E36 (1991 - 1999)
Old 05-06-2012, 04:32 PM
alecpierre alecpierre is offline
Mein Auto: 323i 99'
Weird Window Problems 325is 94
First off this is my first post, great site and community.
Having said that, it is not a motor problem for both windows.. Im 100 percent sure of this. Its seem to be a weird electrical problem. The driver window only seem to work when the car thinks its open! I say this because the only time the windows work is when the lights that turn on automatically when you open the car door stays on. I Make sure all the doors and trunk are closed but the light never turns off, and when this happens the driver side window works fine(passenger side doesnt even give the clicking sound when you press the window buttons but thats another days work). But when the lights turn off, like they are supposed to, maybe couple hours later, windows no longer work. Me and my uncle, who is a pretty good mechanic are scratching our heads on this and would like some insight, thanks.
I also should add that my power locks arnt working so this may be the culprit
Old 05-06-2012, 08:25 PM
hornhospital's Avatar
D'oh, You Kids!
Two words: Comfort relay
(it's in the dash)
Welcome to the fest!
Quotes to live by:
Old 06-24-2012, 01:59 PM
Mein Auto: 323i 99'
Okay I replaced the relay and still having my problems. My power locks are working again but the windows still wont work. Im 100 percent positive nothing is wrong with the motors. Any help?
Old 06-26-2012, 10:19 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Replaced the relay..(?)
Replaced with new? Replaced with used?
Did you check all of the relays?
They are under the steering wheel, behind the glovebox, under the hood, and under the dead pedal.
Did you check the fuses? Are the the correct fuses?
Is the wiring creased out in the door jamb?
Has the wiring been tampered with?
Has this car been submarined? or subject to water damage? (flood)
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 09-17-2012, 02:04 AM
kenrik kenrik is offline
Mein Auto: BMW 325i
All my fuses and relay are under the hood..in the motorroom...on the left side..are there any more relays...I have a 325i, -94....and my windows don't work...? Checked if the any power to the switches but no...
Old 10-04-2012, 09:56 AM
Mein Auto: BMW
Originally Posted by kenrik View Post
all my fuses and relay are under the hood..in the motorroom...
On the left side..are there any more relays...i have a 325i, -94....and my windows don't work...? Checked if the any power to the switches but no...
yes.
Originally Posted by bmw-mania View Post
replaced the relay..(?)
replaced with new? Replaced with used?
they are under the steering wheel, behind the glovebox, under the hood, and under the dead pedal.
did you check the fuses? Are the the correct fuses?
Has this car been submarined? Or subject to water damage? (flood)
Old 12-10-2012, 05:58 PM
E36blownpast E36blownpast is offline
Mein Auto: E36 325i
I have the same year car and I have the same issue but I went under and fixed the comfort relay....the sunroof works now but the others do not so I then replaced it entirely and nothing changed so now Im scratching my head are thier any other relays or fuses that I don't know about or what I checkd if the motors are good...the only other thing I can think about is the driver window switch is broken but I doubt that one switch is going to be shorting my whole window system out...oh besides the sunroof lol
Old 12-10-2012, 08:14 PM
Mein Auto: BMW
Remove fuse for windows and replace.
You need to re-sync your windows..
Usually happens when the battery is disconnected, or window motors disconnected..
Old 12-11-2012, 11:29 AM
Mein Auto: E36 325i
Which fuse is the window fuse I only have a window lift fuse and a sunroof fuse and both are good
Old 12-11-2012, 12:02 PM
Mein Auto: BMW
I didnt say they were bad..
Remove fuses ...turn key on.. try window switches.. turn key off.. replace fuses..
turn car on.. open and close doors... try window switches..
Old 12-11-2012, 01:15 PM
Mein Auto: E36 325i
Tried this and still nothing I'm wondering if it's grounding out somewhere but this is starting to get annoying.....but I'v heard that theirs other comfort relays behind the glove box is this true? If so does anyone have a wiring diagram so that I can try and track the source of this
Old 12-11-2012, 02:19 PM
Mein Auto: BMW
but I've heard that theirs other comfort relays behind the glove box is this true?
