Old 02-27-2012, 09:36 PM
morrisroad's Avatar
morrisroad morrisroad is offline
Mein Auto: BMW 530
Entire sensor. It was -11C yesterday and I still had the miss. Unfortunatley, replacing the sensor did not solve the cold rough idle problem.
MorrisRoad
Old 02-28-2012, 08:45 AM
bbones bbones is offline
Mein Auto: 528i
'99 528i rough idle
Found the trouble, a bad coil.
Old 02-29-2012, 05:14 AM
morrisroad's Avatar
Mein Auto: BMW 530
Good to hear. In my case, I replaced all the coils along with a long list of things of other things, but still have the rough idle when cold.
MorrisRoad
Old 03-09-2012, 06:50 AM
morrisroad's Avatar
Mein Auto: BMW 530
Put my old temp sensor back in since it had been acting up with the new sensor.
MorrisRoad
Old 03-13-2012, 08:16 PM
Softhands Softhands is offline
Mein Auto: BMW 530i 2003
Rough Idle in the Morning 2003 530i
For the last couple of months I have been getting a rough idle in the morning or when the car cools down typically 4 to 5 hours. When it is hot it runs good!
I went out and started up this morning after clearing the codes and it idled rough and within a minute or two check engine light came on. I turned it off and scanned it and I got a P1347 misfiring 3 cylinder. Is it possible I have a blown head gasket and during the night it leaks coolant into the 3 cylinder hence the rough idling?
Old 03-13-2012, 08:19 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Is there white smoke coming out the tailpipe?
Old 03-13-2012, 09:01 PM
no white smoke at this time. I also have replaced the spark plug and wire.
Old 12-05-2012, 03:36 PM
TEdward TEdward is offline
Mein Auto: BMW 528i
morrisroad - Any updates on fixing the issue on your car. I'm having cold rough idle also, did a smoke test no leaks and cleaned throttle body but still have rough idle on cold start.
Old 12-26-2012, 10:30 AM
morrisroad's Avatar
Mein Auto: BMW 530
Car is gone now - no further updates forthcoming.
MorrisRoad
Old 11-29-2013, 01:36 AM
vinic vinic is offline
Mein Auto: e39 525i M pack
Hi to all,
My car, an e39 525i M54 from 2002 had all the symptoms described here at cold start, rough idle, often engine was stalling, loss of power at normal temperature.
As a lot users from here, I have tested from a friend selling used parts almost all:
Fuel injection and pump, cranks shaft sensor, idle speed control valve.
I have also bought the following new OEM parts:
DISA, CCV with all pipes, O-rings, both camshaft sensors , fuel filter, fuel vacum pump from the left side of the fuel tank(or how is called), valve cover gasket, all oil gaskets that were leaking.
I have checked intake boots/
When I have done the Beyssan seals diy for the vanos pistons I have noticed that the distribution seemed to be delayed as cause of timing chains degradation/usage. The chain after some km starts to loosen, to have grater and grater play between joints and so it becomes longer than initial, and as a cause of this the variation angle/ the advance for the exhaust and intake came shaft is modified and so the vanos timing is not any more working as it should be.
The cold start rough idle did not disappear after vanos rebuild.
The car had about 280000km.
I have bought and replaced the both timing chains and the car is now back as it was a long time ago.
After erasing all adaptations the car started to run perfect, like the engine was all rebuild.
It runs fine at cold start up and without any stalling, the power has increased, the consumption has decreased about 2l per 100km. The engine acceleration is more sensitive and prompter, the engine intake filter and final exhaust sounds more sportive. The couple has also increased.
I mention I have not replaced any of the chain tensioners or followers, I have replaced only the two timing chains.
I hope this post will help some one. At least not to buy anymore a lot of parts which are not necessary to change.
Old 11-26-2015, 02:35 AM
Bell1121 Bell1121 is offline
Mein Auto: 522 it wagon
No one has pointed out one of the obvious the air pump that goes to the EGR the if it's not powerful enough will not help the engine get rid of the extra emissions, i took my EGR off and saw it was full of carbon buildup and the first cylinder where the EGR is located the spark plug had carbon buildup as well I must have a vacuum leak between the air pump EGR or the hoses that go under the intake manifold
Old 11-26-2015, 02:48 AM
Cold start is cause by many things but the mayor one EGR problems it's must be clock with carbon buildup or vacuum leak once it warms up the EGR is no longer needed to recirculate the exhaust fumes to warm up the engine quicker after the engine warms up the EGR closest engine normal operations begin there's an air pump the helps the engine with the exhaust fumes to the EGR and the exhaust check this thing
Old 03-10-2016, 05:56 AM
nyce39 nyce39 is offline
Mein Auto: BMW
Has anyone resolved this cold-start hunting issue that is not related to the VANOS seals or a vacuum leak? I have replaced everything that MORRISROAD did, but I still have the same dipping idle on cold starts. The RPMs dip every 19 seconds or so, not 7 seconds that is typical of bad VANOS seals. The idles stay consistent when warm and the engine runs strong at all times.
