E36 (1991 - 1999)
Old 12-15-2012, 09:56 PM
Hatterer4's Avatar
Hatterer4 Hatterer4 is offline
Mein Auto: 1993 BMW 318is
Clutch
Ok. So my 93 bmw 318is have 89530 on it. Just replaced the clutch at 89460. Before I replaced and after I replaced the clutch I've had the same issue. The clutch engages and disengages quite high. When the clutch engages it engages just a little higher than when it releases(pushing in). What could this be? The disc was fine and didn't need to be replaced.
Old 12-15-2012, 10:02 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: 1995 318is
So the clutch disc was fine? What exactly did you replace?
-CJ
Old 12-15-2012, 10:10 PM
Hatterer4's Avatar
Yea disk was fine. We just got new pilot bearings throw out bearing and pressure plate?
Old 12-15-2012, 10:15 PM
Hatterer4's Avatar
This is what came in the kit.
Old 12-15-2012, 10:45 PM
cj.surr's Avatar
some kid
I'm confused, so the clutch disc was NOT replaced?
-CJ
Old 12-16-2012, 12:02 AM
Hatterer4's Avatar
What's in the picture was replaced. maybe the disc was replaced. It to late for me to comprehend myself. Sorry
Old 12-16-2012, 12:28 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
What you pictured was (l to r) the pressure plate, two pilot bearings (you only need one), two alignment tools (again, you only need one), a throwout bearing, and on the right, a clutch disk.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 12-16-2012, 12:33 AM
Hatterer4's Avatar
They sent two and we used both tools. And yes then we did replace clutch disc
Old 12-16-2012, 12:34 AM
Hatterer4's Avatar
And ideas why it's such a high engagement point?
Old 12-16-2012, 08:43 AM
D'oh, You kids!
Possibly you have the wrong throwout bearing. They vary in thickness between M and non-M.
How did you use both alignment tools? You can only put one in there, and should only NEED to use one of the correct size and length.
Quotes to live by:
BMW-CCA #441426
Old 12-16-2012, 10:09 AM
Hatterer4's Avatar
It's not the m clutch kit. And we used one pilot bearing. We used the one that fit the input shaft. We did it right. I think it might just be something to get used to. This is what happened when we took out the trow out bearing. So I think the way the clutch was when the trow out earring was like this is gonna be something to get used to
Old 12-16-2012, 10:10 AM
Hatterer4's Avatar
As you can see two balls were jamme together and wouldn't move
Old 12-16-2012, 10:11 AM
D'oh, You kids!
This is what I was questioning, not about the pilot bearing. I assumed they sent two pilot bearings because there are different-size input shafts.
Quotes to live by:
BMW-CCA #441426
Old 12-16-2012, 10:12 AM
Hatterer4's Avatar
Correct. They sent two ad we used the one that fit
Old 12-16-2012, 10:13 AM
Hatterer4's Avatar
No we used one tool. Haha sorry my bad
Old 12-16-2012, 10:15 AM
D'oh, You kids!
The pilot alignment tools I've used had a stepped pilot bearing portion so it would fit either bearing. One tool fit either setup. Oh, well, you got an extra of each!
And that old throwout bearing?
Quotes to live by:
BMW-CCA #441426
Old 12-16-2012, 10:23 AM
Hatterer4's Avatar
Nice! Well I applaud LUK clutch for the kit. The exact same clutch was in it too. So it was like taking old one out and getting it cleaned and fixed. Haha but I know the throw out bearing was sketchy
