325i Power Window failure - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 11-17-2009, 12:09 PM
bimmerman1985 bimmerman1985 is offline
Mein Auto: 1995 M3
I own a 92 325i 4 door and my windows are not working. Long story short I drove to work and the windows were working fine; then I got in to my car to go home and they didnt work. I posted a thread a month ago (about the time the windows stopped working) asking for any advise on fixing this and everyone replied with "probably a fuse in the fuse box". There is NO fuse in the fuse box under the hood for the power windows believe me I've checked. I did recieve a reply that said it could be the comfort relay under the steering wheel. If anyone agrees or has any other suggestions please let me know. Thanks
Old 11-17-2009, 12:44 PM
madromas's Avatar
madromas madromas is offline
Alja Bydlo
Mein Auto: 93 325i
How is there no fuse for power windows. It can't be. Dont look for window fuse, check them ALL.
From Russia with LOVE
Fun and Unique VipJournal
Old 11-17-2009, 01:48 PM
Mein Auto: 1995 M3
They're all good, none are broken. I replaced the central locking system fuse a month ago; now my locks are working fine, but still no windows. FYI my sunroof is working. Also are my window switches suppose to light up when I turn on the headlights? Cause mine dont, but that might not be a problem.
Old 11-18-2009, 01:33 PM
madromas's Avatar
Alja Bydlo
Mein Auto: 93 325i
Sopose to, but if your bulb inside the switch is burnet than no. But is will not cause the problem.
There is a button on the right of the steering wheel, make shure it is not activate. It sh.uts the power to all windows but not to the sunroof.
Old 11-18-2009, 02:02 PM
Moeman10's Avatar
Moeman10 Moeman10 is online now
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
Ahh, yes, that unmarked black button in between the window switches? The window lock.. make sure it's not on..
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 11-18-2009, 05:02 PM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
92 was a strange year as it was a transition period from e30 to e36. I found in my BMW ETM2 that your power windows could have power flowing through fuse 13 (5A) and fuse 14 (30A) or not be fused at all (as well as the sunroof), using the comfort relay as your over voltage protection. Be wary of fuses as they can appear to be ok and actually have a break at a non-visible location.
If you have a model using the comfort relay, it can only be the comfort relay or a bad ground.
Old 11-18-2009, 05:05 PM
FixItFaster
Damn that pic is useless.. It simply shows how power comes from the power distribution box (fuse box) to the comfort relay and so on.
Old 11-18-2009, 08:51 PM
bonafied36 bonafied36 is offline
Mein Auto: 1995 318i
I had a similar problem, my front passenger window stopped working than a couple weeks later my front driver side window came off the tracks. hopfully its a simple problem because if you wind up having to take the door panel off and fix the motor ull wind up with a hugeeee headache
Old 02-22-2010, 05:35 PM
cbfurg cbfurg is offline
Mein Auto: 1993 325i
i am having the exact same problem in my '93 325i right now. if you figure it out, please let me know! thanks
Old 05-22-2010, 02:07 PM
chungaa1 chungaa1 is offline
Mein Auto: 1993 bmw 325i sedan
it's probably a cold solder joint on your comort relay...it's probably only one suspect leg on the relay with the cold solder...--i resoldered the leg and everything worked as advertised...
Old 12-10-2012, 06:18 PM
E36blownpast E36blownpast is offline
Mein Auto: E36 325i
Same problem with my 94 325i soldered the comfort relay like I'v been told and only the sunroof worked...I'v also heard theirs other relays behind the glove box but I'm not sure
