E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
#26
Would you recommend any good one for this 95 325i, less price but reliable. |
#27
Just an FYI guys, earlier E36s don't have a central locking button, its controlled by the drivers door pin. Press the lock pin down and everything locks, pull the handle and everything unlocks.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
#28
Thank you; nice information
#29
Also please one more question that if I can install it myself or I should/have to go to experts to install it.
#30
Here is my trunk lock picture. It is very rusted, I can turn the key and sound is heared seems that it tries to release the lock and then pressing inside it opens the trunk but I have to strugle many many times. I am able to open the trunk today and took out the battery but again it was stuck. So after unlocking I did not close it. I will fix it first now.
Here are pictures please guide me how to fix it. Question: Is it proper way to turn the key then push the lock inside to open it? Last edited by kmrpt1; 12-11-2012 at 03:49 PM. |
#31
You have to turn the key to unlock it then depress the button the key goes in, to open it. So it worked correctly it sounds like.
"It doesn't do any good for me to know more than you if you aren't going to listen to me" |
#32
--- But still the trunk will not open at first shot. So I am thinking to open the trunk lock and properly clean it and may be I would found some thing is broken inside. I am looking some guidance and steps how to open trunk lock and service it properly. |
#33
You insert the key and turn it 1/4 turn clockwise to unlock. Then you can remove the key (or leave it in, doesn't matter either way) and depress the button to open the trunk. To lock it you put in the key and turn it 1.4 turn counter clockwise.
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
#34
The key does not have to be in the lock cylinder to open the trunk, though. Just unlock it, remove the key, and then push the lock cylinder in and open the trunk.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
#35
and also once I pushed in the cylinder, it does not come out automatically, I have to turn the key inside and pull it with the key. Now to fix it; I will put more WD-40 and graphite lubrication spray in it and then I will try to open the lock assembly completely and will clean it thoroughly, may be I find some thing broken inside. Is that a good idea? Also can I get some manual describing with the help of pictures how to open the trunk lock assembly? One more question, which lubricant and/or greese should I use to clean and lubricant properly the trunk lock and assembly? Thanks. Last edited by kmrpt1; 12-12-2012 at 08:00 AM. |
#36
Don't use WD-40. That stuff eats grease. (And many other lubricants).
#37
Thanks. |
#38
Just use the graphite lubricant spray. Best one I've used for locks and it was originally recommended to me by Ken. And it seems that old people know stuff.
As for a diy, i just did a quick google search to come up with this: http://tinyurl.com/bnco7pn
#39
http://www.canadiantire.ca/AST/brows....jsp?locale=en Also please see the picture. Only concern with this spray I had that it spilled down to the paint and looks like it did not stay there. Should I use other one which comes like paste so that it will stay there? Thanks again. |
#40
That is exactly the one I have. I bought mine at CT too. Just wipe up the drip.
#41
![]() Here's another good lock lube, for the record.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
#42
Can you guys tell me what are these plastic nails or screws are called (please see the red marks on the trunk ) which hold the trim/cloth of trunk and which tool we should use it to open and what is the proper procedure to open it and close it back.
Currently it is very nice and fit in my car so after opening and fixing the trunk lock, I want to put it back as it is. So can you please tell me its names, and tools to open it and do I need new one to fix it properly or same one I can use again? Note: This is not my car picture but I just posted to put marks related to my question. |
#43
I believe that these are what you mean. You can just ask at a $tealership for the trunk carpet clips.
http://www.pelicanparts.com/cgi-bin/...eries%20all%20 Parts like that are usually really cheap even at the $tealership.
#44
I opened the trunk carpet to see the lock and it looks ok and functioning properly.It is closing and opening properly after lubrication. Thanks guys for the the help.
Now only issue is that when I press the lock it is not coming out. After putting graphite spray and oil, it is coming half now. Should I open it to see may be it is stucking some where or just keep lubricating? |
#46
I think may be I am wrong, the push lock has alignment issue. It has more gap from one side and no gap on opposite side. Please see picture.
To align it do I need to open those four screws or I can allign it from back side (inside the trunk.)? |
#47
I'd say it's still a matter of insufficient lubrication. My trunk buttons have the "more gap/less gap" situation on both cars and both work flawlessly.
#48
I opened from front and back, and lubricated. It is coming half way out on pushing inside but it is ok for now I think. Either the spring has not much power or I need to replace it with new. Any way at least I can open/close trunk now and can use it. Now next is hood. It is not closing. It seems that lock either is missing? When I see the hole, it looks it is empty. Is that ok?
Please see the picture? |
#49
Now I want to fix my hood. It is not closing. I am wondering if I can check its lock is working or not? Both holes are seem to be empty? Is it correct? Last edited by kmrpt1; 12-15-2012 at 08:32 PM. |
#50
For the hood latches again it's just a case of lubrication.
