Old 12-27-2012, 08:57 PM
SFbay SFbay is offline
Mein Auto: BMW 745i
Originally Posted by cmpcpro View Post
So this is after driving freeway, and town, and traffic? 92c? See that's what I don't understand.. either your TSTAT is bad, your DME is opening the tstat way early because of a sensor or something, or your car is running super cool from the small coolant loop and not even using the lower radiator hose.. I don't understand how this could be.. only thing I can think sounds right, is either DME is opening it early, or do you happen to have an 02? I heard somewhere that the early 02's got a 92c tstat.. Or I should say the early N62 engines.
Nope all bmw v8 v12 engines starting from 98 are built to fail with 105C. If your car never goes to 103-105 it means its either half opened or bc DME opens it too early. I personally saw one e65 where DME kept it fully open all the time!!!
It depends on some factors like intake air temp sensor and engine temp. If DME sees that it's super hot outside it would open tstat earlier.
Anyhow I totally understand what's going on:
I bought 160k miles e66 and it worked great but radiator was leaking a little, so replaced it and it worked for a while but recently I got a leak from somewhere else bc of high pressure.
In other words this stupid super hot cooling system sucks and will keep exploding weak areas of this system!!
You fix one leak and you'll get another one over and over, until either you overhaul everything related to cooling system or you replace engine!
What a great car and great ideas
Yes they want more money from us and moreover they don't want luxury vehicles to last over 60k warranty miles and 105C tstat is a brilliant solution!
Coolant pipe and rear cover profile gasket and a heater core are the worst : and all these gaskets only last 3-5 yrs max. I'm not even talking about all oil leaks related to high temp
ID:	354921   Click image for larger version
Old 12-27-2012, 09:17 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 12-27-2012, 09:43 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Well I have bought the entire cooling system in the last couple days. It's all sitting in my living room.. Was going to install tonight but I didn't make it to the dealer in time to get the last two pipes.. I have new expansion tank, cap, all new hoses, sensors, tstat, the good metal impeller water pump, aux water pump, coolant. The only thing remaining is the radiator, heater hoses/core and engine.
Old 12-27-2012, 10:14 PM
Mein Auto: BMW 745i
Entire cooling system?? Don't want to upset you, but...
You'll be surprised, but you also need:
-valley pan 99.9% leaking from the rear of the engine (I found small leak on my car)
- rear passage cover (not sure if mine has it, bc valley pan could cause that leak to.
- coolant pipe seals (most likely you can see wheep hole leak but not always)
Replacing a heater core is a real PITA!
Old 12-28-2012, 12:31 AM
Mein Auto: Nothing
Yes unfortunately I only have the cooling system that isn't built into the engine/heater core.. what do you mean you aren't sure if your car has a rear passage cover? Don't they all? I am wondering if this issue could be the starts of the coolant pipe/valley pan? I will have my water pump out tomorrow, I will look around and see what I can find.. which reminds me, SFBay, I know TIS said the harmonic balancer has to come off for the water pump but I am reading people are doing it without removing.. what did you do? Thanks!
Old 12-28-2012, 11:36 AM
B7M4W5's Avatar
B7M4W5 B7M4W5 is offline
Mein Auto: BMW 745LI
Been read this for some time and I had the same things happen to mine over heating hacd to replace upper hose and expansion tank and cap the hoses have a poor made were the T or Y connect they just fall apart Im thinking what if we flush cooling systems it could be clug from crap like parts that come from T or Y connectiond from hoses. What do u thing guys?
E66 745LI 2004 Sport / Sterling Grey Ext. Blck Int./
22" Wheels / ACS Pedals / ACS Rug Plates/
Black Out Tail Lights / Carbon Fiber Blck.-Gry. Emblams/
Grill Chrome-Blck. /
12" Subwoofers 2000 watt Amp
Old 12-28-2012, 12:08 PM
Mein Auto: BMW 745i
I'm not quite sure if its valley pan or that rear cover since they both leak from rear of the engine.
Idk how to remove waterpump without removing that harmonic balancer, and it's very easy to remove and install.
Old 12-28-2012, 12:10 PM
Mein Auto: BMW 745i
Hey after you replaced that Y pipe did it fix everything?? Mine looks good and cannot see any leaks, so I was wondering if I need to replace anyways 70$ smth!
Old 12-28-2012, 12:14 PM
Mein Auto: Nothing
Your talking about the one that goes from the expansion tank to the t or y and then into both heads? I have the new one, going in with everything else..
