Old 12-27-2012, 09:57 PM
joebruin joebruin is offline
Mein Auto: Mercedes
Weird Noise in Gear Shift Control
Hey Brothers--I have a 2012 550i. I noticed that when I am shifting from Park to D or N and back to Park, there is a weird noise in the controller. Is this normal?? Thanks!!
Old 12-28-2012, 04:28 AM
markl53's Avatar
markl53 markl53 is online now
bimmerfest Supporting Member
Mein Auto: 2014 535i
What is the noise? You will hear a slight "click" of a solenoid (or similar mechanism) when shifting into or out of Drive. That is the control that allows the lever to be moved over to the DS "gate". Other than that, I hear no noise from the shifter. Oh, and if you leave it in the DS position and engage Park, the shifter will automatically push over to the standard gate first.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Old 12-28-2012, 07:57 AM
Mein Auto: Mercedes
It kind of sounds like an electronic gear...almost like a buzzzz sound. I know it is hard to describe, but it is not a clicking sound.
Old 12-28-2012, 08:17 AM
markl53's Avatar
Hmm, sounds a little strange. The part I mentioned about being in the DS mode and pressing Park, there is a slight motor-type noise as the lever is automatically pushed back over to the right side. But this noise doesn't happen if you just go to Park from N or regular D. Maybe time to have someone take a look -- good luck.
BMW-CCA
Old 12-28-2012, 08:32 AM
Kar Don Kar Don is offline
Mein Auto: '14 & '15 i3, now '16 i3
My F10 with sport auto didn't make any noises shifting. My X5 with standard E-shifter also makes a electronic buzz sound when i shift into drive.
2008 Mercedes-Benz CLS550 Iridium Silver/Black Leather -- P2/321/881 (leasetraded 1/10)
2002 BMW 325i --Topaz Blue/Natural Brown Leather --SP/PP/HK/CWP/Bi-xenon (Sold 9/06)
Old 05-23-2014, 09:49 AM
ninja_zx11 ninja_zx11 is offline
Mein Auto: 2009 X5 35D
Hi, First of all sorry for reviving the old thread.did you find the problem?I am feeling same kind of motorized noise coming from the gear shift lever.I hear when i press the P button from drive.Its like motor running for a second.It was already there when i bought it used couple of months ago.Vehicle is E70 2009 X5D.Thanks
Old 05-23-2014, 12:24 PM
markl53's Avatar
If you have the gear selector in the left side "DS" gate when you shift to Park, a motor will push the lever over to the standard gate first. My new LCI 535i has a change from the original solenoid "click" I mentioned in one of the original replies. Looks like they changed that to a small motor. WHen I shift into or out of Drive, you can hear the quick "whir" of a motor opening the DS gate. My old solenoid-based unit had an intermittent issue, as I think others did. This is probably an improved version.
BMW-CCA
Old 05-23-2014, 01:35 PM
yes exactly that motor 'whir' noise.but i didn't notice the same noise in other models in which same kind of joystick shift lever is.It feels like worn out motor or worn out gears that drive that mechanism.anybody knows.? thanks
Old 05-21-2016, 11:39 PM
hectic77 hectic77 is offline
Mein Auto: 2006 e90 320d
Buzzing noise in gear shift
Hi there, I know this was posted a long time ago. Did u manage to found out what was causing it to buzz? Having the same issue and replaced the gear shift assembly unit and still making buzzing sound. Don't know where to go from here?
Old 05-22-2016, 02:02 PM
cityjohn cityjohn is offline
Mein Auto: 1998 M3 . . . 2012 528i
Yes, BTW this is what it looks like (can't hear though). Shut off the motor with the START button and the shifter moves over on its own.
