E46 (1999 - 2006)
Old 12-24-2012, 10:35 AM
Metlic53 Metlic53 is offline
Mein Auto: 325i
Should i buy this head? Mine is Cracked
well after i had a tech look over my 01 325i he said my head has a crack, their heads are way too expensive at 3000 bucks so i found this one on ebay what do yall think? I wont need to take it to a machine shop and the tech said he will put it in and swap my cams over for 800 bucks.
http://www.ebay.com/itm/BMW-M54-Rema...36b884&vxp=mtr
Old 12-24-2012, 11:30 AM
Fast Bob's Avatar
Keeping it surreal
You need to be aware that if the engine overheated, it`s possible that the block softened up and will no longer allow the head bolts to be torqued correctly. This happens quite frequently, and renders the engine useless.
The road goes ever onward....
(R.I.P. Jever)
Old 12-24-2012, 11:43 AM
Mein Auto: 325i
the first thing the tech said was it doesnt appear to have been overheated
Old 12-24-2012, 12:02 PM
Fast Bob's Avatar
Keeping it surreal
Bulldinky....heads *don`t crack by themselves*....
(R.I.P. Jever)
Old 12-24-2012, 12:17 PM
Mein Auto: '04 330Ci 6-speed
Would TimeSerts solve this problem if it came to that after he bought the rebuilt head?
Old 12-24-2012, 12:27 PM
Fast Bob's Avatar
Keeping it surreal
I don`t know if I would trust them with the pressures/expansion/contraction, etc. involved with a head job....
(R.I.P. Jever)
Old 12-24-2012, 12:34 PM
They do list this application on their website as I recall. And I think someone on another board has used them successfully. Just wondered if that was an anomaly?
Old 12-24-2012, 12:46 PM
Fast Bob's Avatar
Keeping it surreal
If I *did* take that route, and it worked, I think I`d be pretty tempted to sell that car quickly....
(R.I.P. Jever)
Old 12-24-2012, 01:26 PM
titan silber titan silber is offline
Mein Auto: '02 330ci RIP
$3000? You're not far away from a crate engine from BMW! If you're a car club member the discount on one is fairly substantial. If my engine falls out that's what I plan to do. Even if it costs me $7000 to get it all done , the car is worth more than that to me. To me, the E46 is the last great 3 series.....
Three Queens = a full house!
There's also a Queen in the sky - her name is Svetlana Kapanina!
Check her out on you tube, it's worth the trip.
Old 12-24-2012, 04:38 PM
We keep a thread handy for people faced with overheated M54 engines ... oh ... it didn't overheat (ummm ok) ... here's that thread anyway ... hope it helps the OP:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
Old 12-24-2012, 06:10 PM
Mein Auto: 325i
What is timeserts? And that overheated thread is pretty hard to read lol, so how do I know when I need a new head? All he said was the compression numbers were fine but the radiator leak down test or whatever didnt pass, it started spraying water out of the radiator cap which means the valve was letting water past? I think that's what he said. All in all I'm still a little confused
Old 12-24-2012, 06:37 PM
Fast Bob's Avatar
Keeping it surreal
You`re a *lot* more than that, my friend....
(R.I.P. Jever)
Old 12-24-2012, 08:04 PM
Mein Auto: 325i
hmmmm is 800 for a head and 800 for install a good deal though?
I want to get a second opinion but i'm not sure who to take it to
Old 12-24-2012, 08:34 PM
Fast Bob's Avatar
Keeping it surreal
That`s another thing....where are you located ?
(And *don`t* say "Conroe" or we`ll break your friggin` legs.... )
(R.I.P. Jever)
Old 12-24-2012, 08:49 PM
Mein Auto: 325i
im down her in Conroe texas, 40 miles or so north of houston
Old 12-25-2012, 06:29 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
You need to have a clear discussion with your mechanic, or get a second opinion. There must be several good BMW mechanics near Houston. Ask specifically if you have a cracked cylinder head, a cracked radiator, or maybe just a cracked radiator cap. If its the latter, buy a new cap, screw it on by hand and enjoy the holidays. From the sound of it (and I'm not trying to be insulting) you don't know much about cars and are getting confused by terminology.
