2011 328ix vibration - Bimmerfest - BMW Forums
Old 11-25-2012, 07:05 PM
ddubreck ddubreck is offline
Mein Auto: 2011 328i xdrive
My first BMW new to me 2011 328i x drive I bought from BMW dealer 4 weeks ago with 6,000 mi. has a vibration that starts at 40 mph. It is most noticeable at 45mph, after 50 it starts to fade and ends at above 60-65. The dealer did force balance the tires, rotate and check for bent wheels last week.
The vibration is still there. A tech and a manager tell me they both have the same year and model and theirs vibrate also and its in the drive train and nothing can be done to correct it.
The X drive only. The BMW Rep told them the same thing.
What? Give me a break! The car should be smooth at any speed. Has anyone out there heard or have this problem also.
Any advice to solve this? Possible lemon law?
Old 11-26-2012, 11:39 AM
Spagolli94 Spagolli94 is offline
Mein Auto: 2017 3401
My 335 is perfectly smooth at all speeds (non-xdrive). I did once have a vibration issue with an MDX though. Tried new wheels, new tires, countless force balances, etc. Nothing worked. It was a new car, so all suspension and steering parts were perfect, so that ruled out something like a worn control arm bushing. Next step was to investigate possible drive train issues, but I didn't feel like dealing with the hassle, so I sold the car.
Old 11-26-2012, 02:22 PM
BobBNY BobBNY is offline
Mein Auto: 2015 535d
Does the vibration happen all the time?
I have the same car and I notice that the tires have a tendency to get a minor flat spot when sitting especially when the weather is cooler. I can feel a very slight vibration driving around town. However it goes away after about 15 -20 minutes once the tire warms up. Other than this issue the car rides smooth as glass. I have ~16k on my car.
BB
Old 11-26-2012, 04:01 PM
3284me's Avatar
3284me 3284me is offline
Mein Auto: 2011 328 xdrive
Your dealer is fos. I have 33,000 miles on my 2011 and zero vibration at any speed.
2011 328xi. Space Grey, Beige Dakota Leather, Premium pkg., Value pkg., NAV, SAT, Heated SW, Steptronic,
Old 11-26-2012, 04:07 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
>AHEM<
Which dealer is this?
Old 11-27-2012, 03:58 AM
Steveg203ct Steveg203ct is offline
Mein Auto: 2014 328i
I have a 2011 328 x drive with 17 k and I also notice a slight vibration through the drive train.
Old 11-27-2012, 07:27 AM
Did you try to get it resolved at a dealer?
Old 11-27-2012, 09:22 AM
hpc714 hpc714 is offline
Send a message via AIM to hpc714
Mein Auto: 2008 BMW 328xi
I also have an 08 328xi (e92) and I dont feel the vibration often, but I think ive felt a slight vibration once or twice over the past few months. I dont see it a problem in my car and i think the dealer is FOS. at this point theres not much else u can do other than getting rid of the car and getting a new one or ignoring the issue.
Old 11-28-2012, 11:52 AM
I'm almost due for an oil change I'm going to ask them to look at it.
Old 11-28-2012, 07:12 PM
zeeway zeeway is offline
Mein Auto: 2011 328 ix
No vibration with mine. Tires do flat spot after sitting a while - goes away in five minutes. I would sit on dealer and have him fix it. Any BMW that has a "normal" vibration is not a normal BMW.
Angie
2011 328 ix Coupe \ Sports \ Premium \ Winter \ Space Gray Metallic \ Black Leather
Old 11-29-2012, 04:00 PM
Angie
Are Conti Pro Contact run flat tires on your car?
Old 11-29-2012, 04:31 PM
Yep.
Angie
Old 12-02-2012, 07:29 AM
Yep.
Angie
No vibration what so ever at 45 mph?
Old 12-02-2012, 08:51 AM
pointandgo's Avatar
ddubreck,
If the dealer "force balanced" the tires (using the Hunter GSP 9700 machine), what were the individual tire "force" results? Ask them! I had the same issue on my car (Conti RFs). The machine will give a reading in "lbs force," and on sensitive cars 16 lbs force (1st radial harmonic) may be the limit requiring tire replacement.
BMW certainly has a standard for tire "radial force variation - RFV" that may cause ride disturbance, but I've been unable to find it. GM, Ford is about 16 lbs. max RFV. Tire RFV ride disturbance may be speed dependent, but the Hunter machine can detect the anomaly in the tire.
