The X5 SAV Forum
Old 12-26-2012, 12:59 PM
bpbendbimmer bpbendbimmer is offline
Mein Auto: 2000 E53
2000 e53 battery voltage 11.7 replace battery or alternator?
I have a 2000 X5 (e53) 4.4. Yesterday the red battery light came on shortly there after it began to systematically shut down systems then died. Hauled it home recharged the battery overnight voltage reads 11.7, 10.7 while the motor is running, the battery light is still on. Should I replace the battery or the alternator?
Old 12-26-2012, 01:26 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Alternator. Bosch alternators pretty much lock th top voltage to 13.85 Volts. Anything much below 13.5 Volts with the engine running suggests the alternator is defective. Having said that I would also check the battery under load in case it has joined its buddy the alternator.
Old 12-26-2012, 03:32 PM
Mein Auto: 2000 E53
Thanks Zulu, pretty much as I thought.
Old 12-27-2012, 12:07 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
If you have the V8 with the water cooled alternator, sit down when the part guy tell you how much it cost. Talk about sticker shock.
Old 12-27-2012, 12:15 PM
Zulu95's Avatar
I did not want to mention that bit. I hate to kick a guy when he is down.
Old 12-27-2012, 03:39 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
The battery warning light is about the most misunderstood warning of them all...it illuminates when the BATTERY is NOT being charged...thus it reveals that the battery is the VICTIM...not the culprit.
Q {BMW CCA Member #191509}
(SOLD)
alternator, x5 battery
