Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 12-19-2012, 09:11 AM
Bimmerkid325i Bimmerkid325i is offline
Mein Auto: 1991 BMW 325i E30
Carpet removal instructions.
I'm getting water into the cab somehow and it has soaked my carpets, under the passenger seat and passenger rear foot well, driver and passenger front foot wells and a small amount on the drivers rear foot well. Basically I need help removing the carpet. My basic idea is to remove seats, center console, and plastic around the shifter. Any advice would be greatly appreciated! Thanks
Old 12-19-2012, 12:47 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
yeah thats about it, and rear seat to get the little piece out. I also made sure to have a razor knife to make things a little easier around the center console. My floor and firewall had a bunch of little holes. My front winsheild was also leaking at the bottom of the trim. I made sure to weld in new metal and undercoat the interior floor and underneath, kept my padding out, and re-installed my carpet. Lighter, louder, and less comfort, but no leaks and no ponds on the floor board.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap
http://www.bimmerfest.com/forums/sho...36#post7573736
M20B27 for sale in Cincinnati
Old 12-19-2012, 08:22 PM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
Door opening trims have to come off as well. (The ones at the bottom)
Current:
Previous:
Old 12-21-2012, 07:45 AM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Glove box and driver knee bolster and both kick panels, remove hood pull, seat belt guides...
And you have to decide if you want to cut around the HVAC or pull the dash and heater core and all.
Old 12-21-2012, 01:10 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
the correct way to remove the carpet is (in addition to the above) you need to remove the heater box as well. however most people will cut around that and leave the carpet under the heaterbox still installed. when you reinstall, the console goes back over the top of the join and noone would ever know.
while the carpet is out, its a great time to waterblast the hell out of it and clean it up a bit and/or dye it
