Is there anyway to replace the Idler Pulley without taking out the radiator fan/shroud out? Apparently you need a special tool to remove it, and I certainly don't have said tool.
Going by :
Dreaming of the ///M. Last edited by bimcwe; 12-10-2012 at 08:00 PM. |
Or, you can make your own or buy the tool for about $3. - How to make your own BMW cooling system overhaul fan clutch nut counterhold tools (1) (2) BMW_Fan_Clutch_Counterhold_Tool_CAD_Template_to_sc ale.pdf
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-10-2012 at 09:06 PM. Reason: Added CAD template |
No, there is not enough room to do it with the fan on. You probably don't need the tool to remove the fan, I removed mine using hammer method. Secure the wrench on the fan nut and sharply hit with a hammer, this should loosen it.
Dreaming of the ///M. |
Isn't the thread on this nut reverse? So caution not to hammer the nut on tighter?
I'm probably going to buy the tool. The sound coming from my car due to this is ridiculous and a little embarrassing lol. I just haven't had time to fix it Q_Q. Anyone willing to link me to the correct tool?.. there seem to be quite a few variations.
I just made mine out of a scrap price of aluminum about 1/8" think took 20mins and was free
Sent from my PantechP9060 using Bimmer App
That has got to be the worst DIY video ever. Who shot that thing... Moe, Larry and Curly?
Umm... er ... it was in the thread I pointed you to?
There are MANY (many many many many) ways to hold the water pump and loosen the fan clutch nut (all explained in gory detail if you just click on the link I provided). No sense repeating it here. Me? I just use the right tool - and it comes off in a split second. Here's a picture of my M54, with the proper tools lined up. But, trust me, if I give you a link, it has the answer you seek. Did you even click on the link we already provided you which contains the answer to all your questions?
Dreaming of the ///M. Last edited by bimcwe; 12-11-2012 at 09:59 AM. |
Not sure how I double posted but it happened.
After managing to force my 1-1/4 inch open end on that fan nut, and doing my best to hold it all from turning, I just paid the $50 for the tools and keep them in my toolbox. Well worth it if you're going to be doing DIY's along the way.
--------------------- Light a man a fire and he'll stay warm for a day. Set a man on fire and he'll be warm the rest of his life. |
I bit the bullet and bought a set off ebay. And they do see the light of day every now and then. I've even loaned them out to others in the area. It's not a one time use kind of deal.
Yes, it is reverse, so clockwise will loosen it.
So
![]() And I should be all set?
Dreaming of the ///M. Last edited by bimcwe; 12-11-2012 at 08:30 PM. |
Correct!
Anything I can do to alleviate the exceptionally loud squealing that only seems to let up a bit after she heats up... the tool won't come in for about 4 days.
Back to square one. Because if you could reach the pulley, you could get a squirt of oil in there to quiet it down short term. But have to get the bolt out to do that.
We go to a ton of trouble to create links to the answer of every question ever asked on the E39 forum (many of which are the same for the E46), that sometimes I get short with people who don't click on the links. Good luck - you have MANY options, as evidenced in that thread.
If you have a ratcheting box end wrench it is possible to change the pulley without taking the fan out.
This is the one I have:http://buy1.snapon.com/catalog/item....e=snapon-store
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 |
I had to replace mine as well, and i did it without removing the fan shroud. If you put a wrench on the fan bolt and turn it a little, it will release the tension on the belt enough to pull it out. Im not gonna lie, it was a pain in the butt unscrewing the bolt that way, but it only took an hour and a half start to finish. Good luck im sure with the tool you ordered it will be a piece of cake.
I bought my car new the month after your 330 build date and decided to spend the extra $7000 for the 330 because I knew it was worth the extra thrill. No regrets! |
