Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 12-23-2012, 02:28 PM
AWDBoost AWDBoost is offline
Mein Auto: 2008 BMW 550i
Help with Lug Bolt Key
I need a key in order to remove my wheel lugs. I bought the car 3 months ago and there is NOT one on the car. Where can I purchase one of these. The car is a 2008 550i Sport Package
Old 12-23-2012, 04:28 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
those look like spline drive "tuner" lugs. 6 point, fairly common, i do not believe thats an actual "lock'
usually used on rims where there isnt enough space to fit a hex head lug. my winter rims use those lugs.
my guess would be the person who owned it before had a winter wheel set that came with those lugs and used them instead of the bmw lugs-- did you check the trunk/glovebox for something like this:
http://www.amazon.com/POINT-SPLINE-T.../dp/B006UH66R8
you can probably find it locally-- i recommend buying more than one, when used with impact tools, they sometimes split.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 12-23-2012, 04:34 PM
Thanks for your Help. Ive checked everywhere .. I'm also missing the Wallet key adapter but that's another story! That seems to be what i need I will order it right now. If i was to get a flat .. i wouldn't be able to replace the tire.
The car lived in California , then NYC sold on a auction and Now I own it.
