Old 11-23-2012, 05:39 PM
ImpetuousRacer ImpetuousRacer is offline
Mein Auto: 2013 BMW M5
Got my cable, got everything installed, coded some stuff on my 2013 BMW M5 US
Worked:
-DVD While Driving
-Turn Off iDrive Legal Disclaimer
-HUD Turn Signal
Didnt work:
-TPMS pressure didnt work for me.
Need Help With:
Unlock on engine off:
On ER_KEYOUT_AUTOVR I changed to Werte=01. When I turn the car off it unlocks the driver door only. Anyway to make it do passenger as well?
Thanks for the help!
Old 11-23-2012, 05:41 PM
April1 April1 is offline
Mein Auto: X3 2011
For unlocking all doors, go to iDrive settings.
Old 11-23-2012, 05:46 PM
That worked. Thanks.
Old 11-24-2012, 10:21 AM
tomeller tomeller is offline
Mein Auto: F30 320d
Eureka
Originally Posted by shawnsheridan View Post
I should have also mentioned that the iDrive checkbox is enabled with HU_CIC / DAYDRIVING_LIGHT = standard.
Thanks Shawn, thats where it was and now the jobs done. Not sure if the new 48.1 files helped or I was just blind the first time I looked, but alls well now.
Old 11-24-2012, 11:14 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Glad to hear it.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 11-26-2012, 08:03 PM
skymast skymast is offline
Mein Auto: 2012 BMW 535
Coding Help for Legal Disclaimers
First day coding. Somewhat painful but I solved my big issue which was turning OFF the Auto Off. I also made some other changes in terms of changing the Werte 00 to 01 for a few of the items that were on my hot list!
I am having some problems removing the legal disclaimers. Specifically, I am getting an error when i try to change ld_mit_timeout to kein_ld. It says invalid input when I try to save it.
I am also having trouble locating the remove Seat Belt from the ACSM module files if anyone has input on this as well.
Thanks!
2012 BMW 535 ... Silver / Black, M Sport, Premium, Premium Sound, Technology, Heated Seats, Sport Automatic
Other Cars ... Mercedes S550, Chevrolet Tahoe LTZ, Porsche 996 Turbo
Old 11-26-2012, 08:12 PM
Thanks!
Are you changing the Drop Down selection choice, or the actual Werte Values?
What is the name of your ACSM CAFD file?
Old 11-26-2012, 08:27 PM
I didn't see a drop down box, so i just changed the values when it was 00 to 01, then saved it, etc. This didnt work when it was text ... how do I get to the drop downs?
i wont be able to check on this until tomorrow.
Thx
Old 11-26-2012, 08:51 PM
Thx
You should only rarely be changing the actual Werte Value. Only for DVD in Motion, and very few FDL Codes where you change the Werte Value when it represents an actual value (e.g. milliseconds, volts, etc.), not when it represents a state (on/off).
To get the Dropdown box, right-click on ld_mit_timeout, and select Edit, then change it to kein_ld.
Old 11-26-2012, 10:13 PM
that was helpful, not sure why i didn't see that before. thanks.
Old 12-04-2012, 07:00 AM
coyote96 coyote96 is offline
Mein Auto: 2013 650xi Gran Coupe
Completed my first successful coding session last night! I would like to thank everyone on the forum for all of the great information and especially thank April1!!!
I coded the following after a FULL BACKUP:
DVD in Motion
Auto Start/Stop to start in the last used setting
Unlock doors when engine is stopped
Close mirrors, windows and moon roof through key fob and comfort access
iPhone ringtone is transferred to car
Opening doors (front and back) does not stop window operation
HUD Turn signals
HUD Entertainment List
HUD Phone List
iDrive legal disclaimer
Camera legal disclaimer
TPMS Add pressure and temperature
Digital Speed in BC
Once I got going it was extremely easy! Now to help the festers out here! I will be experimenting with some other functions as I spend more time reviewing all of the files, settings and translations.
I am in Lincoln, NE if anyone is in the surrounding area and wants to come to me for coding.
2015 650xi Gran Coupe M-Sport w/ 20, Black Sapphire, B&O, Cold Weather, Luxury Seating, Premium Sound, Ceramic Controls, HUD, Full LEDs, BMW Apps
2013 650xi Gran Coupe (Born 07-19-2012) M-Sport w/ 20, Black Sapphire, Cold Weather, Luxury Seating, Premium Sound, Ceramic Controls, HUD, Full LEDs, BMW Apps
BMWCCA Member
Sorry for the double post, just excited.
BMWCCA Member
Old 12-04-2012, 10:47 AM
My 5 Series satisfaction level went WAY up after disabling start / stop and enabling door unlock! Did you disable the seat belt warning? For some reason I could not find the file.
