Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 11-27-2012, 10:28 AM
Wolfman64 Wolfman64 is online now
Mein Auto: BMW 750li, Mercedes SL600
Originally Posted by FalconFlyer View Post
umm... hate to say it but they are too dim..... I could not tell you even had AE's.... they look no different than other LED AE lights...
Tend to agree. I was hoping that they be brighter with 40Watt output. Others are as low a 6Watt.
Unless of course it's 40Watts combined for both sides...
Old 12-05-2012, 08:42 AM
745ion22s 745ion22s is offline
Mein Auto: F01
The Stahl LED replacements I'm using may not perfectly recreate the look of the current model year but in my opinion look 100 times better than the ugly yellow look the halogen bulbs gave. I've used a number of different halogen bulbs and none gave a good white output. Some even gave off codes. I also tried a different vendor's LED and saw that the center ring was way brighter than the outer. With these I get good output out of both AE rings.
Personally, I'm not willing to run wires and drill holes to accommodate HIDs.
Old 12-05-2012, 11:32 AM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
our MTEC angel eyes produces over 900 Lumens
Old 12-05-2012, 04:49 PM
ChrisF02's Avatar
ChrisF02 ChrisF02 is online now
MCHTSCHNL
Mein Auto: 2013 750i
Originally Posted by 745ion22s View Post
Is this enough sunlight?
1st pic, AE's are off
2nd AE's are on
Wow those are really dim, this is why E92Lighting didn't want to post any pictures of his own products, they're vaporware!
2013 BMW 750i - Coded, Executive, Lighting, Cold Weather, M Sport, M 303 Wheels, 5% Tint, Conti DWS Tires, 3M Bra, Front DE Plate.
Old 12-05-2012, 04:58 PM
FULL 6 FULL 6 is offline
Mein Auto: 2012 750i MSport
E92 lighting, why do you always get so much bad press on this forum your posts are crazy you post you post you post you post and none of your **** works - then claim to have the best stuffs and it CODES!!!!SHOW US REAL F01 EXAMPLES of your product with testimony and review instead of bumping everyday and boasting.
Old 12-05-2012, 07:25 PM
f01driver f01driver is online now
Mein Auto: 750i, S5
Lol, I agree; if you have a product which is supposedly superior you would post tons of pictures, the issue is there is no "silver bullet" when it comes to aftermarket angle eyes.
2011 750i
Old 12-07-2012, 10:47 AM
MOPAULY's Avatar
MOPAULY MOPAULY is online now
Mein Auto: Many things
Originally Posted by full 6 View Post
e92 lighting, why do you always get so much bad press on this forum your posts are crazy you post you post you post you post and none of your **** works - then claim to have the best stuffs and it codes!!!!show us real f01 examples of your product with testimony and review instead of bumping everyday and boasting.
amen
2007 Kawasaki Ninja ZX-14
2006 BMW 750i
1972 Dodge Charger
1968 Dodge Charger
1967 Austin Healey Sprite
Old 12-08-2012, 09:11 PM
stephenaron stephenaron is offline
Mein Auto: 2011 750i
Strahl
Took out my alpines and replaced with Strahls kit. Though not as blindingly bright as the alpines, the strahls still look good. I bought the strahl kit to see if the reason my outer rings dimmed was due to something in the alpine kit/parts. As you can see in my pic with the strahls, the outer rings are still bad. Thinking the alpine lights damaged the rings. Anyone?
2011 750i with 19" M Package
AlpineMSS Angel Eyes 8000k upgrade.
Bridgestone SO-4 tires.
Old 12-12-2012, 08:05 AM
Mein Auto: F01
Sorry to hear that happened with your outer rings. I run the Strahls and my outter rings light up fine. Glad I never went with using the HID
Old 12-12-2012, 01:05 PM
jprescott jprescott is offline
Mein Auto: 740Li
I hate to jump in here so late but I installed the following back in June :
http://www.bimmerfest.com/forums/sho...hlight=umnitza
Yes they were cheap and stupid easy to install. Yes I did have a code issue that was easily rectified with an extra resistor. No I do not have any dimming after 6 months. They are not the brightest bulbs in the pack but they sure look good
2011 740Li
Old 12-12-2012, 07:57 PM
Mein Auto: F01
I had that brand prior to the Strahls. Problem with that brand was the outer ring was still quite dim.
Old 12-12-2012, 11:22 PM
ChrisF02's Avatar
MCHTSCHNL
Could it be the mixing back and forth with AEs?
Mine have worked flawless *knock on wood*
