E46 (1999 - 2006)
Old 11-06-2012, 02:20 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
My GM auto transmission did not like Dexron VI
This was my third drain and fill. The first one was done with original ATF - Texaco ETL 8072B, second and third ones with Castrol Dex 6. I went with Dex 6 because that's what BMW now recommends for GM hydromatic transmissions.
The result is not so good. The car now is sluggish, with slow, soft, long shifts. It feels like something is holding it back, as if climbing up the hill. No slipping , but does not feel right at all. Not good.
The level is fine, I'm an expert at doing this by now having done it 3 times.
I'm planning to drain and fill again with different ATF.
Just a warning - be careful what you put in your AT.
Old 11-06-2012, 03:23 PM
OfTheLost's Avatar
OfTheLost OfTheLost is online now
Mein Auto: 2000 328i
Alex-
I have a tranny filter and gasket sitting in my trunk pretty much for the very reason that i cannot decide on which fluid to put in my GM transmission. There are so many different opinions out there and its very difficult to come to a decision. Do you know yet what fluid you plan on switching to? Or have you heard any positive results from other people with the GM tranny and the fluid theyve gone with? Any info would be greatly appreciated.
Old 11-06-2012, 05:30 PM
CRJ900 CRJ900 is offline
70 428 SCJ, 04 325xi
Mein Auto: 2004 325xi
Actual GM Dexron 6 changed at 110000 miles. Current mileage 149000. No problems whatsoever. You probably have other issues with your tranny that a fluid change will not rectify
Old 11-06-2012, 07:07 PM
QAfred QAfred is offline
Mein Auto: 323i, 330ci, R1200C
I doubt that is your transmission causing those symtoms SL. I believe you have a MAF or Throttle body or something else going on there. Dexron six is just another hydraulic fluid that meets previous spec. Worked fine on my daughters 2004 325ci.
However, did you ever do the memory reset? I read in this forum that you can turn the key on, engine off, depress gas pedal to the floor for 30 seconds and that resets the computer. So it doesn't drive like the person who was in it previously etc. I know that was probably you but would not hurt to try it.
I tried this on my wife's 323i and it seemed to get snappier afterward...i.e. slightly different shift points? not sure.
Old 11-06-2012, 09:02 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Dexron VI claims to be backward-compatible with all previous versions....maybe the current "mix" that`s in the trans is having a weird effect....each one has a different coefficient of friction, which could be causing your problem.
The road goes ever onward....
(R.I.P. Jever)
Old 11-06-2012, 09:20 PM
Do not know yet guys...
A couple of things. I did reset the transmission adaptations with INPA and that actually might have caused a slightly negative versus positive result. After 122K the valve body and other hardware is not the same as new, so who knows.
I've spent some time today doing diagnostics in INPA. Everything looks normal. All the solenoids activated normally, wires checked OK, pressure controllers fine.
I was afraid my torque converter was acting up, but driving with INPA monitoring the torque converter revealed no abnormalities. I mean I could see it turning ON and then OFF, so TCC clutch seems to function normally.
I replaced 5 quarts of Dex VI with Castrol Multi Vehicle ATF (advanced Dex III ATF) to change the viscosity of Dex VI but no change so far...
Will post an update when it happens. I also think that it
might be something different than my transmission, but what a coincidence!
Old 11-06-2012, 09:24 PM
That's what I think too, Bob! Dex VI is 40% thinner than Dex III too, so friction is the word...
Old 11-14-2012, 06:19 PM
jimvideopro jimvideopro is offline
Mein Auto: 2006 330CiC
Nuts, this is not good news. My car has 70k on it and I'm starting to think about a fluid change, but I don't know what to do about the fluid. This is not a job I feel I can tackle myself, so it's going to be a one-time change at an indy shop yet to be determined.
Question: from some searching, it seems that some Dex VI fluids like Valvoline are full synthetic, but Castrol may not be. Could that be the difference? Thoughts?
Old 11-14-2012, 06:25 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
OR, you could just sell the car to me and not have to worry about it. I'll give you $10.
(No Offense - I'm just being a jackass).
Member No. 470379
Old 11-14-2012, 06:38 PM
schnecharl schnecharl is offline
pending
Send a message via ICQ to schnecharl
Mein Auto: bmw
Dexron VI claims to be backward-compatible with all previous versions[img]*****************ca3[/img]
Old 11-14-2012, 06:45 PM
"Claims" being the operative word!
