E36 (1991 - 1999)
Old 12-07-2012, 06:51 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
i have not installed the refresh kit yet.. its on its way.. and i dont know that it is failing but i know that the vibration cannot be doin any good at all for it
That makes more sense. Before I thought that your water pump was new. As said above just add the fan and fan clutch to your order and your car will be fix. One last thing ZeGerman knows what he is talking about I would heed his warning.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 12-07-2012, 07:38 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
yeah the vibrating is an indication that your fan unbalanced cause its missing a a blade or 2.
driving like that will kill you water pump for sure
-Dino
Old 12-11-2012, 01:18 PM
Kaptainkid1 Kaptainkid1 is offline
Mein Auto: 328i convertible
Sounds like your fan clutch is failing and you should replace the fan blades and clutch.
This sounds like a recipe to the exploding e36 fan.
I've choose do a FDM and replacement electric fan / switch is costly mod but good for people that have poor maintenance.
So far 2 years no problems.
Old 12-11-2012, 03:08 PM
dc_wright's Avatar
When you do the FDM you are deleting a relatively reliable belt driven fan that was designed to run all the time and do the primary cooling and substituting the auxiliary fan that was designed to run only as a back up to the belt driven fan or when your AC is on and you are stationary. Your aux fan is likely as old as your car and once it becomes the primary cooling source it dies pretty quickly and the cheapest replacement is about $200 bucks.