Old 12-04-2012, 11:45 PM
Glock 32 Glock 32 is offline
Mein Auto: F10 550i
Random input, but I did not see this posted in any of the instructions, so I thought I would pass along:
The follwing is translated from the enet_doku.pdf found in the C:\EDIABAS\Hardware\ENET folder cable build manual:
Documentation to ETHERNET Diagnosis Plug
Shield RJ45 to pin 4 and pin 5 OBD connector
Instructions for Operation Connection sequence for ETHERNET diagnostic connector for running from a computer:
First, the computer, and then connect to the vehicle.
Due to discharge static charge on leading ground pins
(Pin 4 and pin 5 on the OBD plug)
Because activation of Ethernet when connecting to the vehicle
(Pin 8 and pin 16 on the OBD plug)
So to be safe, we should be using the shielded cable with pins 4 and 5 grounded to the RJ45 (shield) and we should plug into the computer first and then into the OBD II port...
While this probably hasn't been an issue for anyone using a shielded cable or not, I would hate to be the unlucky one to transmit a static shock to the car / ECU .
Old 12-05-2012, 05:21 AM
Well, number me guilty. I have coded over 50 cars, and my own car probably more than 50 times by itself, and not once have I ever connected ENET to my laptop first. Every time I connect to OBDII first, then I get in the car and sit in the driver's seat and then connect my laptop. I Guess I've just been lucky.
Old 12-05-2012, 08:03 AM
Mein Auto: X3 2011
Laptops usually remain floating even if 3pin power adapter is connected. In such cases its all the same if you connect the cable first to laptop or to the car. Car is also not connected to earth though its huge mass acts as an artificial earth but it can't discharge it's accumulated charge on its own.
I agree in a perfect and ideal coding conditions, laptop/ testing m/c and car should be earthed and cable should be discharged for any static before its use.
Main purpose of a shield is to protect external noise entering into test setup.
Old 12-11-2012, 04:17 PM
fplanner2000 fplanner2000 is offline
Fplanner2000
Mein Auto: 2011 550ix Mpkge,etc; RRv
Anyone coding in the Denver area? 2011 550ix m-sport, etc.
_________________________________________________
550ix, Dark Graphite Metallic II, M-package, Dinan Stage 2, 20" wheels, conven pkge, cold weather pkge, Prem Pkge 2, Paddle Shifters, vent seat pkge, sport transm pkge, fold-dn rear seat, etc. Black Dakota Leather, Light Wood trim
Old 12-11-2012, 09:37 PM
snowboardjoe snowboardjoe is offline
Mein Auto: 2013 X3 28i
The simple act of touching your laptop and touching any part of the vehicle chassis for a few seconds is more than enough to neutralize any electrical differences before connecting cables. Making sure the laptop touches the car (either directly or through your body) will do the trick. During dry weather the risk will be a little more.
Joe Morris
2013 X3 28i (prem, tech, cold1&2, conv, hud)
Old 12-21-2012, 12:36 PM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: F80 M3
If you buy a cable you should be able to get going pretty quickly.
Old 12-26-2012, 12:06 PM
wendellg85 wendellg85 is offline
Mein Auto: 2008 M6, 2013 x3 35i
Really interested in this, but also really worried about messing up my new X3. This seems a little intimidating, but I work in IT so I'm fairly confident I could succeed with patience. As long as I have adequate backups I will be able to fix anything I could mess up, correct? Thanks all.
Old 12-26-2012, 12:12 PM
It is pretty safe, but on rare occasion, I have seen people mess up their VCM so bad, it had to go to the dealer. Of course if you move from coding to flashing firmware on modules, you could brick an ECU. Again, this is rare, and I would not let it discourage you from coding your X3, but I am not going to lie to you and say it is 100% risk free either.
Old 12-28-2012, 11:36 PM
snowcatxx87 snowcatxx87 is offline
Mein Auto: F01
I must admit - from NCS Expert and WinFPK on E vehicles back when no one was doing it was so tough. I have had DIS working and SSS Progman working as well.
Esys is so damn easy! No text editing, no complicated EDIABAS set ups, etc etc.
I will continue to investigate modules and post up new info for F01 drivers. Mostly F10 in this forum!
Big thanks to Shawn for the software.
Old 12-28-2012, 11:41 PM
Old 12-28-2012, 11:48 PM
Mein Auto: F01
I remember the millions of PMS I got back in the day. Now it's my turn heh.
Old 12-29-2012, 10:07 AM
Thanks for the reassurance! Maybe I will feel brave enough to give it a try!
How taboo is this really with BMW? What do you do when you take the car in
for service given this 'may' invalidate the warranty? Would they know that you've made changes and would they give you a hard time about it?
Also for a leased vehicle would you restore to factory defaults before turning back in?
