Old 12-17-2012, 12:53 AM
maxim1975 maxim1975 is offline
Mein Auto: BMW 645ci
FSC to CCC
hi
I'm looking for help with typing the code FSC to CCC by Tool32.
i greet
Old 12-17-2012, 10:36 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by maxim1975 View Post
hi
i greet
You are using Tool32, but what exactly are you trying to do with the FCS codes in your CCC?
What do you mean, "typing the code"?
Old 12-18-2012, 05:46 AM
hi
CCC damaged - exchange, the lack of voice control
I greet
Old 12-18-2012, 06:26 AM
hi
I greet
So you have a new FSC Code for Voice Recognition that matches your Vehicle and CCC VIN?
Old 12-22-2012, 03:41 PM
any info appreciated
Old 12-22-2012, 04:31 PM
I PM'd you a ton of information...and based on that, what is still unclear?
Old 12-23-2012, 02:00 AM
thank you very much the problem as I have already written argument?
Old 12-23-2012, 08:36 AM
As I already explained privately:
1) VIN B293747 needs to match CCC and the FSC Code, and the Car itself. Without a 3-Way match, it won't work.
2) There are VERY FEW people that know how to use Tool32 to Import and Activate FSC Codes. I am NOT one of them.
I do know that with 00SWT.prg, these are the jobs, but I do not know the arguments.
FREISCHALTCODE_PRUEFEN FSC check
FREISCHALTCODE_LAENGE_LESEN FSC long read
FREISCHALTCODE_SCHREIBEN FSC write you can use the 64bit FSC long word from the .FSC with this one.
I think also for FREISCHALTCODE_SCHREIBEN, first you have to do an authentication somehow with jobs "authentifizierung_zufallszahl_lesen" and "authentifizierung_starten".
3) Other people use a program called FSTool (Freischalt-Tool), not to be confused with FSCTools, which is an entirely different program that does not do do Import and Activation. You will likely never get your hands on FSTool (Freischalt-Tool), as the few people who have it, will NOT share it.
4) The FSC B293747.ZIP contains no actual FSC Code. The B293747_00020001.der file is only a certificate for the FSC Code, which you do not need. The FSC Code file name would be B293747_00020001.FSC. I think the B293747_00020001.xml file is the ****** FSC Code embedded in a XML File. Maybe this can be converted to the .FSC file, but I do not know how.
The other option is to use ISAT/P. Have you considered that?
Old 12-28-2012, 02:58 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
If his OP vehicle is 2007 and below he needs the CD that has FSC codes for CCC and code with PROGMAN not with ISTA will be the prefer method[specially it is used].
Old 03-15-2013, 11:27 AM
Ysseydk Ysseydk is offline
Mein Auto: E39
Hi
I've got the FSTOOL 2 - but it's with BMW TEST Certificates and cannot be used for anything...
But is someone knows someone that has a WORKING FSTOOL 2 - I'm interested
Rgds
Jesper
Old 03-16-2013, 08:05 AM
Originally Posted by Ysseydk View Post
Hi
Rgds
Jesper
PM sent.
Old 04-30-2013, 11:55 AM
bimmerquest bimmerquest is offline
Mein Auto: BMW
Originally Posted by shawnsheridan View Post
PM sent.
Hi I'm looking fstools 2, please PM me. Many thanks.
Old 04-30-2013, 12:46 PM
FSTool is near impossible to get.
I would PM Ysseydk, as he announced he has this program.
Are you trying to generate FSC Codes, or import and activate FSC Codes, and for what chassis?
Old 04-30-2013, 01:03 PM
Mein Auto: BMW
I would like to replace the CIC on e70, so I have to put FSC code in the new cic.
Old 04-30-2013, 01:13 PM
Ok. I can't really help you with that.
There exists another program though that is easier to find that is developed by Bimmer Retrofit called "CIC Special Service Utility", that supposedly works just as well. Try searching for this one too.
Old 04-30-2013, 01:41 PM
Mein Auto: BMW
I have BMW CIC Special Utility 1.0.4352, it does not work, I can only read FSC.
Old 04-30-2013, 01:53 PM
There is a "cracked" version that supposedly works.
Old 04-30-2013, 02:00 PM
Mein Auto: BMW
You can find out where to download it?
Old 04-30-2013, 02:36 PM
Mein Auto: BMW
This is not a original installer, this is a working version? Thank you, I will try.
Old 05-05-2013, 11:59 PM
karl-heinz karl-heinz is offline
Mein Auto: E92 335i
Yesterday I read out the stored FSC Codes in cic with "CIC Special Utility 1.0.4352"
I saved them as files and compared the 9c FSC with the one I have from Dealer.
comparing the saved FSC with "CIC Special Utility" to the original from Dealer, I saw that the saved one is really short and completely Different.
Don't know if importing would work.
What is the difference by the "cracked" version, and can anyone share it for testing?
Old 05-06-2013, 10:31 AM
Mein Auto: BMW
Hi Shawn. Are there any news about fstool2 or cracked CIC Special Utility 1.0.4352? I have not found anything.
Old 05-06-2013, 11:38 AM
Sorry, but I do not have any. The Exx Tools are of no use to me. I only work with Fxx Chassis, and E-Sys works fine for FSC Code Importing and Activating.
You can always just use an ISTA/P VM for both Exx and Fxx FSC Code Importing and Activating though, so I do not see why these old programs are sought after.
Old 06-23-2013, 03:11 AM
silvano silvano is offline
Mein Auto: E61
Hello, i have an e61 lci with ccc, is it possible activate svs without the dealer code?
Old 06-26-2013, 02:22 AM
Mein Auto: E61
resolved
Old 09-08-2013, 12:22 PM
script0r script0r is offline
Mein Auto: 520d
any way to convert cert to fsc for nve?
