E36 (1991 - 1999)
Old 12-07-2012, 08:06 PM
OV2310's Avatar
OV2310 OV2310 is offline
Mein Auto: 97 M3
Code P0301 Cylinder 1 Misfire
My car lost power while I was on the freeway and my check engine light came on. I don't have any rips on my boot and my MAF and ICV are clean. I had cats welded in about weeks and I've been trying to pass smog. I'm barely failing my NOx at 15 mph.
I've replaced:
Spark plugs
oil/filter
anti-freeze
fan clutch
cleaned MAF and ICV
catalytic converter
Please help me with my P0301 code and if the code has anything to do with my smog.
Old 12-07-2012, 08:16 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
does it run poorly??
did you try moving the coil to another cylinder to see if it follows??
df
Old 12-07-2012, 08:20 PM
dc_wright's Avatar
bimmerfest Supporting Member
P0301 is cylinder 1 misfire. Check the plug boot and coil pack for cylinder 1. Also check the ground connection at the front end of the valve cover.
Yes, a consistent mis-fire will cause you to fail smog.
Old 12-07-2012, 08:22 PM
OV2310's Avatar
Mein Auto: 97 M3
Yes and I will give that a try tomorrow since im going to work in a little.
Good idea!!
Sent from my SAMSUNG-SGH-I717 using Bimmer App
Old 12-07-2012, 08:34 PM
OV2310's Avatar
Mein Auto: 97 M3
Alright thanks.
I'll check back tomorrow.
Old 12-08-2012, 03:13 PM
OV2310's Avatar
Mein Auto: 97 M3
I switched the coil/cylinder 1 with cylinder 2 today and erased my CEL. I've been driving it and haven't had a CEL. I moved my car from a cold start for about 45 mins to the street and when I came back to drive it, I found a puddle of coolant under my car.
So I filled it up again and let it sit for another 45 mins but nothing leaked. I also checked around the radiator and didnt find anything.
I'm thinking I might of messed up the water pump from when I replaced the fan clutch a couple of days ago.
Old 12-09-2012, 05:55 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Did you use a new gasket for the waterpump?
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 12-09-2012, 08:14 PM
OV2310's Avatar
Mein Auto: 97 M3
I only replaced the fan clutch.
I've been driving for 2 days without any problems or codes. Kind of weird.
Old 12-09-2012, 08:31 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
When that happens to me I just forget about it and accept it as the car just talking to me.
Old 12-10-2012, 08:40 PM
OV2310's Avatar
Mein Auto: 97 M3
Haha nice.
Still haven't taken it to get smogged. I'm a little confused about what to do next.
Old 12-21-2012, 02:26 PM
OV2310's Avatar
Mein Auto: 97 M3
Finally passed smog!
Feels like I won a prize!!!
Looks like one of my new cats were not working correctly and my CEL never came back. I also got a new fuel cap since my old one was leaking air like crazy.
If anyones local to me, go to Blueribbon. They fond the problem. Good service too.
