E30 (1982 - 1993)
Old 12-06-2012, 06:42 PM
t2112 t2112 is offline
Mein Auto: 330 ci / 325e in progress
Oil pan replacement ?
Anyone replace oil pan on 325e? Looking for tips from someone that's been there. Thought just support engine a few inches high after disconnecting drive shaft and manifold. Better ideas anyone.
Old 12-06-2012, 09:23 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
You really should get a Bentley manual.
Here's the relevant parts for your project:
Name:	E30 oil pan removal.jpg
ID:	352211   Click image for larger version
Name:	E30 oil pan removal 2.jpg
ID:	352212   Click image for larger version
Name:	E30 oil pan removal 3.jpg
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 12-07-2012, 02:43 AM
BMWFatherFigure's Avatar
Old School
For a small lift (up to say, 3") no need to disconnect anything, IF you are careful
Current:
E38 Parts Car
Previous:
Old 12-07-2012, 09:51 AM
D'oh, You Kids!
The trick is getting the oil pump out so you can then pull the pan. You're going to have some "head scratching, how the crap do I do that?" moments. Putting the pump back when you're buttoning it up is fun, too.
Quotes to live by:
BMW-CCA #441426
Old 12-09-2012, 03:24 PM
Bullmoose Bullmoose is offline
Mein Auto: 1990 535i 5 speed
I found the easiest thing was to use an engine support bar to hold the engine up and drop the subframe crossbar completely out of the way
Old 12-10-2012, 05:22 PM
GeorgeBush234 GeorgeBush234 is offline
Mein Auto: Passat
I think your only job it s to jack up the car and star unbolting the screws from your oil pan bro.
