Old 12-22-2012, 07:17 PM
kidrock's Avatar
kidrock kidrock is offline
Mein Auto: 2015 BMW 528xi msport
Instrument Cluster Hidden Test Functions
Not sure if this has been posted here before. Just came across this video:
Old 12-24-2012, 09:44 AM
jgscott987 jgscott987 is offline
Mein Auto: 2011 528i
Very cool- thanks for posting!
The last 7 digits of my VIN includes a letter (C123456) Do I count the C as a 3, or do I ignore it?
Old 12-24-2012, 10:26 AM
gsmith999 gsmith999 is offline
Mein Auto: 2012 535i
I believe it's the last 5 digits of your VIN (in your case, with a VIN of "23456" the total would be 20. you add the 2+0 again for a code of "2" (note: it might have been "20" but i think I added the last 2 digits again to come up with a single digit number). Below is another description someone posted months ago. I used it to reset my mileage cal factor from 1000 to 1045 (Car used to over-estimate my mileage by 4.5%). I'm now within .1 mpg of the actual value....
Trip computer true MPG adjustment
Does your trip computer over estimate your true MPG?
If so, I found this piece of information on another forum that could help:
You could if you wanted use the correction factor in the hidden menu to make the quoted MPG the same as the actual MPG.
here's how:
1. Hold down the odometer reset button and turn the ignition on by pushing start/stop button.
2. Release the odometer reset button, and you should see a menu of 4 items on the dashboard. From here on, use the odo-reset button to advance to the next entry through a short press, and to select through a long press.
3. Choose the one that says Unlock through the above, which will take you to a passkey screen. Your passkey is the sum of the last 5 digits of your VIN. Increment the two-digit number until you get to it, and with the long press of the odo button, select it.
4.then scroll down to correction factor and modify it from 1000 to whatever you require
My car claimed more mpg than it was actually delivering by about 6%. I changed the 1000 to 1060 and it now seems about right.
It did take me a few goes at getting it right , but I much prefer seeing the correct MPG displayed.
If your trip computer reads higher than true figures worked out, make the correction over 1,000. If your trip under reads (very rare!!!), make the correction number under 1,000
2012 535i
Space Gray / Black Dakota / Anthracite
Premium - Premium Sound - Tech - Cameras - Active Cruise
Old 01-01-2013, 10:17 AM
Tgrin24 Tgrin24 is offline
Mein Auto: 2012 535 M Sport
Does this fix teh odometer as well, or just the trip? Thanks.
Old 01-04-2013, 08:16 AM
nesterk's Avatar
nesterk nesterk is offline
Mein Auto: 2011 550xi
Just tried (on my Canadian 2011 550xi) - add last 5 digits - works like a charm.
Some nice info to spend time on the long red lights or traffic jams
Old 03-30-2013, 05:20 PM
Sam-F10 Sam-F10 is offline
Mein Auto: F10 550xi
Wow, never knew abt this. Thanks for the video. Very interesting.
2011 BMW 550xi MSport ( Dinan S3 w Exhaust) | DDC | ARS | Black Panel Display | Color HUD | Carbon Black | Cinamon Brown Interior | Rear Video Entertainment
Old 12-27-2015, 10:49 PM
tonys3rious tonys3rious is offline
Mein Auto: BMW 535d Xdrive 2014
Digital Intrument Cluster
Hey guys,
This is really helpful, but unfortunately its not working for me. I have a 535 2013 model which has an upgraded cluster instead of the normal analog i have a Multifunctional digital cluster display. There when I hold the button it gives me all the information but does not allow me to unlock it to get further details about the status of the car. Is there a different procedure I have to go through in order to get to unlock it with the use of VIN?
Old 12-28-2015, 12:48 PM
fmfm fmfm is offline
Mein Auto: 2011 523i
Originally Posted by tonys3rious View Post
Hey guys,
Some models require you add the last 5 digits not 6 to unlock the hidden features
ie if your last 5 digits of VIN is 260251 you enter 8 to unlock
Old 01-23-2016, 08:09 AM
BimmerLover21 BimmerLover21 is offline
Mein Auto: F10 530d xDrive
Returning to older post, I have the same problem, mine F10 530d xDrive (2015) has digital cluster & hidden menu can be accessed by long pressing the odometer reset button without entering any code. Some data are shown in engine speed indicator area, but I think there are much less of them than in analog cluster. I had a E60 530d xDrive and there was much more options there.
Does anybody know whether there is some other datas to be shown after entering the unblocking code. I do not know even where to enter the code in my digital cluster...
Thanks for any ideas....
Old 01-24-2016, 11:06 PM
BimmerLover21,
that is exactly what i meant. In normal analog clusters you get way more information than with the digital one. Unfortunately i still didn't find out how to access more info.
Old 01-25-2016, 12:41 PM
Robert A Robert A is offline
Mein Auto: BMW 535d
Is there any way to recalibrate the speedometer?
Robert A
BMWCCA Member
Current
2014 535d, M Sport, Space Gray/Mocha Nappa
Prior
2007 530i, White/Black, 6MT
2001 530i, Orient Blue/Beige, 5MT
1994 325is, White/Black 5MT
1984 325e, White/Black 5MT
1983 318i, Delphin/Beige 4MT
Old 01-25-2016, 02:03 PM
Carbon Fiver Carbon Fiver is offline
Mein Auto: 2013 535i M-sport
I don't think so. In the coding forum I found that other models have a setting to correct the speedo (which reads 3-5% over by design) but it doesn't apply to the F10. You could use taller tires, like 45-series instead of 40-series, which would correct the speedo but then underreport the odometer and alter the handling.
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, Sport Auto, Driver Assistance Pkg, Premium Pkg, Multi-Contour Seats, Heated Seats, Navigation, H/K stereo. Michelin Pilot Super Sport non-runflats, M5 grille, Painted reflectors from IND.
Old 03-01-2016, 01:19 PM
Sisyphus987C Sisyphus987C is offline
Mein Auto: 535xi
The code for my 2015 535ix was the sum of the last 5 digits of the VIN entered as a two digit number. This appeared to unlock everything shown in the video though I didn't check one by one.
Les
Old 09-28-2016, 07:14 AM
super19021902 super19021902 is offline
Mein Auto: BMW 530d Touring Luxury
BimmerLover21,
I have a 2016 year 530d with multifunction / all digital display. I, too, cannot find where the 'Unlock' menu item is, so I can't enter the "sum of last 5 digits of VIN" and can't see any data on battery voltage.
Did anyone ever know how to access the hidden menus on cars with multifunction display?
Old 09-28-2016, 02:58 PM
just press and hold the reset button it will show the hidden menu in the rpm area without unlock.
and yes i have changed from the standard odo to the 6WB and the hidden menu does not all data like the standard odo such as system voltage and so on.
Old 09-29-2016, 01:01 AM
I have done the "hold reset" thing and it does not show me system voltage. Where do I find these statistics?
Old 09-29-2016, 03:15 PM
if you have 6wa or standard cluster just hold the reset untill the hidden menu appear then go to unlock option then hold to enter the number which the sum of the last 5 or 7 digits of your car VIN
click to go next
hold to enter
Old 09-30-2016, 12:28 AM
click to go next
hold to enter
No, there is no Unlock option with 6WB-Multifunction Display. It is like this video:
So how do I see the system voltage stats?
