rescale the current and get good control range.
'96 328iC "Marie"
Old 12-19-2012, 06:03 AM
johnf's Avatar
John Firestone
In practice, you can treat LEDs that way from, say, 25% to 400% (pulsed) of their static, maximum current. The further you stray from that range, however, the more an LED diverges from a linear ideal, because of its semiconductor non-linearity and its inexact manufacture. This is especially true of white LEDs. They must be matched or "binned" during manufacture (into perhaps 4 x 3 = 12 different bins) to have any hope of producing a group of them with a consistent hue and intensity. Even then, the hues and intensities within a group will diverge if you decrease their drive current much below a minimum value, their so-called "grouping current". This might be 5 mA for a 20 mA white LED – which is not much dimming! Dimming an LED with PWM not only saves power, it also maintains its hue as you go lower, and dimming a string of LEDs with PWM keeps their intensities consistent.
As a practical example, I have a couple, series-wired, white LEDs in my dome light that illuminate the center console. I pulse width modulate them: with a 100% duty cycle, to light a map or a list of directions, and with a 1% duty cycle to provide ambient lighting. If I am unlucky, one of the LEDs might not even stay lit, if instead, I were to reduce their current from 10 mA to 100 uA – to say nothing of how their hues might change.
The issue I have had with LEDs vs. incandescent lamps is how much more linearly a LED's brightness changes with voltage and current compared to an incandescent filament, as in somewhat linearly vs. very non-linearly. (I think that is what you mean.) I like your idea of using an audio taper potentiometer in series with a resistor, which will also protect the pot from shorts. If we set aside everything I wrote earlier, I suspect, however, it might only be a simple solution for fairly low LED currents. I get the impression that rather few use audio taper potentiometers as power rheostats. I can't find any over 2W (and those are pricey), and the pot datasheets I have browsed give no guidance for the maximum current the pot can carry approaching zero ohms.
Old 12-19-2012, 09:28 AM
petriej's Avatar
you guys are too much.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-19-2012, 10:12 AM
johnf's Avatar
John Firestone
Indeed. It is a quaint and neglected way of considering things.
