Old 12-22-2012, 10:48 AM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
Rear or Top view CAMS while going forward?
Is there a way to turn the top view or rear cam on while going 20mph on a 2013 F10?
Old 12-22-2012, 10:35 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Try Coding PDC module as follows:
D_SCHWELLE_1 = max distance in meters to disable top camera view - Change to Werte = FF
D_SCHWELLE_2 = max distance in meters to disable rear camera view - Change to Werte = FF
V_SCHWELLE_1 = max speed to disable top camera view - Change to Werte = FF
V_SCHWELLE_2 = max speed to disable rear camera view - Change to Werte = FF
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 12-24-2012, 10:28 AM
Thanks, I got it to work.
The issue I had was I had to restart the car for it to take effect and the fact it changed the value to "unknown".
Old 03-08-2013, 04:10 PM
coco135's Avatar
coco135 coco135 is offline
Mein Auto: 2009 750i
By changing those values when in reverse camera start working and screen will not go back to normal mode unless i shut off by pressing the pdc button in the center (arm rest) also when driving and pressing that button nothing happen.
How can i set that the camera screen will automatically close when driving forward but while driving, if i want to view the rear camera (please dont ask why) i could by pressing the pdc button?
Old 03-08-2013, 08:04 PM
razorback razorback is offline
Mein Auto: GT 530d
You can't.
the automatic close is determined by those 4 parameters.
when set to "FF" they won't close automatically because D (Distance) and V (Velocity) are set to infinite.
when set to anything lower they will close automatically according to the set values and you cannot enable them by hitting PDC while driving any faster or after the set Distance respectively.
BMW GT 530d (MY 2013)
Old 03-08-2013, 08:23 PM
coco135's Avatar
Originally Posted by razorback View Post
You can't.
When is the distance starting to be calculated? Can the speed be set to FF and distance to 200 m? If yes then I should be able to turn it on at any speed for 200 m, no?
Old 03-08-2013, 10:48 PM
Mein Auto: GT 530d
this is what you will have to try for yourself, I won't do it for you......
Old 03-08-2013, 11:53 PM
coco135's Avatar
Asking for your opinion since there is a slight chance you have more experience but obviously you are hallucinating
Old 03-09-2013, 12:02 AM
Mein Auto: GT 530d
keep your guns in your holsters :-)))
meaning that you have to try it for yourself says clearly that I haven't tried it yet and not plan to do so.....
Old 03-09-2013, 06:45 AM
captirwin captirwin is offline
Send a message via Skype™ to captirwin
Mein Auto: 2013 X3 35i
Lighten Up
Originally Posted by coco135 View Post
And, who exactly asked that you will do it for me????
LIGHTEN UP.
I'm sure his response was because of the language differance. I bet his English is better then your Austrian.
Old 03-09-2013, 07:46 PM
octopump's Avatar
octopump octopump is offline
Brevity = soul of wit
Mein Auto: F10
I have coded these for the rear cam and it can only be activated while doing < 20-25 mph and it will be deactivated automatically when doing > 50 mph.
Does anyone else have a different experience?
Old 04-08-2013, 09:07 PM
coco135's Avatar
Here is an update...Yes, i did try my self o_0
Setting:
V_SCHWELLE_1
V_SCHWELLE_2
To werte=80 equal to 128kph or in that case it is also 80mph
D_SCHWELLE_1
D_SCHWELLE_2
To werte=32 equal to 50meters
now i can turn the rear camera at any speed up to 80mph (you can set it up to higher speed just remamber to convert kph as decimal to hexadecimal)
The camera will close once i drive more then 50 meters (you can set it up to longer distance just remamber to convert meters as decimal to hexadecimal)
Conversion can be made easily here - ignore the binary, its not being used.
http://www.mathsisfun.com/binary-dec...converter.html
Old 04-15-2013, 04:33 AM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
I changed the following values on the F01 (2009 build) but only the side camera works at any speed not the rear camera. Is this common for an early model or missing some this else.
PDC:
D_SCHWELLE_1 Werte=FF
D_SCHWELLE_2 Werte=FF
V_SCHWELLE_1 Werte=FF
V_SCHWELLE_2 Werte=FF
TRSVC:
SV_Activate_Speed_Limit Werte=FF
SV_Deactivate_Speed Werte=FF
Old 04-19-2013, 04:04 PM
coco135's Avatar
PDC:
TRSVC:
i had the same issue, it didnt work using 'FF' try to input actual hex value.
look at the post above yours
