E82 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by either an inline 6 in the 128 or the twin turbo rocket sled 135. |
#76
Cheers Jochen |
#77
Did you ever try that ?
#78
No, I didn´t! Just ignore the error mess!
#79
It seems to be a common problem that may require a new steering column to fix completely. Get your car to the dealer if you've got warranty as soon as possible. If you're lucky they will just have to reset the electronic steering lock. However, if it goes again and again that may require a new steering column.
#80
Hi BMdude816,
If you want to pay for nuts, you can go to a BMW dealer. Or you buy the LuPeDi (Google) interface and install the Ediabas Inpa pack, trying to reset the steering SW (will try myself lateron). Both parts work together if fine you´re following the numerous instructions on the WWW or on Bimmerfest! |
#81
I don't think the car will let you start the engine if your steering wheel is locking. It is the 1st step for the car to verify a legit start.
I got the problem the other day and had to tow the car using wheelies, the car couldn't even go from P to N. I am sweating now since I am not sure how much dealer will charge me on Monday since they are off today - Sunday. Quote:
#82
Steering lock yellow warning, dealer name?
Bchuong58 |
#83
My wife's 2006 330 column locked up in our garage with a ELV fault this weekend. Had it towed to local shop, $1013 for new column installed and $125 for recommended software update. Should be done by end of the day. Indy and tow truck driver both stated they've seen quite a few of these, dealer stated the opposite.
#84
BMW is not straight on this problem.
#85
http://news.cincinnati.com/usatoday/article/1924627
DETROIT (AP) - BMW is recalling almost 570,000 cars in the U.S. and Canada because a battery cable connector can fail and cause the engines to stall. The recall affects the popular 3-Series sedans, wagons, convertibles and coupes from the 2007 through 2011 model years. Also included are 1-Series coupes and convertibles from 2008 through 2012, and the Z4 sports car from 2009 through 2011. The cable connectors and a fuse box terminal in the cars can degrade over time, and that can break the electrical connection between the trunk-mounted battery and the fuse box at the front. If that happens, the cars could lose electrical power, causing the engines to stall unexpectedly, the U.S. National Highway Traffic Safety Administration said in documents posted on its website Saturday. The company says in documents sent to the NHTSA that the problem stems from movement between the battery cable and the fuse box. BMW says it knows of one minor collision in Canada due to the problem, but no injuries. The German automaker says dealers will replace the battery cable connector and secure it for free. It will start notifying owners in March. The 3-Series is BMW's most popular car in the U.S., dominating the small luxury car market. The company sold nearly 100,000 of them in the U.S. last year. The recall affects more than 504,000 cars in the U.S. and another 65,000 in Canada. BMW, Toyota and other automakers have experienced large recalls in recent years because they use common parts on multiple models in order to save money. Owners can call BMW with questions at (800) 525-7417. |
