The X5 SAV Forum
Old 12-13-2012, 02:07 PM
kash_BMW kash_BMW is offline
Mein Auto: E53
Help! Water leak rear left side
Hi All, new poster and was wondering if anyone has had my problem.
I have pretty much ruled out a door vapor seal problem
A week ago after a few days of rain noticed the rear right side passenger floor was wet.
I poured a bottle of water this afternoon and pretty much ruled out a door vapor seal problem and I think my problem is from my door/door seals
It just rained so I went to check on my car and the pictures are attached from what I found
The seal on the body of the car is wet between the white lines, its not wet on the other side of the car and there are a few drops of water on my seat.
What is causing this problem? The seals on the body or door? any ideas would be appreciated
ID:	353130   Click image for larger version
ID:	353131   Click image for larger version
Old 12-13-2012, 05:45 PM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
How did you rule out the vapor seal? Did you pull the cover and inspect it?
Old 12-14-2012, 07:05 AM
Mein Auto: E53
I poured water and it drained properly, and the water on the seat leads me to believe its dripping from another area
Old 12-14-2012, 08:34 AM
I would recommend removing the inside door panel and inspecting the barrier along with how well it's sealing around the edge. I had a water leaking problem too and it ended up being the moisture barrier. There was a small tear which I assume resulted from previous work (I suspect window regulator replacement). I sealed the barrier and ensured the seal around the barrier was good and the issue disappeared.
The door panel is not difficult to remove and took me at most 30 minutes...and that was because I was reading an DIY on how to remove it. Most any DIY on replacing the window regulators will include instructions for removing the trim panel.
Old 12-22-2012, 05:36 AM
Mein Auto: E53
you were right. it was the vapor seal. My mechanic who only deals with BMW's did not believe it he claimed that its just for sounds proofing. He just heated it up and said we'll put silicone later after the rainy season, I'm just gonna DIY and get the required stuff from the states next week
Old 12-22-2012, 01:49 PM
Glad to hear you found the problem. Even better is it's an easy fix
