Old 12-21-2012, 03:21 PM
kjk645 kjk645 is offline
Mein Auto: BMW 645ci 2005 Convertibl
FROM 19" TO 21" Do I need lowered
Hi Guys,
I am going from 19 Elipsoids to 21" 128's on my 05 645. Do I need anything except spacers? Does it NEED to be lowered or do you just slap em on? If I need a wheel alignment do I do it with the new shoes? And lastly, how do I know they are OEM and not knockoffs. Too late to ask now but it would be good to know. Thanks
Old 12-21-2012, 08:41 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Lowering after plus sizing wheels is normally just for looks only. When you lower the sidewall thickness with a lower profile tire the gap between the tire and the fender looks bigger, it's an optical illusion.
You will see "BMW" and a BMW part number cast into the wheels, normally on the back of the wheel, if it's OEM. The Ellipsoids have the number cast on the front under the center cap.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-22-2012, 12:49 AM
thanks Yorgi I knew I could count on you.
Old 12-23-2012, 08:44 PM
OVRTKR OVRTKR is online now
Mein Auto: 650i
21's will most likley fill the extra gap you do not have to lower it and get the wheel alignment done with the new rim and tire set up as per the "knockoff" issue Yorgi is on point as usual..
