Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 12-26-2012, 06:18 PM
spooledsouth spooledsouth is offline
Mein Auto: 135i
135i clutch out at 46k miles?
Hey guys, I bought my first bmw (135i 2009) Friday night and long story short the "clutch" went out on me the very next day.
Story: I was driving normal as a approached a red light I pressed the clutch to the floor and lifted my foot and the clutch stayed on the floor. I got the car in 1st and pulled into a parking lot and had it taken to BMW of Nashville. I was almost positive it was just going to be a slave cylinder. They called today to let me know it is the clutch. The clutch didn't show any signs of slipping or burning smell. They haven't pulled the tranny yet but they're positive its the clutch. I didn't notice any fluid leaking.
I'm wanting to see what everyones input is on the subject. Good thing is that I have a BMW maint. plan on the car but that only covers the clutch, not the flywheel. The flywheel alone is a $1.4k job.
Thanks, Justin
Old 12-26-2012, 06:24 PM
Mein Auto: 135i
Also there was a small exclamation mark with a triangle around it that came up and started counting the miles since it was on. I was low on gas and thought it was because of that. The dealer said there is no warning light for low clutch fluid and it came up becasue the clutch slipped. I didn't feel it. It got to about 25 when the problem happened.
Old 12-27-2012, 07:54 AM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
It sounds like your pressure plate bit the dust. The warning light is from the DSC. It sensed that the engine rpm is not in sync with the speed of the car (i.e. the clutch is slipping). I'm not sure if this is covered under the maintenance plan but do your homework to find out what is definitely covered so you're not shelling out money on expensive parts and labor if you don't have to.
Also, clutch hydraulics share the same fluid as the brakes. If the fluid was low you would see the brake warning light. But, if I'm not mistaken, the clutch pulls the fluid from a high spot in the reservoir, so if the slave cylinder started leaking it would be able to leak enough fluid out to trigger the light.
Old 12-27-2012, 08:05 PM
x3brian x3brian is offline
Mein Auto: X3
It's not uncommon for a clutch to go out at 46k...depending on how the car was driven. I have had clutches last 150k driving lightly and had m3 clutches burn in 25k because I was a knucklehead.
Clutch, resurfacing of pressure plate and labor should be covered by maintenance plan assuming two things...
1) If DCT and launch control wasn't used more than 3 or 4 times since new (I forgot which but they do look it up)
2) pressure plate doesn't show excessive wear. If its blue you'll be blue..,.
Old 12-27-2012, 08:17 PM
ND40oz ND40oz is offline
Mein Auto: 09 135i
Originally Posted by x3brian View Post
1) launch control wasn't used more than 3 or 4 times since new (I forgot which but they do look it up)
The only launch control on a 6MT 135i is your left and right feet.
17 Volvo XC90 T6 Inscription P* (OSD 7/16)
15 BMW 328d xDrive Sports Wagon M Sport
15 Audi SQ5 Prestige
13 Honda Insight EX
Old 12-27-2012, 09:51 PM
Mein Auto: X3
Valid point. I assumed DCT as the post didn't specify 6mt or DCT. Post above edited.
Old 12-28-2012, 06:58 PM
Mein Auto: 135i
The dealership called and said that the clutch was in pieces! Really? I didn't even drive it hard for the 24 hours I owned it so I guess bad timing from previous owner beating on it. I'm stopping by tomorrow without asking and seeing if the tranny is really pulled of if they're just trying to bend me over. And now he is saying that the flywheel is able to be resurfused when at first he said it couldn't be. To many fishy things going on with this.
Old 12-28-2012, 07:25 PM
Mein Auto: 09 135i
NP, the DCT wasn't available until 2011 when the N55 switch happened.
13 Honda Insight EX
Old 12-29-2012, 06:57 AM
If the PO really beat on the clutch, ran it hot, burned it or wore out the lining, then the flywheel would be completely spent and need to be replaced. If the pressure plate self destructed on its own because of a manufacturing defect then the flywheel is likely to be in good shape and can probably be left as is.
If I'm not mistaken, BMW explicitly says that dual mass flywheels should never be resurfaced. Due to the nature of their design it is impossible to control the runout while resurfacing and clutch chatter, judder, etc. will likely happen after the new clutch is installed.
I would highly recommend taking a look at the parts yourself and see if there's any evidence of the PO driving it hard (glazed or excessively worn lining, burnt or scorched pressure plate and/or flywheel). If it looks like the springs in the pressure plate just exploded, then it's likely no fault of anyone who's driven the car, just bad luck.
Old 12-29-2012, 04:41 PM
Mein Auto: 135i
This is the picture they sent me.
Old 12-29-2012, 04:46 PM
Mein Auto: 135i
I wanted to see the fly wheel but it was still in the car they said and the car was outside on these rolling dolly type things because I'm still raising hell with corp to at least get a new flywheel for free. I don't want the old fly wheel in either way but don't want to pay the 3.4k for clutch and flywheel install. Right now the price is at 1.6k for a new clutch, resurface the flywheel and labor.
Old 12-29-2012, 07:28 PM
SuperTerp SuperTerp is offline
Mein Auto: m4now M5M3 550 760 335RIP
I'd freaking call BMWNA if you bought it at one of their dealers... Thats unacceptable if they sold you the car and the next day it falls apart. If the clutch is "in pieces" take a camera and snap pictures for BMWNA.