Yes.
Read post #6
Have you tried RE-SYNC-ing the windows?
Disconnecting the Battery for 30 minutes to reset everything?
Old 12-11-2012, 02:21 PM
Mein Auto: BMW
And they worked BEFORE .. correct?
Old 12-11-2012, 08:04 PM
Mein Auto: E36 325i
I do not know
I bought the car for $900, it was running on 4 cylinders, no windows at all worked, oil leak, no ceiling upholstery, and left brake light was out. I'v replaced all 6 spark plugs and wires, 2 coils, I resoldered the blown point on the comfort relay that is under the driver side but this only solved the sunroof problem, so i replaced it and nothing new happeded except i spent more money, oil pan gasket, ceiling, and new bulb and bulb holder because when the bulb blew it melted the holder.
Yes.
Read post #6
Wher are the locations of them other than behind the glove box, how do I resync my windows and I have not tryed disconnecting the battery for any longer than 4 minutes while replacing the coils. Also I do not believe thier was any flooding to it I live in Wisconsin so I'm sure the winters werent so nice to her but I doubt thier has ever been any flood damage to it
Old 12-11-2012, 08:54 PM
Mein Auto: BMW
I do not know
You dont know..?
You havent done any other troubleshooting?
This is where you would offer up information that is pertinent, like:
"when i push on the window switch I hear a click in the door/dash/bonnet"
You're going to keep spending money, your time, your energy, without result if you
keep working the way you're going..
You should pick up a service manual... it will save you lots of time, and frustration.
Where are the locations of them other than behind the glove box?
You're talking about the relays.. right?
You really need to READ the information that is presented to you.
For the third time...
how do I resync my windows?
A quick SEARCH for "window sync" turns up many results..
Roll the windows all the way down.. then hold the button down all the way for 20 seconds.
(dont go breaking switches pushing hard on them)
Then you roll the window all the way up and hold the button down for 20 seconds.
Try disconnecting the Battery for 30 minutes.
Old 12-12-2012, 09:40 PM
Mein Auto: E36 325i
Disconnected the battery for not only 30 minutes....but 45, when I click any button it makes NO noise anywhere except for the tick of the button it's self, but I still went ahead to try the re sync....held it down and nothing happened but continued to hold for 20 seconds let go and did the same for up, still nothing, so then re disconnected the battery for yet another 30 min. Tomaro I will be going through the dashboard looking for this stupid relay but I have a feeling that's all it need...and a good greasing
Old 12-13-2012, 09:46 AM
Mein Auto: BMW
First things first..
- Check all FUSES - pull out, inspect, clean connection and replace as necesssary DOUBLE CHECK PROPER AMPERAGE FUSE IN PROPER LOCATION
- Check all RELAYS - pull out, inspect, clean connection and replace as necesssary... ALL of them, including the ones INSIDE the car hidden in the dash.
(you can test them with a 9volt battery to see if they *click*)
- Clean all electrical connections - CLEAN, loob it up, and re-connect.
If still no luck..
remove door panels
disconnect BOTH plugs on the motor in the doors
turn on car.. push window switches
turn off car.. clean/lube/reconnect plugs to window motors
last, but not least.. double check the actual switches themselves.
pics of behind glovebox:
http://www.bimmerfest.com/forums/sho...d.php?t=606368
Old 05-05-2013, 05:36 AM
Mein Auto: BMW 325i
I had almost the same problem....but I changed the comfortrelay that's fitted under the panel below the stearingwheel...have you tried that...? Here in Spain I payed 24 for it...but if that will sort your problem..I can't tell...I'm not a mechanic...but got it solved by Bimmer members help...
Cheers
kenrik
Old 05-07-2013, 06:19 AM
Mpower1028 Mpower1028 is offline
Mein Auto: 98 328is with m3 swap
The owners manual or Haynes manual tells you everything
