Old 12-18-2012, 05:55 PM
FatGuyOnEbay FatGuyOnEbay is offline
Mein Auto: 2011 E90 335i
Engine emergency
I was installing Lux H8 V3 bulbs into my car and while i was finishing the installation I dropped the light compartment cover into the engine bay. I have searched where I thought it had fallen but I can not find it. So the question is, what and how can i remove the plastic skid plate on the bottom to get it back, should I just order a new one, and will it be save to drive with the cap missing roaming on the bottom of the car?
ID:	353750   Click image for larger version
ID:	353751   Click image for larger version
Old 12-18-2012, 06:25 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Take out the screws holding the bottom cover on. Its very light & easy to remove/install. Might give you a good chance of recovering the part. Don't think I would drive around with a piece of plastic in contact with all that hot metal.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 12-18-2012, 06:28 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
The under body cover is held on by a bunch of 8mm screws, about 22-24 IIRC. A couple of the screws are actually on the side of the wheel well housing and may not be readily apparent.
You'll have to put the car up on jacks (or on a lift if you're lucky!). Use a power screwdriver or a drill bit adapter in an electric drill to make it a lot easier to unscrew/rescrew them. You may be able to start at the front and remove enough screws to pull the cover down and hopefully the light cover will slide down the cover to the front.
Good luck!
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 12-19-2012, 02:23 AM
THANK YOU for the replies. I took your guy's advice by unscrewing the skid plate and it worked. Luckily for me the cap was right near one of the cracks and i only had to remove a couple screws to fit my hand in. I didn't have a jack or lift so I had to crawl under the car haha but I am glad it's over. I'll post pics after i finish everything I'm doing. Thank you again for the help and suggestions.
Old 12-19-2012, 03:08 AM
Banned
Mein Auto: 2007-335 HTC
I just got my LUX bulbs in on Monday, and they totally transform the look, You will definately like them
Hondo
Old 12-19-2012, 10:11 PM
Yea they were a pain to install. You need small hands to be able to get in there comfortably. It took longer than i expected cus of the light cap but i love em so far. Already got a compliment and they've been installed less than 24hrs.
Old 12-20-2012, 06:23 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
So, you are slender? I'd like a pic o'that!
In fact I challenge anyone; everyone to post a pic of a live person having crawled under a E9x & in process o'removing the shield.
Scratch that. I demand a YouTube.
Name:	Ricky Ricardo [a].jpg
Old 12-21-2012, 12:43 PM
HAHA yea i'm slender but i was halfway under the car, just enough to get behind the wheel.