Old 12-30-2012, 12:24 AM
Mein Auto: 135i
Well that's the thing, I didn't buy it at one if their dealers. I've been talking to bmwna and I'm waiting to hear from a resolution specialist. I at least want a new flywheel for free.
Is the clutch delay valve something that needs to be removed on these cars? I was on modbarrgings and saw the delete kit and read a little about the OEM part. Apparently it delays the clutch from full engagement to avoid drive train shoc. Correct me if I'm wrong, but couldn't that burn a clutch out especially if the driver were already use to releasing the clutch cautiously?
Old 12-30-2012, 06:01 AM
The clutch delay valve should remain installed if you want to keep your warranty. Removal is a popular aftermarket mod to give you a better feeling in the clutch pedal during engagement. Some argue that keeping the valve can result in premature wear since it can cause excessive slipping in the clutch under certain circumstances.
But, I think it's a moot point right now. I would encourage you to go to the dealer and take some pictures of your own. The one above isn't too clear and it's hard to see if the lining has any glazing on it. Also, the pressure plate is covered in clutch dust so it's impossible to see if it has any scorching or burn marks.
While you're there, crawl under the car and snap a pic of the flywheel.
If there's no evidence of excessive heat, burning, scorching, glazing, etc. on any of the components, then BMW will be hard pressed to find a reason to blame this failure on the driver(s) of the car. In this case, it's just a stroke of bad luck and the lining decided to disintegrate. If there's any evidence of heat build-up, then you're stuck with the bill, sorry.
Old 12-30-2012, 04:54 PM
snowcatxx87 snowcatxx87 is offline
Mein Auto: F01
Thumbs up
Does the vehicle still have new car warranty?
If you didn't buy a CPO BMW how can it be BMW's fault? The previous owner didn't know how to drive standard... and unfortunately you're the one who has to fix it!
Old 12-30-2012, 07:43 PM
rich8566's Avatar
rich8566 rich8566 is offline
Mein Auto: 2014 M235i; 94 Mx5 R Pkg.
Unhappy
Ughh. I feel your pain.
2014 M235i 6 SPD Prem CA NAV HK CWP Driver Assist Estoril Blue
ED#4: 3/17/14
2011 335i 6 SPD M-Sport CWP CA HK ETTE Laguna Blue
ED#3: 8/15/11
2011 X3 3.5 HK CWP
PCD#1: 2/11/11
2008 535Xit Slush Box Prem Sport HK CWP CA Monaco Blue
ED#2: 2/16/08
http://picasaweb.google.com/Rich8566...ueFebruary2008
2007 335i 6 SPD Sport CWP HK CA ETTE Montego Blue
ED#1: 7/31/07
http://picasaweb.google.com/Rich8566/335iEDAugust2007
Old 02-27-2013, 04:44 PM
robacks robacks is offline
Mein Auto: 325
Is there a way to check the clutch before you buy a car. I am in the market for a 135 manual.
Old 03-01-2013, 06:27 AM
Bob Z. Bob Z. is offline
Mein Auto: 2013 135i Convertible
If you've driven manuals before you should be able to tell if the clutch is worn and/or has problems since it will slip and that is something you will notice for sure. I guess other problems could come on suddenly, such as what happened to the OP in the this thread. But it would have been interesting to drive it just before it happened to see if any symptoms existed.
What year & type 135 manual you looking for?
Old 03-01-2013, 06:41 AM
Mein Auto: 325
I am thinking about a 09 or 10 135i CPO car. Does the CPO warranty cover the clutch. I would assume not because its a wear part.
Old 03-01-2013, 06:44 AM
The clutch is covered on the new car warranty, unless they can prove you modded the car or severly abused it; however, I am not sure about the CPO warranty...I suspect that someone will chime soon.
Old 03-01-2013, 07:06 AM
Mein Auto: 325
Just looked a the BMW site and the clutch is not covered. None of the wear items are covered.
Maintenance; engine, transmission, and body adjustments; wheel alignment, balancing or rotation; wiper blade inserts; engine drive belts; spark plugs; filters; fuses; all batteries; all hoses and clamps (except air conditioning and power steering); oils, lubricants, fluids, refrigerants and coolants (except as required in the course of a covered repair); brake pads and rotors; brake shoes and drums; manual transmission clutch assemblies; suspension dampers (shock absorbers/strut elements); exhaust systems; tires.
Old 03-01-2013, 07:13 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
The PO new how to drive it, the PO just drove it hard. But, this type of failure is usually seen on an XI 335. Usually with this type of failure the flywheel is fine and you will notice that there is plenty of friction material. This type of failure will not give you any symptoms.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 03-02-2013, 08:43 AM
JimMetcalf JimMetcalf is offline
Mein Auto: 135i coupe
1335i
As my 2007 335i convert approches end of warrenty (at 73,000 now), I am seriously considering a cpo 1335i or is coupe as a replacement. Therte are very few CPO 335i coupes with 6 sp in this area, but a few 1 series with manual are showing up. Test drove a1335 and did not really find the smaller car unpleasant to drive-the shorter wheelbase and smaller turning circle were ok! Anyone else made this switch from 335i to 1335i? Looking for a 2011-2013 with manual tranny and fully equipped with nav. Comments?
help advice needed, help need fix
