Old 12-11-2012, 05:37 PM
kharripe kharripe is offline
Kerry
Mein Auto: 2012 BMW X5
How do I hook up Cleansweep to L7
Just got the whole cleansweep setup and I have know idea how to install it, I know the wires connect to the speakers but where would it go through the l7 or what? Please help
2007 BMW 750i Sport SOLD
2007 Infiniti M45 Sport SOLD
2006 Chevy Express G3500 SOLD
2012 Mercedes C300 Sport
2012 BMW X5 Sport Activity
Old 12-11-2012, 09:38 PM
Kerry
BUMP!!
Old 12-11-2012, 10:10 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
What is cleansweep, educate me
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 12-11-2012, 10:27 PM
Kerry
http://www.jlaudio.ca/car-audio-oem-...em-integration
Old 12-12-2012, 12:19 AM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Not only is the one review on their website calling it a very sad product but it doesn't seem to be fiber optic compatable.. it may not need to be, it may connect to the outputs of the L7 I dont know, but I don't think anyone here will know, may want to call JL..
Old 12-12-2012, 07:48 AM
Kerry
Keif calling you out bro, help me out lol
Old 12-12-2012, 07:57 AM
mrbmwx5 mrbmwx5 is offline
Banned
Mein Auto: 06 750Li
This should help...
http://www.m5board.com/vbulletin/blogs/douglasabaker/
http://forums.bimmerforums.com/forum...d.php?t=799835
Old 12-12-2012, 11:06 AM
BuiltnBoostedZ BuiltnBoostedZ is offline
Mein Auto: X3 xDrive35i & 350Z TT
Cleansweep taps into the speaker wires to get a signal...cleans it up and then spits it out via RCAs. I've used this product before many times in the past. Great if you want to keep the factory head unit and add amps/subs/etc. If adding subs, tap into the rear most speakers so you aren't running wire all the way down the car.
350Z TT - SOLD!
2004 745Li - SOLD
2011 X3 xDrive35i
Old 12-12-2012, 05:04 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
You need to tap in full range speakers. Basically your L7 amp stays in place an you tap into the speaker wires going from the logic 7 amp. Are you adding a sub?
Old 12-12-2012, 06:09 PM
Db750's Avatar
Db750 Db750 is offline
David
Mein Auto: M3 - M6 - 911
If you just want to hook up subs why not just buy the L7 harness sold by member Technic? I think it's around $100.
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
Old 12-12-2012, 06:18 PM
VA BOI 750i VA BOI 750i is offline
Mein Auto: 2012 750LI
Maybe you should ask PAPER. He has one in his car. At least he did in his pictures.
It's not SWAG! Real men have CLASS!
Old 12-12-2012, 07:45 PM
DFEL750I's Avatar
Mein Auto: 750I
Clean sweep is suppose to "clean up" the audio signal and give you better sound quality.
Old 12-12-2012, 09:04 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
In all honesty, return it.
The Cleansweep is barely 4 channel audio with FL, FR, RL & RR signals. There is no dedicated subwoofer channels, tweeter channels, etc. You are going to need external crossovers to split up the signal and get the sound right. Adding more insult to injury, the factory system has WAY to many inputs for the cleansweep to accept! To fix this you need to spend more money on a JL summer (http://www.jlaudio.ca/cl-ssi-car-aud...egration-98112) to add up the signals.
IMO, do it the right way and get an Rocksford Fosgate 3.Sixty.3. It has 8 channel inputs so you can do the FL Tweeter and Mid, FR Tweeter and Mid, the subs and then the RL & RR mids. Then you go through PROPER tuning software with a mic and other stuff and tune it to YOUR LIKING.
OR you can get the JBL MS-8 which you hook up the same way as the 3.sixty.3 and setup a mic and set it to auto config. The HILARIOUS part is that it uses Logic 7 processing
Old 12-12-2012, 09:08 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
Is your factory l7 amp working correctly?
Old 12-18-2012, 07:44 AM
Kerry
I have technics harness already,
Old 12-18-2012, 08:04 AM
dsaautocustomz's Avatar
dsaautocustomz dsaautocustomz is offline
Donny A
Mein Auto: 14 Sierra, 13 Denali XL
If you have technics harness i dont think you need the cleansweep
Sent from my DROID RAZR using Bimmer App
Old 12-18-2012, 12:05 PM
csmeance's Avatar
Mein Auto: 760Li
In any case the Cleansweep is going to be useless since it needs the WHOLE 20hz to 20KHz Signal to "retune" it and make it flat, but the problem with that is that you need all the adapters, and then you'll have ****ty outputs since it only provides outputs for door speakers and not subs.
Return the cleansweep and just use the tecknic harness.
Old 12-18-2012, 12:14 PM
Donny A
Old 01-07-2013, 08:27 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
the clean sweep will come into play if you are totally rewiring the audio system. The clean sweep goes after the ask unit and by passes the Logic 7 amp. you will install new amps as the amplification for the car, new power amps.
