Old 12-13-2012, 08:53 PM
BMSJ3 BMSJ3 is offline
Mein Auto: BMW 3 series
Recommendation on snow chains
I haven't use snow chains before & will be driving soon to some locations where snow chains may become mandatory. I have16" wheels with regular Bridgestone Turanzas' RFTs on my 2009 E90 . Would appreciate your recommendation on where I could get the appropriate snow chains & if there are concerns/ issues to be kept in mind.
Old 12-13-2012, 09:09 PM
beden1's Avatar
beden1 beden1 is offline
Mein Auto: '11 E93 335is & '08 535xi
Where will you be driving your BMW to need snow chains? I have not seen them in use since I was in 2nd grade living in Upstate NY. You have to check your state laws to see if they are legal to use, and when you can use them. I think most states that do allow their use, limit you to driving on snow covered roads.
If not mounted properly, they will damage your wheel wells.
Modern snow tires have become so good that snow chains are not needed in most cases, especially if you have AWD, IMO. (at least where it would be practical to take a 3 Series BMW because of the relatively low front end clearence).
Current Stablemates:
'12 Porsche 911 GTS Cabriolet (MT); '11 BMW E93 335is (DCT); '08 BMW E60 535xi
Favorite Cars Gone But Not Forgotten:
'09 Corvette ZO6; '04 MB S600; '01 BMW 740iL; '01 Corvette; '90 Nissan 300ZX 2+2; '89 Jeep Grand Wagoneer; '79 BMW 320i; '79 MB 300D; '71 Pontiac Firebird Formula 400; '67 MG Midget
Old 12-13-2012, 09:59 PM
andrew b's Avatar
andrew b andrew b is offline
flâneur en cabriolet
Mein Auto: 2007 E93 N54
I'm not in a location where I need them, but I've always thought the fabric "snow chains" looked interesting.
http://www.ecstuning.com/News/ISSE/
Old 12-13-2012, 10:33 PM
floydarogers's Avatar
Pedant and Curmudgeon
You actually want to buy cables, not chains. They should fit fine on 16" wheels. You need to practice putting them on to ensure you will be able to get them tight enough not to rub on the wheel wells.
I would strongly advise NOT to get any "fabric" or "Spyder" thingys: in most cases they are not classified as Snow Chains and therefore not legal to use when the Chain Sign is up (in WA, OR CA at least.)
Tirerack probably sells them; discount tire, Les Schwab, Big O, etc. Pep Boys, Kelley's and other auto part stores. Some of them will allow you to return them after the season if not used. Buy a blanket (or tarp), cloth/rubberized gloves and anything else you think you need to put them on in the snow. A shovel is quite useful, too.
Old 12-14-2012, 06:30 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
I recommend Thule CB-12's. It's what we carry with us when we're going where we might need them.
http://www.amazon.com/Thule-Quality-...pr_product_top
Old 12-14-2012, 12:33 PM
hoopla hoopla is offline
Mein Auto: 05 X3 Manual Transmission
SCC Super Z6
I used SCC Super Z6 cable chains on my X3. They seemed to work quite well in the bare pavement-ice-snow mixed conditions that we'd get around the ski areas here. Never had any problems with them damaging the wheels. The instructions were terrible, but once I figured it out, they were fairly easy.
The fabric ones look interesting. There are some very useful reviews for another brand of them on Amazon; I don't think they would work for me (too much bare pavement in chain-required areas).
If you live somewhere with consistent sub 40f degree temps, then getting winter tires makes a lot of sense. Then you never need to worry about chains, and general performance (assuming you get good ones) should be similar to all-season tires.
Old 12-14-2012, 12:47 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Agree with the first sentence. Agree with the second half of the second sentence only if you're talking about high-performance snow tires, but they're not that great in a situation where you would otherwise be considering using chains. If you're on "true" snow/ice tires, you're bad weather performance is greatly enhanced and I'd agree with the first half of the second sentence, but dry and wet driving really do suffer.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 12-20-2012, 07:38 PM
Thank you all for your suggestions.This was very helpful in the processs. I'm going with cables as recommended. Hopefully, I wont need to use them :}
Old 12-21-2012, 11:38 AM
Here's some info I'm sure you'll find useful. If anybody knows about snow getting around in snow it's Oregon and Washington.
