Discussion pertaining to the flagship BMW here. |
760Li V12 exhaust mod experiment
so I tried the whole Mufflerman mod on my 760Li. I know I mentioned it before but I have an update.
here's the complete story http://mwsmith.smugmug.com/Cars/760L...04237969_iiNZ5 The end result is: the pipe I attached so I could use the stock valve and have a quiet idle, was way too restrictive to let the V12 sound come out, with all the proper overtones of a V12. It sounded like a buzzy V8, both in and out of the car. I mean, the valve "worked" and all, but the sound was like an anemic 745. I do not have a video of this. I just decided, "heck with it" and removed the pipe, since it was mounted with a flange I welded on, and drove around like that. now THAT sounds like a V12. Here's a little sample movie with my wife trying to blip the throttle. Put headphones on to hear the full effect. now THAT sound is more like the V12 wail I was going for. I decided to just try driving around with a 2.5" gaping huge hole in my exhaust. You know what? not that loud at idle, and very nice note when accelerating, both in and out of the car. It does get a strange wooshing noise going up high, probably the gasses banging into the rear bumper as they exit. So yes, it's totally ghetto and needs to be tamed down a bit. I still want to incorporate a valve for idle to really quiet it down and direct it out the back with some 2.5" to 3" pipe. The stock valve is too small to do what I want. After much searching, found this: http://www.apexi-usa.com/products/?id=5326 which are meant to be actuated in the cockpit with a cable. It will not take much to weld on the vacuum actuator from the stock valve and have a valve big enough to pass those V12 gasses (and overtones!) |
btw: what I mean is: a 745 that not in good shape, not that all 745s always "sound" anemic in general. I like the sound of 745s, I wish 760s had an aggressive sound when accelerating as well.
as far as the exhaust goes and that whistle, you might want to get an elbow or something for it since there's a good chance it'll slowly melt the rear bumper and deform it.
IMO you should cut the whole exhaust system off and get a magnaflow muffler as the stock exhaust (quiet muffler) and then get the apexi valve and attach an elbow to it and call it a day. Better exhaust flow, better sound and it'll look good from underneath too. EDIT: just listened to the video, sounds good but it lacks that growl that a V12 gives off. I wonder what straight pipes would sound like on the 760... hmmm I might have to disconnect my exhaust one day... Last edited by csmeance; 03-04-2011 at 07:36 PM. |
Wow, I only thought there was only 1 cat cast into the header and that's it along with a ton of resonators. I contacted Hamann a while ago for the sports headers w/o cats and they never responded. I might call up an authorized dealer and see what they can do. The design makes it look very restrictive as it is:
It's bad enough without also trying to support the OBD2 stuff.
Those are no cats!!!!!
![]() #1 is the "Center muffler" I thought it was a large cat (from underneath, it looks like one). hmmmmmmmmmm..... I am thinking they are chambered/baffled. ie: steel walls impeding gas flow and directing flow around them. More like the rear mufflers. and the pre-cats are the only cats on it. So it has 1 cat and 3 mufflers per "side" so to speak. here's the "front" mufflers as they call them. They are likely perf tube resonators, like a magnaflow or even an old cherry bomb.
In all honesty, I would think that a new set of headers and some pipes straight back (duals that merge into 1 right before the axle) and then into a dual muffler setup (performance and quiet tip) would make probably add a decent amount of power. All of those mufflers probably restrict the flow of all the exhaust gases a great deal and the same with those headers! I'd think something that was equal length tubes into a solid collector for all 6 would work well enough. I wonder if there are any headers for the 328 that we could modify for our cars...
headers
While the are not pretty, I have a bit of experience prototyping and using headers for a couple cars: the non-turbo Z32 300zx. Which these headers basically did almost nothing to add power. In fact, having full-length headers (about 36" long) reduced torque in a few areas. The problem is, not being able to tune them and try several sets until you get the right length and size. These were then cut off, and I had some flanges made so I could try to add different ends to the headers to try to find the right combo. I never finished the job. It was a waste of time. ![]() the GM 3400 DOHC motor transplanted in a lowly Pontiac Fiero. What a tight fit. and these were equal length, and full-length as well. http://fiero*****fiero-tdc/members/mw...ers/index.html [IMG]http://fiero*****fiero-tdc/members/mws/headers/Rbank1.jpg[/IMG] these headers worked better because I also changed the intake radically and adjusted the cams. I achieved a 38% gain in power, which was really good for a NA motor. http://fiero*****fiero-tdc/members/mws/intake/index.html [IMG]http://fiero*****fiero-tdc/members/mws/intake/240hp.JPG[/IMG] It would be difficult to be able to tune headers to know what to do with VANOS and Valvetronic. That said, some sort of short, tubular manifold would be better than the log. So that "would" alleviate some restriction. I think the only mufflers restricting anything are the "Center" and rear mufflers. The front mufflers are just perf-tube and replacing them with straight pipes would just add more ratty noise, from my experience. |
SOLD 2003 745Li Authentic AC Schnitzer Aero Kit inc Front, Side Skirts, Rear, Mirrors, Roof and Trunk Spoilers Gloss Black Grille and Window Trim KW Variant 3 Coilovers 22" Interad Turismo Forged 3-piece wheels |
http://www.energeticforum.com/renewa...n-foulers.html people do this so the car will not see the full emissions and thus think the cat is working as it should. |
I've got a video of my 760 stock exhaust:
I wanted to put cutouts on my car after cats but i realised there is no any space for that, so i decidet to put it between middle and rear muffler and i was very impressed i could make so easy modification but the problem is i cant hear a lot of difference between my stock exhaust and exhaust modification like mws did. Or its just video quality? |
Rostman, how does it sound when you drive?
BTW: in order to get rid of the whoosing air sound I welded up a flange and a 3" dump-pipe with a turn-down that goes under the car to the rear bumper. Still makes the V12 wail, but no flute-like air whooshing noise. Do you hear that more high-pitched engine wail like I am describing, while driving? If so...I am pretty convinced you could simply cut the rear mufflers off completely (replace them with a nice 3.5" dump pipe) and get basically the same sound as you and I have now. The rear mufflers and the second to last muffler system, the big one that looks like a shielded pillow, I believe, do the most muffling. If I were to mod the system further I would want to see what it sounds like with just straight pipes from the round, can-shaped resonators, all the way to the bumper. Leave the resonators on, but remove everything behind them and replace with pipe. If I then got too much bass, I would add a large chambered muffler like a Flowmaster or a Spintech. I know, sounds like I just committed blashpame, but they do a good job of preserving mid-range sound, and removing pulsing, thumping bass. No one needs to know it's there.
Whats happend if remove middle muffler? I'm looking for something not so loud with V12 tones
Done. But still its not so loud, I do not fill a lot of difference when the muffler was there
![]() I think in a few weeks i will take off mid muffler. ![]()
Your pipe is too small
my experiments showed that the open pipe needs to be 3" or so, to get any sound out of it. |