Good luck. Merry Christmas.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 12-25-2012, 11:50 AM
What is timeserts?
With the decisions & effort facing you, you'll need to do a lot of reading:
- Helicoils (1) vs Timeserts (1) for stripped oilpan (1) & head gasket thread repair (1) & Metric/SAE bolt conversion factors (1)
Hmmmmm... you intimated you have a M-A-J-O-R repair in front of you. If a bit of reading is too much effort - then just wait for the two gotchas you're potentially facing:
a) Money (lots)
b) Complications (potentially a few nasties are awaiting)
Ummm... Did you read the test thread we pointed you to?
Hmmmm... if it were that alone, we'd all be replacing our heads since every single one of us had had a coolant leak at one time or another.
You have a lot to learn, my friend. And you start by reading up on what OTHERS did in the same situation (since no situation here is unique).
+1
Originally Posted by jonathan2263 View Post
YAsk specifically if you ha.ve a cracked cylinder head, a cracked radiator, or maybe just a cracked radiator cap
+1
If the OP doesn't have a good mechanic, I suggest he start here:
Finding a reputable BMW indy in your area (1) (2) & the consumers' checkbook method of finding a good mechanic (1) & repairpal labor/job/shop rates by zip code (1) & other things to consider replacing while you're already there (1)
Old 12-25-2012, 03:18 PM
Mein Auto: 325i
i know plenty about cars, my dad is a mechanic but he wants nothing to do with that bmw, he says everyone can afford to buy a bmw they just cant afford to own a bmw. I've swapped motors from jeeps, im a jeep guy that bought a bmw. i usually do all work myself to save money, i run a 2002 camaro SS with 450 HP, CAM, NANO Nitrous, Stall and lots of other mods. i put it all in myself. I'm just having alot of trouble with this BMW, i know nothing about them, i'm still learning, i probably should never have bought one. The tech said it was a crack in the # 3 cylinder and it needs to be replaced. He said the radiator and cooling system was in top notch shape. I'll go find someone else that will look at it, i paid him 75 bucks to diagnose it and i got a discount cause he is a friend. i'm sure the next diagnosis wont be that cheap.
Old 12-25-2012, 03:25 PM
Mein Auto: 325i
a) Money (lots)
+1
+1
I'm going to call european auto techniks and see how much they will diagnose it for. If they come back and say the same thing then what do yall suggest? New Head?
Old 12-25-2012, 04:48 PM
Mein Auto: 325i
ok i called the tech and he explained, he pressured up the 3rd cylinder and water sprayed out the radiator cap. all other cylinders were fine
Old 12-26-2012, 05:16 AM
Cogito Ergo Zoom
Mein Auto: 325iT
Easy there, I didn't mean to offend. You were clearly getting confused by terminology so I jumped to a conclusion I maybe shouldn't have.
Now that we know it failed the leakdown test, and you have a major problem, if it were me, I would skip the new head and look for a low mileage engine in good shape. This is the perfect opportunity to upgrade it to a 330. It's basically plug and play.
As Fastbob pointed out, M54's are very strong engines and don't "just fail" without an underlying cause such as overheating. I'd be worried about the overall health of the block at this point.
Old 12-26-2012, 09:21 AM
Fast Bob's Avatar
Keeping it surreal
OP, this^^^^^^^^^^^^^^^^^^^^^^^^is probably the best solution given your current situation. Rebuilding a BMW engine can run you *thousands* more $ than you had originally planned on....
(R.I.P. Jever)
Old 12-26-2012, 11:58 AM
Look here which was just updated moments ago regarding cylinder #3 cracks:
- 2002 525i Cracked head
Old 12-26-2012, 01:17 PM
Mein Auto: 325i
You didn't offend me, I'm just blunt I guess
Old 12-26-2012, 01:27 PM
Cogito Ergo Zoom
Mein Auto: 325iT
It's all good.
