E34 (1989 - 1995)
Old 12-23-2012, 03:10 PM
espektor espektor is offline
Mein Auto: 1993 e34
Driver Seat Stopped
Hi all.
I was working on my 1993 e34 front seat, fixed adjustment cables al was working well.
Started putting things back together, seat moving and all that, put rear bolts in and the seat stopped responding to anything, switch does not work at all, not bottom, not back. Tried same switch on the pas. side , works fine, pas side with pas switch, works fine, the seat is stuck in forward position so I can't remove it as the front is not on bolts bit on hook brackets, sort of slide for and up and remove it, with seat forward, cant get it off. Pleeeease tell me there is some simple thing I am overlooking.
thanks
Old 12-23-2012, 11:53 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I would find the seat circut fuses and test for contunity .
Old 12-24-2012, 05:43 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
I would check the plug you may have not connected it properly , it nay have worked its way lose
Sent from my Desire HD using Bimmer App
Old 12-24-2012, 07:40 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
+1 on both suggestions above.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 12-24-2012, 11:18 AM
Mein Auto: 1989 525i M20B25
You must have pinched the wire under the seat frame when tightening the bolts.
You can still move the seat manually, instrucionnes here:
http://forums.bimmerforums.com/forum....php?t=1742710
Old 12-24-2012, 02:08 PM
Mein Auto: 1993 e34
fixed this
I have figured it out, thanks, for all the posts.
Here it what it was, the fuze went out., I discovered a frayed wire on the switch, it was shorting on the seat sled around the switch and shorting the fuze, so I fixed that and it worked great.
Thanks again, little help is always good.
Old 12-24-2012, 02:45 PM
BMR_LVR's Avatar
Humble E34 lover
Thanks for posting the fix
Glad it was something simple.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
1993, e34, electric, seat, switch