My advice: go back to the dealer and ask them just what the tire "RFV" limits are supposed to be and ask what they found before. If they don't give an adequate answer, go to another dealer and have the tires re-checked.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 12-02-2012, 09:45 AM
pony_trekker pony_trekker is offline
Mein Auto: 5
Wheel balancing is like cutting hair. Some people do it well some people don't. Have it rebalanced. You'd be surprised what can happen.
Old 12-02-2012, 10:34 AM
Nope.
Angie
Old 12-02-2012, 04:07 PM
Thanks for the replies.
Old 12-27-2012, 03:28 AM
Like I said I was having vibration too. It was bad between 40 to 45 . Yesterday I took it in for an oil change and I told them to check it out.
They ended up balancing the tires which cost me 100.00. That solved the problem and it drives really smooth now. I'm at 19k and I'm really careful with potholes. I can't wait to Ditch these run flats. The ride is so rough and I'm tired of the punishing ride.
Old 12-27-2012, 01:29 PM
I hope your vibration is solved, the balancing didn't work for mine, 9,000 mi. now. It starts at 40mph and is worst at 45 and doesn't happen all the time. I thought mabey the cold temperature here in Rochester, NY while it was between 36- 40 degrees but yesterday it was 23 when I started out and it was smooth as silk. Stopped at a coffee shop for about 1 hour and the vibration was back when I left. ??? What the F---? Is it the tires or drive train Xdrive? Let me know if your vibration returns. You have Conti tires too?
Old 12-27-2012, 01:39 PM
So far so good and my vibration was really bad between 40 and 45. They gave me a 2011 328i x drive for a loaner with 10k and this car really drove very smooth. Then when I picked up my car it was also smooth again.
I have the conti's also, I can't wait to get rid of the run flats. The ride will be smoother and the car won't hit the bumps so hard.
I wasn't happy about dishing out the money for balancing so soon.
Good luck and keep me posted.
Old 12-27-2012, 02:47 PM
Dubzdenver Dubzdenver is offline
Mein Auto: A4 /2011 335i ED11/12/10
My 2011 335 X Drive is smooth at all speeds.
I would never accept "this is how it is" from the
Dealer.
November 12 2010 ED
2011 335i Xdrive coupe, alpine white, dakota black leather, msport, nav, cold wx, HK sound, ipod,sat. Redelivered 01/26/2011.
Old 02-27-2014, 10:29 AM
Bmw bruce Bmw bruce is offline
Mein Auto: 2011 535I GT
speed vibration
I have a 2010 328xi and have been working with dealer to find the cause of a speed vibration starting at 50 mph to 70 aprox.felt in seat and cabin . Over the past 6 or 7 service calls,they did 2 road force tire balances, replace tranfer case, replace front drive shaft, all four rims, one tire ,arrrrrgggg it will be ok on pickup then the vibration returns.
in my past mechanic days this vibe was associated with a drive shaft or carrier bearing.
Any words of wisdom will help....Bruce
Old 02-27-2014, 11:21 AM
Indyjer Indyjer is offline
Mein Auto: 2016 X5 xDrive35i
Bruce, my 2011 328i has the same issue. vibration and low rumble noise starts at 50mph, is most prominent at 60mph to 70mph. I've had it in 5 times now, two road force balancings w/ rotation, both rear wheel bearings and a new rear diff and no improvement. I dropped it off this morning for another go, this time they are concentrating on the drive shaft. I'll report back with what is found / results when I get the car back.
Here's another thread in the forum on this same issue...
http://www.bimmerfest.com/forums/sho...d.php?t=661022
Old 03-27-2014, 12:14 PM
Vibration
Hi Indyjer, yes I gave up and upgraded to a 535I X. GT. the problem wasn't fixed. Probably a drive shaft or bearing/bushings
Old 03-27-2014, 12:27 PM
sleeper22 sleeper22 is offline
Mein Auto: 2009 328i Tasman Green
I'm experiencing the same thing with my 09 328i. Mine starts about 50 mph and stops around 60 mph. Brand new tires are on the car and there is no vibration or shaking in the steering wheel or pulling to one side whatsoever. Leads me to believe it isn't the tires or balancing. If it was a balancing issue wouldn't you think it would be felt through the steering wheel? I feel like its coming from the drive train as the car is quiet up until 50 mph.
