Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 12-12-2012, 12:35 AM
TerrorActivity TerrorActivity is offline
Mein Auto: E30
Exclamation Which to go for V8 V10 V12
Hello there gents I have an E30 and I want an advice on which to go for V8 V10 V12 on an E30 and how hard can it be installing the V10 and V12 thanks in advance
Old 12-12-2012, 01:12 AM
WickedFast.Inc WickedFast.Inc is offline
Go Fast or Go Home
Mein Auto: 1989 325I
Why so much power in a small car you know twisting frames seen't hard
Wicked Fast Entertainment
Old 12-12-2012, 01:22 AM
StRaNgEdAyS StRaNgEdAyS is offline
Registered Lunatic
Mein Auto: E39 535i
With appropriate bracing... why not?
Sent from my HTC Desire using Bimmer App
Absinthe makes the tart grow fonder
Mein Auto: E30
Because I want to build a fast car to race drift and to get maximum high speed on high way since we dont have speed limits here and if I get a ticket for drifting or doing something its only 15 or 30$ so why not building a beast , and if not what can I do to an M20B25 ?
Old 12-12-2012, 01:49 AM
Go Fast or Go Home
Just seems like an awful lot of power for something so small i mean v8 i could go for v10 is pushing it a v12 is overboard but thats just my opinion and i can say by the look of the engine bay i can't help but think the car will need a bit of mod to fit the v10/12
Old 12-12-2012, 02:03 AM
Mein Auto: E30
Yea V8 no problem my friend fit one in finished it in few days, how far can I push the M20B25 u have any ideas? some easy tuning with basic tools i ve seen alot of people do it and made the car crazy
Old 12-12-2012, 03:19 AM
Go Fast or Go Home
They make turbo kits for the m20 they run about 1000 plus forced induction 12 point modifiable ecu with self maf so you can remove the maf from the car performance chip to add 15 tq 30 hp
Old 12-12-2012, 06:26 PM
downhiller's Avatar
livin large
http://www.s14.net/forums/showthread...-S62-M5-engine
last i read was the engine was being built for 1400hp.
engine wise, you can fit the m72, however it doesnt put down alot of power for a v12. the v8 would be better or just over build a s52. like the ics killer bee
Old 12-12-2012, 07:53 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
you won't twist the chassis. the e30 chassis can handle ALOT of power before it twists.
if money wasnt an option, i'd swap in an m5/6 v10 and boost it. plan on about $6000 to have it installed, $10k for just the motor, $2k for the transmission and if you want to boost it, add another $15,000 to $25,000.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 12-13-2012, 12:45 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
TerrorActivity, I think ask yourself 3 questions:
1) How much experience in swaps do I have or can I get somebody good to do that for me
2) How much money am I prepared to spend
3) In what condition is the rest of the vehicle & what will I have to do/spend before it can handle the envisaged power
Personally I would stick with a 6 cylinder that uses a similar crank-trigger arangent as the M20 motor and then use the Unichip to control the stock ECU, MAF and Vanos
Don't take life too seriously; no one gets out alive !
Old 12-13-2012, 12:48 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Truth.
The V8, V10 and V12 all require extensive rewiring of the entire body of the car, they aren't plug and play in any sence of the word.
as for which one. thats a stupid question. first you need to ask your self these questions:
1/ Do i want a engine that is cool, not necessarily the best or cheapest, or do i want all out power, or do i want the easiest swap
2/ Does it have to be a BMW motor
3/ Is my budget $2k, $20k or $200k?
of the ones you said, the M60 is the easiest, M70 would be middle, and the V10 would be BY FAR the hardest to do. but bear in mind when i say the M60 is the easiest, its still a LOT more work in itself than an M50/M52 conversion, and close on half of people will balls even that up the first time they do it. Bolting any of these engines in is the easy part. making them run is the hard part.