Old 11-14-2012, 07:14 PM
Thankfully, working in corporate America, I have a high tolerance for that
Old 11-28-2012, 03:47 PM
Update. No change. I have replaced ALL Dex 6 with Castrol Import Multi Vehicle ATF. No change. Car still drives like crap. By that I mean a sluggish, non responsive throttle in other words loss of power. Transmission feels like it's shifting OK, nothing abnormal, no hesitation, no shutter, no slipping. I do not know what to do next. Change ATF to another brand? Change filter again? At this point I'm not sure if it's transmission (torque converter) related or not. No codes when scanned with INPA and Pa soft BMW scanner. Nothing. I just do not like to start throwing parts at it. So right now I'm doing nothing. But it's driving me crazy. All I know it all started after I changed the ATF with Castrol Dex6.
Old 11-28-2012, 06:55 PM
newtothebimmer newtothebimmer is offline
Mein Auto: 99 328i Auto
Can you tell me where you bought the oil pan gasket that goes around the top? Mine has 22 holes, and is metal, but for the life of me I cannot find the gasket for the oil pan. Mine broke off while I was doing my ATF change and I as well have put in Castrol import atf. I skipped the gasket part and just hooked everything back up. But I'm not sure if thats a smart idea now.
EDIT: 99 328i auto.
Old 11-29-2012, 02:17 PM
smolck's Avatar
smolck smolck is online now
ROLL TIDE!
Mein Auto: 2004 ZHP Sedan
Drive it like you hate it and add 1/2 qt of B&M trick shift.
Check out my BMWBLOG!
Old 11-29-2012, 06:02 PM
Alex,
Did you check to ensure you did not disconnect or contaminate one of the electrical connectors on the tranny? I know from reading in these forums there is at least one connector, if disconnected, loose, or contaminated will cause limp mode...so it may be possible something like that can cause an issue like you are dealing with? but easy enough to remove connectors, spray with CRC QD contact cleaner and reconnect.
Old 12-21-2012, 07:26 AM
Update. My transmission is back to normal after I drained all of the Castrol fluid and filled it in with German Pentosin ATF1, fully synthetic, golden color ATF. The power is back, shifts great.
Now my transmission is sealed for life. I'm not touching this pos anymore after all that work and waste of money on fluid. I'm glad I found the compatible fluid that restored the normal operation though.
Old 12-21-2012, 08:26 AM
crowz's Avatar
crowz crowz is offline
Mein Auto: 2000 323i, 97 528i
Mine likes the factory fill. Ran into similar problems when I tried redline fluid in it. So it gets texaco when I change it. Cost more but it works flawless.
Old 12-21-2012, 10:35 AM
Bimmer Enthusiast
Did you get the texaco from a dealer or did you get it elsewhere?
Member No. 470379
Old 12-21-2012, 01:30 PM
smolck's Avatar
ROLL TIDE!
Glad to see this situation is finally fixed! Now you see why BMW won't touch the darn things!
Old 06-12-2013, 07:21 AM
kevin5797 kevin5797 is online now
Mein Auto: 2005 325 Ci
Starless- now that you have had Pentosin for a few months- what is the verdict? Any problems?
I'm having similar issues after refilling with Dexron VI
Old 06-12-2013, 08:08 AM
Here is what I think. Many ATFs will be OK in GM transmission. And it's actually normal for a transmission to behave "a little differently" than before after the ATF change, due to different viscosity, friction modifiers, etc. Unfortunately for our GM transmission BMW contracted Texaco to make a custom ETL fluid that is very specific to the transmission. My GM transmission felt the best with that original juice.
Now to answer you question. I like Pentosin better than DEX VI but having said that its still a different feeling from Texaco etl 8072b. Now, transmission is working fine, no slipping or anything but it just still feels "different".
Some other things to consider. I reset my transmission adaptations which might not be the best thing to do after 100k because of the wear of the components and resetting to the original values might not help anything.
Another thing is the car is getting up there in mileage, 130k miles now. I will be doing another round of major maintenance in some 20k. So it can be that what I'm feeling (that lack of responsiveness) is not ATF related at all. We"ll see how it feels after new spark plugs, fuel filter , etc. The MAF is a suspect too. It seems that there is a difference with different air temperature and humidity.
Conclusion: something has been lost since the change of the ATF type, but seems to be within the "normal" range. Could be other things influencing the performance too.
