Old 12-27-2012, 12:25 AM
frostz frostz is offline
Mein Auto: Camry 02
Question Big difference between the 328 and the 335?
I'm looking at getting a 09 328xi coupe and I just wanted to know if there is a big difference (other than 0-60mph) in overall driving experience between the 328 and the 335. Right now I have an 02 Camry which has around 157 hp so I think anything will be fast in comparison. I can afford the 328 but the 335 I'd be a bit tight on money. So I'd just like to hear your thoughts.
Old 12-27-2012, 03:25 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
The 335 has a lot more torque, so at-speed acceleration is also noticeably greater than that of the 328. The N54 in the '09 335s can also be easily tuned to get even more torque and horsepower. The turbos add power, complexity, and potential downstream maintenance costs.
I have an '09 335 and have never regretted spending the extra money. There's a ton of opinions on this. Strangely, they all seem to lean towards "I have the (enter model) and it's clearly superior to the other one!"
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 12-27-2012, 06:58 AM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
Bigger brakes on the 335 is the largest difference. It comes with more standard equipment than the 328 as well.
Old 12-27-2012, 07:17 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
The very thought is absurd. In truth, they are the same engine. One has valvetronic [328i] and the other turbos [335i].
Apples and oranges are, in the final analysis, both fruit.
Some say one if faster than the other, but that is often misinterpretation, depending on the driver and road conditions. Naked truth: Both vehicles sport exactly the same suspension and performance thereof.
One pays more for turbos. Do not be intimidated! Unless you wish to modify, you may not notice a difference. However, engine modification, on a 335i, will result in a much faster car at the cost of its warranty, invalidated.
We are interested in your decision - please post! And keep in mind that statistically, 328i is a more reliable machine.
Old 12-27-2012, 07:49 AM
SuperTerp SuperTerp is offline
Mein Auto: m4now M5M3 550 760 335RIP
Originally Posted by CALWATERBOY View Post
[B][I][COLOR="Navy"] Unless you wish to modify, you may not notice a difference.
I get whipped all the time by other cars in stoplight racing[when I have that 328 as a loaner], where you might need to anticipate a jerk 1 second ahead with the 335i you need to do it 10 seconds ahead in the 328i. Also all the silky smooth talk I never notice that, its jerky as hell taking the foot off the gas and reengaging the car.
It may not be a big difference with suspension, interior exc., but you will get your butt kicked A LOT in a 328.
Get an IS350 if you want reliability (and it'll still be faster)
The only thing I'd worry about is the OP said he'd already be stretched just getting into it, and could find himself at the dealer within a month needing VANOS, Turbos, exc. and may not have the funds to fix the car.
*fun thing about the 328i is you can put your foot to the floor and make the the engine noises and still not be going over the speed limit
Old 12-27-2012, 08:11 AM
LegendsNeverDie LegendsNeverDie is offline
Mein Auto: BMW 328i SP
And here we go....
OP: The 328i does 0-60 in low 6's and 1/4 mile in mid to high 14's. The 335 does 0-60 in mid to high 5's and quarter mile in mid to high 13's. So there is a quite a difference acceleration wise between the two. The 328 is roughly 200 lbs lighter than the 335 and some say it is a little more tossable on turns but the difference is minimal. The biggest issues with the 335 is its reliability record and it is something you should research before purchasing the vehicle. Go test drive few of them and make your decision then. I had a 335Xi rental when my RWD 328i SP was getting work done and I really missed the 328, so it really depends on what you like more.
Old 12-27-2012, 08:35 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Avoid the 335. Coming from an '02 Camry, the 328i in any configuration is already a LOT more car than you are accustomed to. Yes, the driving experience is different from the 335i--but not in a way you will readily appreciate, yet. They are both an absolute blast, each in their own way.
You will be grinning ear-to-ear with the 328 and by not over-reaching, you will not cringe at every tiny sign of a mechanical malady.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 12-27-2012, 09:34 AM
pruks pruks is offline
Mein Auto: 335i
I agree with Zeichen311, I recommended a BMW to some one in the same boat as you. They got a 2009 328xi na dare more than happy with it.
Just for the record I own an highly recommend 335i (not xi)
2008 BMW 335i | Sparkling Graphite with Black Interior | Premium | Sport | Automatic with Paddle Shifters | Cold Weather | Ipod Adapter
Old 12-27-2012, 09:35 AM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Personally after 54 years of driving up to & including a front engine dragster I think the "its to much car as compared to what you are used to" is just silly. Any new car will drive differently then the one you are driving now. You just drive it, get used to it then work up to its & your capabilities. Working up a new car is part of the fun of ownership especially the big smile you get after learning something new about the car.
Back to the OP's question. I have both turbo & non turbo 3 series, as Calwaterboy said it's the same basic engine. If you are not interested in 0-60 vs. a 335 you will be very happy with the 328. Its quick, agile & fun to drive. My 2004 has 100K+ miles on it with about $1000+ out of pocket in maintenance expense (I do my own work) not counting tires. Both the newer 3 series are still on the factory deal but nothing outside of oil changes etc. has been done to them even though the 335is has had a modified engine for over 12K miles.
