Old 12-13-2012, 08:27 AM
sle39lvr sle39lvr is offline
Mein Auto: 08 E90
RFT vs Non-RFT Air Pressure Question
The Basic question I want to ask is:
Should PSI be higher on NON RFT's compared to similar spec RFT's?
I got 18" staggered wheels on my e90 and I recently put on Michelin Pilot Super Sports.
User manual states I should run 36psi front/42psi back for extra load. I ran this on my old NITTO NON RFT Tires (Softer tire from what I experienced) and the fronts had shoulders wear off noting that they were under inflated.
I wonder 36/42 is for RFT's and if I should run higher for these NON RFT Michelin PSS's.
Old 12-13-2012, 08:40 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Street, naw.
I get best results at BMW owner's manual recommended psi.
Old 12-13-2012, 09:42 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
+1. What CWB says for same size tires.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 12-13-2012, 10:02 AM
tturedraider's Avatar
Freedom isn't free!!
What they said. The type of tire does not affect the recommended air pressure. btw - there's virtually no way that 36/42 is going to result in an under inflated situation.
www.bmwcca.org
Old 12-13-2012, 10:21 AM
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Mein Auto: 2008 335Ci
I actually DROPPED my pressure by 2 PSI front and rear. I noticed my Michies were not using the outsides of the tread.
Softer ride with no noticable change in handling.
No matter how fast I go, there's always someone slower in front of me.
You can lead a horse to water, but you can't make him jet ski.
'08 335 E92, M-Sport option, 6 sp auto w/paddle shift
JB4 PNP G5 ISO upgrade, 3" charge pipe w/dual CM5 nozzles, meth injection, Oil Catch Can. Zero to 'OH GOD!' in a scream.
CCA Member 109065
CQ ... CQ...Kilo Charlie 3 Bravo Whiskey Zulu calling CQ
Old 12-13-2012, 09:24 PM
pointandgo's Avatar
pointandgo pointandgo is offline
Mein Auto: '13 F10 535i (loaner)
Short answer: RFs and non-RF tire pressures are guided by the same tire/load/pressure standards according to U.S. standards: The U.S. Tire and Rim Association. There is NO difference. Size-for-size, RFs and non-RFs carry the same load and have the same PSI requirements.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
'71 AMC Javelin (4-Spd Stick on the floor)
'67 Pontiac Firebird 'cabrio' (1st car - "the leaker")
Member: BMW CCA
Old 12-13-2012, 11:17 PM
Mein Auto: 08 E90
That clears things up! Thank you.
