Old 12-24-2012, 07:32 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
P1349 Help
Hi guys. Driving to work today, going up a steep, twisty hill in M mode (auto trans) in 2nd gear at about 5500 rpm's when service engine soon came on. Feels like loss of power and rough idle at stop in gear. In neutral, with rpm at about 1000 feels smooth.
Code is P1349: misfire cylinder 4 with fuel cutoff. Any advice on where to start troubleshooting is most appreciated. I'm working until 2, then will dive in.
Merry F-in Christmas.
Have just 83k miles.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 12-24-2012, 09:54 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Brother Jonathan,
Sounds like a bad coil on the #4 cylinder....try switching `em around and see what happens.
Merry Christmas !
The road goes ever onward....
(R.I.P. Jever)
Old 12-24-2012, 10:00 AM
Cogito Ergo Zoom
Mein Auto: 325iT
Thanks Bob. I was going to try that when I got home. I know my coils were switched under the warranty but not sure when that was. All records are home.
I'll update when I've done it...
Old 12-24-2012, 10:04 AM
Fast Bob's Avatar
Keeping it surreal
Same here...."London Calling" by The Clash currently spinning on the turntable....
(R.I.P. Jever)
Old 12-24-2012, 12:08 PM
Cogito Ergo Zoom
Mein Auto: 325iT
Hahahaha...
Update: first , all coils were replaced at about 27k miles as per the recall.
After work, it started and idled just fine, although maybe the secondary air pump sounded a little different, but I'm not sure about that. The cel was not on. I cleared the code and drove home with two stops. It ran just fine up and down the hills, idled dead smooth, no warning light came on and when I scanned it after I got home, there was no current or pending code.
I'll just have to keep an eye on it and see what happens. I wonder if I just kept it at high rpm's too long and it got angry? I'll update later...
Old 12-24-2012, 12:29 PM
Fast Bob's Avatar
Keeping it surreal
Hahahaha...
Hopefully it was just a one-time thing....
(R.I.P. Jever)
Old 12-26-2012, 06:08 PM
Cogito Ergo Zoom
Mein Auto: 325iT
Update: this morning I put it in M and attacked the same hill in the same style as I did when I got the code and misfire, and no problems.
This afternoon I drove home on super slippery roads and had to floor it (in A, DSC all the way off) to slide/drive up two particularly steep but short hills. And again, no problems. It seems to be back to purring like a kitten. Not sure what it was, but maybe the ghost in the machine has fled.
Meanwhile, my front left xenon bulb has gone out. Doh !
Edit: btw, for local festers, it was Ironia Rd from Mendham to Ironia, off rt. 24. Try it, 4 switchbacks in about 1/4 mile. Both directions, up or down the hill, will demand your attention.
Old 12-27-2012, 05:22 PM
Cogito Ergo Zoom
Mein Auto: 325iT
Update on the update: this morning the SES popped on again. I got P0174. It's running dead smooth and idling smooth right around 550, as usual. My first thought is small leak in an intake boot. Since the car is 10 years old this January, I figure go ahead and replace the boots. I ordered them from Max at oembimmerparts today. While I'm in there, I will clean the ICV and MAF.
Meanwhile, I'll do the "spray carb cleaner at the boot test" to see if I'm correct. Hope this does it.
Oh, I cleared the code before I left work, drove home with one stop, and no code present or pending when I scanned it in the driveway. Whatever it is isn't major... Yet.
Any noobs reading this, get a cheap code scanner to keep in your glove box, it's priceless.
Old 12-27-2012, 05:23 PM
it was Ironia Rd from Mendham to Ironia, off rt. 24..
Didn't Ironia used to be called Pleasant Hill Road? Love the iron ore mines of Dover, Chester, Rockaway, etc.
Anyway, to diagnose the classic misfire, I'd recommend you start here:
- How to diagnose a BMW E39 engine misfire (1)
And, the fuel shutoff is covered in detail here:
- Why misfire-related fuel shutoff occurs and how to fix it temporarily (1)
Old 12-28-2012, 04:30 AM
Cogito Ergo Zoom
Mein Auto: 325iT
If you bear left at the stop sign, it's Ironia Rd. , if you bear right, it's Pleasant Hill, also good but not quite as challenging.
Thanks for the links. In my searching for info I had already stumbled upon them but extra help is always appreciated. I'm hoping for a quick, easy fix, but if it persists, I may be making your smoke machine.
More to come...
Old 01-06-2013, 03:15 PM
Cogito Ergo Zoom
Mein Auto: 325iT
Just wanted to update this if anyone stumbles across it.
I replaced both boots today. The upper boot came off easily but the clamps on the lower boot were facing towards the back and I couldn't get any type of tool on them. Ultimately, I just cut away most of the boot and was then able to get a small (6mm) open end wrench on the clamps.
Before I cut the lower boot off, I could clearly see a crack in the small elbow. Obviously, that was my leak. With new boots on, and clamps lined up for ease of future access, it was running quite smooth and feeling peppier than it had recently.
So I'd say, if your getting P0174, and nothing else, get a good look at the intake boots. Also, the old, lower boot felt a lot harder and stiffer than the new boots. Guess eventually the heat gets to these things.
And one final thing. Start to finish was over three hours, but if I hadn't spent so much time trying to get the old boot off clean, and just went straight to the knife, it probably would have taken about 1.5, including cleaning the MAF and getting distracted by shiny bits.
Old 01-06-2013, 03:33 PM
Fast Bob's Avatar
Keeping it surreal
Glad to hear the surgery went well , and the patient survived, Doctor Jonathan
(R.I.P. Jever)