Part of the enjoyment of a car is not worrying about the monthly bill so go with what you can afford & enjoy the ride.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 12-27-2012, 09:38 AM
Speedwagon's Avatar
Speedwagon Speedwagon is offline
Mein Auto: 2012 328IX Sportwagon
Nice trip over the holidays about 300 miles here in Germany, my E91 328XI cruises great around 100mph. The power band is so sweet at 4000 rpm. The way the car tracks and rides so quiet at that speed seems like you going 55mph. I don't need turbos with the extra HP most of the time
Old 12-27-2012, 09:44 AM
Lol when we got our turbo s cayenne a guy at a local BBQ said the same thing cause he had the base S
Originally Posted by LegendsNeverDie View Post
And here we go....
Here we go what? I openly admitted the 335i is a possible shop nightmare and gave my impressions of driving plenty of 328i's (I've logged at least 2k miles in them).
Just cause I dislike the car
Old 12-27-2012, 10:00 AM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Don't be mislead by this completely erroneous statement. They are emphatically not the same engine, in fact they start with completely different engine blocks, and this analogy of apples and oranges both being fruit is just plain misleading.
The engine in the E9x 328i is the N52 engine. The engine in the E9x 335i is the N54 engine through 2011 and the N55 engine from 2012-2013. BMW didn't just take the N52 and slap a couple of turbos on it and call it the N54 or slap a twin-scroll turbocharger on it and call it the N55. Click on the links for Wikipedia articles on each engine. Also see this thread comparing the two engines. Although virtually identical in spec, the N54 and the N55 are not even the same engine, although both use turbo technology.
With CALWATERBOY you have to learn to take almost everything he says with a grain of salt.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 12-27-2012, 10:16 AM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
Everyone is going to throw numbers at you. But the truth is take them for a drive. Let yourself decide which one is better. If used both will have different options. Try it out for yourself.
Enjoy..
Take out an extended warranty with low deductible you will use it if you want to keep your car in good shape.
If you like customer service. Don't look beyond a BMW.
Old 12-27-2012, 10:22 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: 750Li Hi-Sec, '13 Actros
it depends on how much you have "fun" driving. if you take a utilitarian approach and willonly be using it to commute (as evidenced by your current Camry ownership), then the 328 will suit you fine. If you tend to try and drive your camry fast to have fun, then you will wish you got the 335.
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Mein Auto: 2008 335Ci
If the $$$ are tight, don't get the 335. You'll probably need a set of rear tires every year ... or less. (:
No matter how fast I go, there's always someone slower in front of me.
You can lead a horse to water, but you can't make him jet ski.
'08 335 E92, M-Sport option, 6 sp auto w/paddle shift
JB4 PNP G5 ISO upgrade, 3" charge pipe w/dual CM5 nozzles, meth injection, Oil Catch Can. Zero to 'OH GOD!' in a scream.
CCA Member 109065
CQ ... CQ...Kilo Charlie 3 Bravo Whiskey Zulu calling CQ
Old 12-27-2012, 10:24 AM
must not use traction control..
Old 12-27-2012, 10:28 AM
Lol I just got 30k out of the stock rfts. I'm doing at least 110+ runs twice a week.
Old 12-27-2012, 03:08 PM
Solution: Travel a high road. Do not cave to boy racer challenges - it is eloquent, and it is sophisticated, to decline with grace and cheer. That often leaves them so bamboozled that they do not remember clearly what happened.
Old 12-27-2012, 03:12 PM
This is just outrageous.
In the first place, both engines are 3 liter. I will go so far as to say that if automatic, the transmissions may differ.
Lastly, a grain of salt? I would never recommend less that a salt lick. My antennae quiver.
Old 12-27-2012, 03:14 PM
I'm not talking about someone looking to race (honestly who'd be silly enough to want to race with a 328 ) I'm talking about the jerks that cut in over solid lines, or get in the merge line and step on it.
Old 12-27-2012, 04:25 PM
So maybe the grown up plan is to just let them in & not try to close the door.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 12-27-2012, 04:30 PM
unrealii unrealii is offline
Mein Auto: 2009 335 6MT 'vert
OP, I say drive both and then decide. During my daily commute I barely make it last 3k rpm, so it wouldn't have made much of a difference to me. During my car search, I was set on a 328 manual for its simplicity and likely lower cost of ownership, but came across a well optioned 335i manual and jumped on it.
2009 335i 6MT M-Sport AW/CR Convertible
2002 Toyota 4Runner 4wd
Old 12-27-2012, 04:34 PM
Thats what they look for. Easy marks.
Old 12-27-2012, 04:42 PM
What can I tell you, its just some of us are very comfortable with ourselves & have nothing to prove.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 12-27-2012, 04:45 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
This is just outrageous....
No, it's not: you are. Your original statement was just plain wrong, SD corrected your false statements.