One user solved it by replacing the timing chains, but can someone explain why that would resolve the issue?
Old 03-14-2016, 10:51 AM
michalko.j michalko.j is offline
Mein Auto: 2001 540i6 M-Sport
Try pulling on the wires to the ignition connector of cyl 3 while running. If the miss becomes intermittent with your touch it is likely shorted wires. I had the same issue recently and assumed the worst at first as well.
Old 03-14-2016, 12:51 PM
eohagan's Avatar
eohagan eohagan is offline
Mein Auto: '03 540i/6
Mine was resolved by changing both throttle body gaskets
Old 03-15-2016, 04:08 PM
Mein Auto: BMW
I think there's two issues at play for me on cold starts. A stumbling (feels like a misfire) and a dipping idle.
The throttle body and DISA o-rings are brand new (OE BMW, not a generic OEM brand). As are the o-rings for the Air Distribution piece and fuel injectors. It feels like an electrical issue and here's why: when I feel the stumble upon a cold start, I can shut down the engine and restart, and the engine idles smoothly.
If it's not a stumble but just a dipping of the idle at approx. 19 second intervals - I'll have to to see if shutting down and restarting the engine helps. I know disconnecting the VANOS does not help (new VANOS seals).
I'm thinking about tightening up the throttle cable so the throttle body plate sits slightly cracked open (i.e. never fully closes shut) even at idle. Does anyone know if the throttle plate should be slightly open, anyway? Maybe that's my problem.
Also, upon cold start and as the engine is warming up, the idles don't drop smoothly from one RPM to the next lower threshold. It's like it abruptly "steps" down to the next lower threshold. Is that what is expected?
Again, the car runs awesome as long as I'm not idling, even when the motor is stone cold.
Old 03-16-2016, 04:28 PM
Brandon002's Avatar
Brandon002 Brandon002 is online now
Mein Auto: 2002 530I Sport
How did you get an OE DISA o-ring? Last I checked this part isn't available aside from aftermarket suppliers.
Old 03-16-2016, 04:30 PM
Brandon002's Avatar
And what throttle cable? I know my TB sits partially open with the car off. Impossible to check at idle as the car won't run with the intake hoses off.
Old 03-16-2016, 04:53 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
what year/model is your car? if I6 engine, pre 2001 is cable throttle, post is fly by wire.
99 528i 5sp sport
Old 03-16-2016, 05:04 PM
Mein Auto: BMW
2000 528i automatic tranny. Bought all parts from Tischer or FCP Euro after researching on RealOEM. I prefer buying from the latter supplier.
I'll tighten the throttle cable to have the throttle plate partially cracked open and will report back.
Old 03-16-2016, 05:28 PM
Brandon002's Avatar
If it idles poorly, but runs fun otherwise you have a vacuum leak somewhere. Check all vacuum hoses as well as the vacuum caps on the back of the intake manifold.
Old 03-17-2016, 12:10 PM
mattmar1's Avatar
Wingnut
2000 528i is the semi fly by wire, the throttle plate should be fully closed with no throttle pedal pressure. if it is hanging open any amount, your dme may sense it and send the engine in to limp mode.
99 528i 5sp sport
Old 03-17-2016, 12:16 PM
mattmar1's Avatar
Wingnut
+1...have you read, or do you have the equipment to read your fuel trims? knowing this could help prove or disprove whats youre seeing.
99 528i 5sp sport
Old 03-17-2016, 12:51 PM
Mein Auto: BMW
I have not read fuel trims. What's the least expensive way to do that? I've been considering getting INPA - will that do it?
Thanks for the info on the throttle plate...
Old 03-17-2016, 04:16 PM
mattmar1's Avatar
Wingnut
if youre droid, id recommend the torque app and an elm327 bluetooth adapter. ios, dashcommand and the elm327. under $20 for the whole setup. inpa will get you there as well, as will the creator 110/310 and many other handhelds.
99 528i 5sp sport
idle, intake gasket, maf, rough, vanos
