Old 12-28-2012, 06:07 PM
hh3uunp's Avatar
hh3uunp hh3uunp is offline
Ball Don't lie
Mein Auto: 2001 Dinan m5
What do you keep in your trunk for emergencys
Right now I have in my trunk
The normal factory stuff
Radiator hoses,
gallon of distilled water (could be used for survival or radiator)
Screw Driver
towel (most usefull item in the universe)
Fix A Flat
Fuses
2 gallons of 93 octane gas
I have a first aid kit headrest from 740il so technically not in the trunk.
Anything else I should carry
If first you don't succeed you must try again, and then again
Mods
Dinan S1, Drilled slotted rotors, Akembo Pads, 19 in MPars,Zoinsville Super duty kit,
Resident Grammar and Spelling expert
Old 12-28-2012, 06:18 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
BMW coolant and a bottle of Remy Martin.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 12-28-2012, 06:52 PM
Andreas540i's Avatar
Andreas540i Andreas540i is offline
Mein Auto: 1997 BMW 540i
I have:
120v Converter
2 Tow Ropes
Spare Jeans and Shirt
Gloves and Hat
Rain Poncho
Ice Scraper
1/2" Torque Wrench with 17mm Socket
Automatic Transmission Fluid (Power Steering)
50/50 Mix Coolant
Quart of oil
Quick Detailer (For Bird Poo)
Towels
Fuses
Spare Bulbs
Screwdrivers
Socket Set
Ratchet Straps
WD-40
Flashlights
Spark Plug Gap Tool
Paper Bags (For carrying many things or to protect trunk)
Spare Wheel Lug Bolt
Allen Wrenches
Electrical Tape
Knife
A few compact multi tools
Tire Pressure Gauge
Tire inflator
Quick Interior Detailing Wipes
And my front license plate...
1997 BMW 540i
Old 12-28-2012, 06:55 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
let me see
well its empty ...
Old 12-28-2012, 07:46 PM
E36 Phantom's Avatar
I Am The Machine
You guys must either travel far, far from civilization or be hyper paranoid about your cars.
I carry the complete BMW toolkit, a flashlight, work gloves for tire changing, and paper towels. Everything stays in the spare tire well, I hate things in my trunk. Everything else, I have AAA for.
For longer trips (+200mi one way) I'll take one gallon of 50/50 coolant/water, a quart of oil, and a better warning light or triangle. That's about it.
Sent from my Galaxy Tab using BimmerApp
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 12-28-2012, 08:26 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
BSW tool-kit, jumper cables, a spare, LED flashlight, rubber gloves and hope. If i was to go on a roadtrip, maybe a gallon of coolant and a quart of oil.
Pretty much the same as E36 Phatom.. AAA is my backup if things go to sh@#.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 12-28-2012, 08:32 PM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
Trunk Money, case of beer & a 12ga Shot gun.
serously, I use my car for work and do travel 200+ miles from home 2-3x montly. I have a rubber made HD container from my old 4x4 I had which stored tow gear. It now contains:
-Hard hat
-Reflective vest
-Commerical grade small fire extinguisher that gets certified yearly by my company safety man.
-Old beach towel
-Wolverine work boots
-Whatever tools BMW includes in the trunk lid tool kit (checked to make sure it's all there)
-Spare tire & jack All stock items
-LED 2AA Maglight
-First Aid Kit I put together; gloves, bandaids, condoms etc.
-Pencil tire pressure gauge (No I don't actually use it regularly, it's for an emergency. I've checked to make sure it's close vs my dial gauge)
-1qt of Castrol 0-30 Oil
-Gallon of drinking water
-Roll 3M Duct Tape
Spare fuses are in the glove box fuse panel. Factory the car came with 1x of each amperage. That's all I need. If I need more than that I'm in seroius trouble. I have a set of jumper cables in the garage, brand new, light duty ones. But I took them out being I have a brand new battery and I now check the battery condition at every oil change or before going out of town 500+ miles is far for me, anything less is around the corner. I have a digital battery meter that checks battery condition and starter/charging. So I look at it this way, years ago I didn't have a $100 fancy microprocessor battery analyzer like the dealers used to have have. Now I do. So having a dead battery now a days means you left something on. Or you don't check your battery at oil changes.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 12-28-2012, 08:49 PM
hh3uunp's Avatar
Ball Don't lie
I forgot to add that I keep a 7 inch knife in the driverside door pocket. I keep a rod on the rear deck incase of a fight. When I turn 18 I'm planning on getting a permit to carry a handgun but my plan is to put blanks in it because most weapons are used on their owners. I am also a big believer that most criminals are cowards ipso facto they would run away. I worked over the summer as a Correctional officer, so I have talked to criminals. Most of the time they try stealing stuff they have to get drunk because they couldn't do it sober.
"Rather have them and not need them than need them and not have them"
I've been paranoid ever since I got hit by the ice storm last year. I've never seen anything like it. Gas stations out of gas, people lining up to charge their phones at 7/11. 2 hours waiting for gas. That was an ice storm imagine if something really big happened. Ill be on doomsday prepers before you know it. It took 10 days to get power back. What if it took a 2 months?
All my stuff is neatly on the spare tire. So it's not clogging up my trunk.
Mods
Old 12-28-2012, 09:00 PM
hh3uunp's Avatar
Ball Don't lie
I've certified fire extinguishers as a CO because I'm only seasonal I get to do the stuff no body wants. My boss says to me this is how you inspect them "look at the hose make sure it's not cracked then sign my ID number shouldn't take you more than 4 hours". I had to inspect 150 of them, about 25 into it I realized it wasn't so bad so that's what I did the next 2 weeks. Those fire extinguishers got the best damn inspection.
