Old 12-11-2012, 07:54 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
OBD2 Scanner....?!?
@ 1/15 the price of Bavarian Technic, I got doubts - anyone use THIS?
Old 12-11-2012, 08:30 PM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
yeah, i have one. only reads out basic OBDII data and resets SES faults. thats it. cannot communicate with any other module in the car, cannot read shadow faults, activations, etc.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 12-11-2012, 08:44 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
On that topic: my understanding is that the Bav Tech only works on the older e90s. Is there anything equivalent for the last few years?
BMW CCA Member
Old 12-11-2012, 08:55 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
FYI coding setup and DIS57
http://www.e90post.com/forums/forumdisplay.php?f=368
also
bmwcoders.com
The above two links are places to find a total diag setup cheap with some hacking.
The elm bluetooth module is only good for generic codes the common obd ones that must
be standardized. What it is good for is using the torque app.
Old 12-11-2012, 09:17 PM
You must mean N54 vs N55 - does work on mine. And, gotta say, pretty good juju....
Old 12-12-2012, 06:56 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
I talked to the guys at BavTech and they said that it would work on my 2007 335i (N54) and my 2013 X5 (N55) equally well.
Old 12-13-2012, 04:20 AM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Carefully
Will the BavTech really pull codes other OBD readers cannot? My ELM 237/ Torque say it can pull historic codes.
$735 is a bit steep for me to justify on an in warranty car - will go another route if replace the battery. Wish the dealer would sort it out without multiple visits; they've lost the sale of a 2013 Wagon to me by not sorting this seemingly trivial issue out.
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 12-13-2012, 06:07 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
At that price, the Bluetooth OBD modules are Chinese knockoffs that don't reliably communicate at full speed. The "real" ones run around $80 - $100.
FWIW, I have one of the knockoffs and use it with Torque. I've pulled codes on my wife's Subaru with it, and used it to overlay the ECU data with camera video on last summer's Mt. Washington ride:
It works. Nothing to write home about, but it works. Cute toy for $30 if you have an Android phone.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 12-13-2012, 07:38 AM
Got mine when my ride was new, just to satisfy curiosity. Note the price - still a lump, gotta be motivated.
Old 12-13-2012, 09:45 AM
MP3_E46's Avatar
Code/wrench Monkey
$24 ELM let me know the coolant temp moves a good bit in the first mile so was well worth it. Needle does not move until pulling into work...
Already have a USB OBDII scanner I paid ~$400 for in 2004... not rushing to spend real money on one again unless absolutely necessary. I think every semi-enthusiast should buy the $23 one and order the BavTech or play with the hacky options if something looks really broken.. or they are really curious too
Also until proved otherwise I am still sure the $23 one pulls all codes even it cannot decode all of them. We won't know what some mean like the errors I had a few weeks ago but I'd wager it pulls them
Old 12-13-2012, 11:10 AM
NickDanger NickDanger is offline
Mein Auto: 335i
I have the PLX Kiwi bluetooth. I'm not sure how deep into the code world it can go, but I have been happy with this device.
http://www.plxdevices.com/
Old 12-13-2012, 11:23 AM
Also until proved otherwise I am still sure the $23 one pulls all codes. We won't know what some mean like the errors I had a few weeks ago but I'd wager it pulls them
I saw the depth and breadth o'info BT delivers. Of course, their web site's needed to retrieve all. Amazing what can be seen & modified, many makes & models. Like the up-to-date info base.
Old 12-13-2012, 11:33 AM
Wihelm G Wihelm G is offline
California Über Alles
Mein Auto: 328CiC and 328iT
Not sure what you mean. The website is only needed to check for software updates and download them to your laptop/desktop/tablet.
Old 12-13-2012, 06:02 PM
Exactly - with all translation tables for mfg specific codes & features; I/O
Old 12-30-2012, 10:01 AM
jvest2000 jvest2000 is offline
Mein Auto: 2006 X3
Just wanted to weigh in on a code reader solution I got that seems to work great on my 2004 Tundra and also on my wife's 2006 BMW X3. It's a Bluetooth OBDII connector that you pair up to and Android powered smart phone. Here is a little write up/review I did for it and for the Torque Pro app, hope it helps some folks, reading these codes and being able to get information from your ECU is awesome! I was able to read some codes on the X3 (the seemingly common P0174 and P0171 Too Lean Bank 1 and 2 codes) and clear them which turned off the SES light.
ELM327 Bluetooth OBDII Reader and Torque Android App Review
Old 12-30-2012, 10:29 AM
Wow. Kindly list the proprietary BMW codes it reads.
Old 05-29-2013, 02:04 PM
fradzz fradzz is offline
OBD2 Scanner....?!?
Purchased the basic Bavarian scanner a couple of month ago. It reads codes, including a code where is no problem.
It will reset An
Old 05-29-2013, 02:13 PM
OBD2 Scanner....?!?
It will reset An
It will not reset any codes!
None!
Bavarian Technic says it because the system is lacking an update. I'm only 5000 miles out of Warrenty and had a complete service 6000 miles ago. Seems like if the system needed updates it would have been done. But I don't know.
I have the scanner that only allows three VINs to be scanned ever, so I hate to hook up to someone's car just to see if the scanner works.
Anyone have any feedback or insight on this? Thanks
Old 05-29-2013, 08:03 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
None!
What code r u getting, I have no issues resetting codes with mine, but recently was unable to reset service reminders, one for brake fluid change, called them and the current version has a bug and they sent me the previous version and all went back to working.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 05-29-2013, 10:49 PM
Yeah its showing a brake code which I've done the brakes and sensor, but can't turn off the code. It shows a LvDs which is a Idrive nav commo problem (but everything works fine) and a code for adaptive headlight left side LL motor and Lr motor which is correct. The L light took on water and shorted something out maybe. It's a step motor replacement probably.
I can fix things but I really want to be able to turn off the codes. Of course if something is going to break it happens right after warranty goes out.
I'll move the question around a bit here maybe someone can steer me towards a solution.
BT says software needs updating on 06 330. I've got a great BMW service writer who's also a Master tech. I think he'll know about a software update. Just haven't had time to go my the BMW store.
And they told me about the previous version but it didn't help.
