Recently I just checked the bottom of my car and found this. It looks like suspension rod is supposed to be covered with something like sponge. However it seems to be damaged by age. The rod still looks shiny so that is good news. How bad is this if I don't replace the cover ? It seems hard to replace it.
Your ride quality won't be what it's supposed to be without it.
To replace the bump stop requires dissembling the strut a bit. By the looks of the wear shown in the pic, the front end could probably use some TLC all together. The stops normally don't get pulverized like that unless the dampers have been completely neglected for some time.
Thanks for the link ! The name of it is "additional shock absorber". Then it means that it absorb less shocks then before. It seems like it is hard to replace them Good to know the name of it at least. Lots of remaining works for the car. Today it failed smog test.
yes to replace it requires removal and disassembly of the front strut. you may like to get a specialist to inspect the shocks and replace these at the same time, as there will be no further labour cost to do this.
its your car, but i would focus on getting it to pass smog first.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