All jokes aside- make sure your fire extinguishers is actually inspected. I could've easily just signed the tag saying it was good without really checking.
Mods
Old 12-28-2012, 09:27 PM
Bandem Bandem is offline
Mein Auto: BMW
My subwoofer and my ice scraper.
Old 12-28-2012, 10:31 PM
NZ BMW NZ BMW is offline
Mein Auto: 2007 X5
I've got some BMW coolant in there, I got paranoid after my cooling system overhaul.
But seriously I don't see the point in carrying a survival kit like some kind of prepper... One thing I wouldn't mind is a fire extinguisher, only because my E39 actually did catch on fire from the aux fan...
Old 12-28-2012, 10:52 PM
OntheRock OntheRock is offline
Mein Auto: 530i
Mine's empty accept for occasionally my golf clubs (love the little diagram that shows how to place them, btw)
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
Old 12-29-2012, 02:05 AM
IndiansFan's Avatar
IndiansFan IndiansFan is offline
Mein Auto: '99 528iA
Originally Posted by NZ BMW View Post
........But seriously I don't see the point in carrying a survival kit like some kind of prepper... One thing I wouldn't mind is a fire extinguisher, only because my E39 actually did catch on fire from the aux fan...
I don't know what a prepper is, but If you live in snow country and get cought or stopped by a blizzard, you will appreciate having a winter survival kit: a small shovel, a good pair of boots, gloves, hat, and a wool blanket. I learned this lesson many years ago when I thought I knew everything.........
Free advice on maintaining any powder based fire extinguisher. Every 6 months turn it over and tap the bottom of the cylinder several times with a rubber hammer. It will loosen up the compressed powder and allow it to mix with the propellant. If the gague does not register in the good zone, have it serviced or replaced. There, now you just serviced your own extinguisher.
Either write something worth reading or do something worth writing.
Benjamin Franklin
2004 X3 2.5 TITANIUM SILVER/Grey - Sport/Premium Package
2001 530iA STEEL BLUE/Sand - Sport/Premium/Cold Package
1999 528iA JET BLACK/Black - Sport/Premium/Heated Seats
1982 Fiat 2000 Spider - BLUE METALLIC/Blue
1999 528iT CASHMERE BEIGE/Sand - Sport/Premium Package - 5 speed SOLD
1989 535i SALMON SILVER/Black SOLD
Old 12-29-2012, 04:51 AM
Hitdog540 Hitdog540 is offline
Hitdog540
Mein Auto: '03 540/6
My hockey bag
Old 12-29-2012, 05:14 AM
mr29 mr29 is offline
Mein Auto: bmw
interesting thread here.lets see a blanket a towel oil.coolant.2 subwoofers.jumper cables.spare tire and items to use it.shirts and rain coat and transmission fluid.2 chairs
Sent from my XT557 using Bimmer App
Old 12-29-2012, 07:43 AM
I have so much in my trunk because I like being prepared and i know that if I just have the tool I can fix or diagnose it and be on my way. When I travel to see my family in Houston, from Lincoln NE, its about 900 miles one way. When I do that I load up the trunk with all my tools. Full mechanics tool set, dewalt impact wrenches, hydraulic jack and jackstands... I also have AAA but I don't like having to wait around for help. I haven't had any serious problems outside of town, but I did use AAA when my transmission blew. You can't prepare for everything. I also have a habit of getting cars stuck in snow and mud so having tow ropes makes it easier to find someone to pull you out. And if you have ever had a brake line blow out the comfort of carrying spare tools is never annoying.
1997 BMW 540i
Old 12-29-2012, 09:19 AM
Itinj6's Avatar
Itinj6 Itinj6 is offline
Mein Auto: 2012 650i Convertible
HMMWVs and MRAPs don't even carry this much crap on combat patrol convoys lol
Sent from my SCH-I605 using Bimmer App
Old 12-29-2012, 09:22 AM
Itinj6's Avatar
Originally Posted by Hitdog540 View Post
My hockey bag
The only thing that matters!
Need an SUV for my goalie gear though
Old 12-29-2012, 09:25 AM
hh3uunp's Avatar
Ball Don't lie
My hockey bag
My hockey bag goes in the back seat. Then no free rides to people I don't like.
Mods
Old 12-29-2012, 09:26 AM
hh3uunp's Avatar
Ball Don't lie
Nah I've carried my gear and back up goalies gear in my e39. I had plenty of room
Mods
Itinj6's Avatar
It's way too stinky though lol. Need to keep it isolated in the trunk
Old 12-29-2012, 09:29 AM
hh3uunp's Avatar
Ball Don't lie
I air my gear out after every skate. Not really too stinky. Only thing that makes me angry is that I can't find a decent place to put my stick. It always ends up hitting me when I'm trying to change gears
Mods
Old 12-29-2012, 09:30 AM
Itinj6's Avatar
Must've been stuffed to capacity. I don't like scratching my interior panels so it has to fit neat in there. I bag my pillows so my gear bag is huge. 44" x 24" x 24"
Old 12-29-2012, 03:13 PM
moots's Avatar
moots moots is offline
Dinggg....what now!
Mein Auto: '04 525i
OP....2 gallons of gas in yr trunk?is that not dangerous?i have d standard tools in d tool kit and a jump start cable in d spare wheel well.nothing else.i hate messy trunks.
Sent from my GT-I9070 using Bimmer App