You were saying its very very easy to install, do you mean harmonic balancer or water pump? Thanks!
Old 12-28-2012, 12:18 PM
Mein Auto: BMW 745i
My car runs okay now, but still I want to fix that damn invisible leak.
Yes it's easy to remove harmonic balancer. But if I were you I would try to fix that leak first. Your waterpump is okay.
Old 12-28-2012, 12:21 PM
Mein Auto: Nothing
Waterpump is making a horrible noise everytime car starts cold.. I think bearing is shot.. going to replace it with everything, so it will all be new at once.
Old 12-28-2012, 12:22 PM
B7M4W5's Avatar
Well leaks stop and since I replace cap it stop over heating, but it still goes up to 105c hope all that programming works out, but Like I said we all had a got temp. when first got our 7s so could it be radiators are clug need cleaning from inside
Old 12-28-2012, 12:31 PM
B7M4W5's Avatar
Yes that happend to me made squeeky sound then one morning on way to work it went out fell apart lost power steering control steam all over could not see where I was goin pully fell of lost belt, man I was hating that day.
Old 12-28-2012, 01:31 PM
Mein Auto: BMW 745i
It's ok you have 105C but what about idling? Can you check When it's 105C will aux fan kick in?? It should be 105C then aux fan lowers it to 103 then it goes to 105 and it's kinda cycle it should have.
Old 12-28-2012, 01:46 PM
B7M4W5's Avatar
That it does in idle, for now nock on wood lol
Old 12-28-2012, 01:49 PM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
What I was thinking earlier the OEM tstat could be gutted and put an aftermarket inline tstat.Might be easier than what your doing SFbay.Also my fan dosnt kick in until 105c but it does let the temp get to 107c.Could the fan not be running high enough speed to keep 105c minus?Sorry to keep rehashing but it takes me awhile for it to sink in lol
Old 12-28-2012, 02:00 PM
Mein Auto: BMW 745i
Try it, I've already tried it. Diameters are really off. I found some Mazda tstat kinda fits ok, but still had to machine it.
Old 12-28-2012, 02:02 PM
Mein Auto: BMW 745i
It means your system works good at tstat opens up when needed. This is how it should be 103 to 105 cycle.
Okay I'll replace that Y hose even though I see no leaks from it.
What's funny that my system was fine a month ago, and I thought it was fine until 3 days ago I got low coolant message!!! In other words you have to check your aux fan every week just to make sure you're not ruining your engine!
So I've been driving my car thinking it was fine for a month and now I can see upper timing chain covers leaking!!! FK
Old 12-28-2012, 02:04 PM
B7M4W5's Avatar
Cool
Old 12-28-2012, 02:23 PM
Mein Auto: Nothing
I know, isn't it frustrating? Whats worse is BMW did this to us to screw us.. Which y hose are you talking about? The little one that goes to expansion tank? I am doing that one with the overhaul.. gonna have to take the TB off to get to it, so I bought a new TB gasket too.
Old 12-28-2012, 02:35 PM
dolfan13's Avatar
Mein Auto: 545i
I replaced the hose behind the intake awhile back.I think SFbay said it when it could be a small leak anywhere.probably shouldn't have done it but I put 1/4 bottle of aluminum seal bars leak.Been holding steady at 105c
Old 12-28-2012, 02:41 PM
Mein Auto: Nothing
Well if it's any of the hoses, or expansion tank, or water pump I should know tonight.. been trying to install this new cooling system for the last few days and have just been too busy.. Sick of looking at all the boxes in my living room everyday.
Old 12-28-2012, 02:58 PM
Mein Auto: BMW 745i
Super update:
I removed TB and look what I found:
- previous owner was a btch
- this Y pipe is actually has a bleeding valve inside, so if there is any smallest tiny leak, the system will never get bleeded!!!!
So I guess it was a number one problem, but I need oem clamps to install oem one. FK
This is very very important hose, replace it anyways even if no leaks bc you don't know if that valve is working!!!
ID:	354997   Click image for larger version
Old 12-28-2012, 03:05 PM
dolfan13's Avatar
Mein Auto: 545i
I went to 108c anyway.Are you saying the bleed is at the expansion tank connection?
Old 12-28-2012, 03:32 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
That barsleak will clog your heater core, I know from experience and its not a cheap fix. I put a bottle in my car trying to get another month or so out of the crossover pipe leak, my Indy was sooooo pissed.
I suggest a good cleaning of the coolant system. This might be why you are at such a high temp, that stuff sticks to anything and everything
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
