Old 12-28-2012, 05:00 AM
mateforrest mateforrest is offline
Mein Auto: BMW F16 3.0D & mini F54
6WA retrofit KOMBI
Hello I'm going to buy a extended information cluster for a good price. 6WA option
The seller told me that the mileage is not stored in the kombi, and he tell me that this data is taken from the car.
This KOMBI has 13k Kilometers and mine has 38k.
Could I retrofit it without the help of the dealer? Only with my enet cable.
Where is the immobility device? Inside cluster like VAG's?
Shawn any advice?
My car has actuality the daten 47,5 and I have in the HUD the multimedia and telephone information.
Could I upgrade this KOMBI once installed to enable this features?
Any time I will go to the dealer I will need to instal my old Kombi and after change again?
Thanks in advance to all for the help.
Regards.
Old 12-28-2012, 07:32 AM
ad2k ad2k is offline
Mein Auto: F07
hello, it seems wiring is completely different for S6WB (optical fibre)
anybody can confirm wiring differences
I want s6wb too
Old 12-28-2012, 08:04 AM
snj1013 snj1013 is offline
Mein Auto: 2011 528i
I am wondering the same thing. Based on info I have read, I don't believe any mileage is stored in the display.
Old 12-28-2012, 03:36 PM
Could you send me this information?
this is great, because i want that it display my actual real mileage.
Regards
Old 12-29-2012, 12:03 AM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
I want s6wb too
The OP wants to go from the basic Instrument Cluster to 6WA, not from 6WA to 6WB.
BimmerTech though has come to market with their official 6WB Retrofit for those interested, and it can be retrofitted with or without 6WA/HUD:
http://www.bimmer-tech.net/shop/bmw-...panel-retrofit
It is $2k USD.
Old 12-29-2012, 12:33 AM
Shawn any advice?
Regards.
Yes, my advice is that if you can get a 6WA Instrument Cluster cheap, do it. If you have to pay full price, go with 6WB.
Based on what I know about BimmerTech's 6WB Retrofit, which I am pretty sure the same also applies to going from the Basic Instrument Cluster to 6WA:
* It would need some coding (Presumably 6WA in VO, and VO Code KOMBI and HU_CIC - If Pre 03/2011 build, the Production Date would need to be changed) - E-Sys and ENET Cable is all that is needed.
* If you car currently does not have Eco PRO or Sport Modes, those displays will not appear
* The mileage will be identical to the your original unit
* You can swap units and the units will always show the correct mileage
* You need to swap the units before you go to your dealer for a service that requires a software update
* It is a 5 min job to change Instrument Clusters
As for the Entertainment List, Incoming and Outgoing Calls, Recent Call List, and Voice Recognition, if you have 6WA KOMBI with 47.x or higher firmware on it, you should get those features in your HUD after coding them.
NOTE: This assumes a Brand New never used KOMBI. A used KOMBI will have original car's VIN programmed in it, and I do not know how to change it, so this will be a problem and the mileage will not update.
Old 01-05-2013, 10:07 AM
yreiser yreiser is offline
Mein Auto: F10 530dA
@mateforrest
Did you swap your units already?
Old 01-07-2013, 03:13 AM
Originally Posted by yreiser View Post
@mateforrest
Hello yreiser,
I still donīt have the new instrument cluster, is on the way.
I hope i will do the swap next weekend.
Donīt worry i will give further information.
Old 01-07-2013, 10:14 AM
Hello yreiser,
Did you order a new one or do you plan to install a used one?
Old 01-07-2013, 09:20 PM
He bought a used 6WA KOMBI.
Old 01-09-2013, 01:07 AM
I got it.
I will inform when i have the retrofit made.
Old 01-09-2013, 07:02 AM
Shawn i just email you.
Fitted, correct mileage, but canīt code... error in E-sys.
Old 01-09-2013, 07:03 AM
Yes, I replied.
Yes, you can't code it because it does not recognize the VIN. That is why it is showing yyyyyyy as the VIN.
The EEPROM needs your VIN written to it.
Old 01-09-2013, 07:12 AM
Old 01-09-2013, 07:14 AM
I have an error to get CAFs for SWE.
Please take a look.
Regards
Old 01-09-2013, 07:32 AM
Please take a look.
Regards
So what happens when you try this:
Connect => Read FA => Activate FA => Read VCM => Left-Click on KOMBI => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on KOMBI (the ECU itself not the underlying CAFD) => Select CODE.
To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps. The I-Step (current) is the one you want to match when you select the CAFD from the "Detect CAF for SWE" options (e.g. F001-08-09-550).
Old 01-09-2013, 07:45 AM
Ok let me try.
But when i did this:
i not sure but i think that i obtain the error of swafīs
Regards.
Old 01-09-2013, 07:48 AM
Ok let me try.
Regards.
Yes, you may have a read error. I think though the CAFD that is there is wrong, and needs to be changed, so what I am trying to do is identify the right CAFD, inject it into KOMBI and VO code it.
Oh, which brings up another point. Make sure the VO you use has 6WA added to it.
Old 01-09-2013, 07:50 AM
I got it
Is the first i do.
Regards
Old 01-09-2013, 07:51 AM
Shawn the speedometer is from a F01?
is possible that i only have the cafd for f10?
Regards
Old 01-09-2013, 09:42 AM
hamfei hamfei is offline
Mein Auto: 2012 E90 CLI
It's impossible to reprogram a KOMBI which was used on other cars without cracking works. This is because the EEPROM stores VIN of the car. If the VIN does not match the information stored in CAS, you will see a white dot on the meter. Also, the device would not be working properly.
I've found the way to reprogram a used KOMBI. See
http://www.bmwcoding.com/showthread....M35080-E8x-E9x
http://www.bmwcoding.com/showthread....-BMW-F10/page2
Old 01-09-2013, 09:55 AM
He suspects the seller erased the EEPROM.
On new KOMBI's, with a virgin EEPROM, supposedly it will automatically sync with CAS.
So, will a Used KOMBI do the same if it has been erased, or must the KM and VIN be changed?
Old 01-09-2013, 10:07 AM
Regards
If you do what I suggested, it will be the right CAFD for that KOMBI Hardware.
I am afraid though hamfei, who is an expert at this, is correct, and the EEPROM will need programming.
Old 01-09-2013, 11:48 AM
This won't help solving the actual problem, but maybe for later:
In KOMBI/300A/FAHRGESTELL_NR_RDA, the short VIN is stored and may be altered. The comment says "Here to write the VIN that will be used to do the comparings with CAS. This VIN has nothing to do with the VIN that's written while flashing."
Old 01-09-2013, 12:25 PM
Shawn i send you pictures to your mail.
Please take a look.
Regards