Yes i do know what im talking about by the way. I have an M70 E34. There would be at least 200-300 cut and resoldered wires in that car and i love it to bits, but its to say i have a V12, not because i want all out power. For the V12, it is actually quite a low performance motor, reletive to other V8s and V12s of the day. probably why the 850Ci was never really that popular. I could have dropped an S54 in there for a similar amount of money, which would have been quicker, but i didnt want another I6
Old 12-13-2012, 05:50 PM
pjoa09 pjoa09 is offline
Mein Auto: 318i E30 1992 (M40)
I think you should be going for just a turbo or stroker.
V8s and V12s are stupid heavy.
Use the E30s agility to your advantage!
Get something else for high speed cornering.
There are plenty of options, sport bikes, supras, muscle cars, E36s, and etc.
I think 300-400 whp should be the maximum, you should be more concerned about making sure you don't have too much weight over the front struts.
700 whp should just be no-tractionville.
Old 12-13-2012, 06:03 PM
downhiller's Avatar
livin large
small, light, and stupid powerful with reliability until you blow out the exhaust manifold gaskets
Old 12-14-2012, 05:17 AM
BMW lebanon BMW lebanon is offline
///323i
Mein Auto: 1985 323i racing
most tuned e30s here have m20 2.5/2.7 or m30 3.5 engine. you dont need a bigger engine. you can modify the chip, crank, headers, air filter, transmission..... and you will have a bomb
Old 12-14-2012, 07:51 PM
downhiller's Avatar
livin large
you forgot the more common one m50.
Old 12-14-2012, 08:36 PM
power isn't twist. Torque is what you want, and E30s do that. have seen subframes ripped out one more than a few occasions, once with my own eyes.
this. The E30 is a light and nimble chassis, it doesnt need a lot of power as it can hold the speed it does have through corners well, assuming the suspension is up to scratch. that should ALWAYs be the first place to upgrade anyways.
Old 12-15-2012, 09:18 PM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
UN: Terror Activity
not sure if srs....
Old 12-16-2012, 11:52 PM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: 1987 325i, 378K
Exactly right. Huge electrical and engineering challenges is such a project, and probably a lifetime of bugs. Then the purt near inevitable situations where you suddenly realize that you can't service (fill in blank) or remove this or that part w/o pulling the engine.
Better off to buy an M5 with V10 or maybe a Mercedes 6000. Major auto manufacturers do a better job at engineering these things than we average civilians.
cmac
As I know more of mankind I expect less of them, and am ready now to call a man a good man upon easier terms than I was formerly. - Samuel Johnson
Old 12-19-2012, 08:27 PM
BMWFatherFigure's Avatar
Old School
With the number of bugs this type of swap could bring, you would end up being your gay auto electrician's sex slave.
Current:
Previous:
Old 12-19-2012, 09:01 PM
i cannot access the spark plugs by the firewall, can access the other 10 though. have to remove engine or intake etc
Old 12-19-2012, 11:01 PM
fcsteve's Avatar
610EUROs
i've always used the term "power" as a general statement not associated directly to either torque or horsepower, more as a combination of the two.
i've never seen a single one, ever. not even from 700+hp e30's with drag slicks romping off the line at the start of the 1/4 mile.
Old 12-19-2012, 11:26 PM
i dont think they will have stock rear suspension somehow
Old 12-19-2012, 11:44 PM
fcsteve's Avatar
610EUROs
last time i checked, Donovan did for a long time.
Old 12-19-2012, 11:47 PM
fcsteve's Avatar
610EUROs
axles and driveshafts go before you'll even begin to bend/break a frame.
Old 12-20-2012, 12:16 AM
Mein Auto: E30
Wow guys thanks a lot thats some good info, well my friend installed V8 4.4 no mods in his E30 and Beat off 2012 charger SRT8 5.7L, anyways I think Im going for m30 3.5L, again thank you guys for taking time to reply almost everyone advised me to go for the 4.4L or 3.5L
