Help. my 2013 X5 stuck in park on a car carrier!! - Bimmerfest - BMW Forums
Old 12-26-2012, 09:34 AM
katanaplanet katanaplanet is offline
Mein Auto: 2013 X5
Getting the car shipped. Battery completely dead as per the driver. How do I override the park manually so I can roll of this beast of the truck?
Old 12-26-2012, 09:39 AM
ND40oz ND40oz is offline
Mein Auto: 09 135i
There's a allen head bolt you can turn next to the shifter once you remove some stuff, the X3 rebuild thread has a picture of it.
http://www.bimmerfest.com/forums/sho...d.php?t=661006
17 Volvo XC90 T6 Inscription P*
15 BMW 328d xDrive Sports Wagon M Sport
15 Audi SQ5 Prestige
Old 12-26-2012, 10:45 AM
ard ard is offline
Resident Curmudgeon
I'd jump the car on the carrier, then deal with it.
Also, I'd caution you that if you get involved with helping unload, and something goes wrong, you may find that this is your problem.
GL
A
OE is Original Equipment: aka 'BMW Original Parts"; aka "What you buy at the BMW dealer with a BMW label on it"
OEM is Original Equipment Manufacturer... EITHER 'the company that made the OE part" or.... 'A part this is identical to the OE part, but is sold by the OEM under their own label,"
OEM is NOT WHAT YOU BUY AT THE DEALER.
Don't believe me? Read:
Old 12-26-2012, 11:55 AM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: Deutsch Automobil
Doesn't the thing in the cupholder release the transmission from park? (When you pull the cupholder liner up)
Old 12-26-2012, 08:10 PM
tonka858 tonka858 is offline
Mein Auto: 2015 Golf R
most cars you put the key into a slot near the shifter, it should be something simple.
look in book
Old 12-26-2012, 08:13 PM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
Call roadside assist......its free and you will be covered if something happens
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 12-27-2012, 07:19 AM
BenF12400 BenF12400 is offline
Mein Auto: 2006 X3; 2010 528;2013 X5
Probably not a good idea to "roll" a vehicle off a car carrier or anything else if there is no way for you to control it safely - agree with need to have engine running (unless you mean it's the only vehicle sitting in a car van)
Old 12-27-2012, 12:48 PM
kungpao kungpao is offline
d is for Diesel
Mein Auto: 2009 X5 35D
car carrier as in one of those multi car carrier rigs that they use to transport new cars in on the highway? You'd think that those guys would be carrying some sort of portable battery jumpers for that purpose. I agree though, definitely should not try to roll it off. And AU is right, the release is under the cup holder using the release tool.
-kp!
2009 X5 35D
Old 12-27-2012, 01:38 PM
ard ard is offline
Resident Curmudgeon
Wonder what's up with the OP??
If it is a new car, it may not technically belong to him until the carrier off loads it to him. Might be the dealerships' problem until then.
OP- be very careful when you take delivery. Note EVERYTHING on the bill of lading the driver will make you sign.. EVERYTHING. "Dead Battery", "Shift release opened and taken apart", any and all scratches, dings, scuffs, dirt, etc, "excessive dirt preventing inspection of the cars condition' is a good one, if true.
GL
A
Old 12-27-2012, 05:54 PM
tribecaX5 tribecaX5 is offline
Mein Auto: '11 X5 35d
Agree with Ard here. I would not touch it.
But for other occasions, just lift the cup holders rubber then on the left cup holder you have this big plastic screw cap. Remove it then you will see this square hole. Go back in the trunk, take the emergency release tool (like a T-shaped plastic with a square end, red color). Stick it in the hole, push down and turn to the left(?) I think. It will only turn one way so whichever way it is. It will stay locked in the position, forcing the transmission into neutral.
I learnt this the hard way when mine was flooded during Sandy and needed to get it out of the garage. Getting another 35d tomorrow.
Old 12-28-2012, 11:52 PM
Mein Auto: 2013 X5
this is one of the two cars I bought at an auction(other being 535xi). Dealership was flooded and all cars were written off and sold. No tool in X5. There is a 8mm bolt in the transmission(at the bottom) which you screw all the way to manually release it.
Old 12-29-2012, 10:52 AM
what you get it for?
Old 12-29-2012, 11:21 AM
Mein Auto: 2013 X5
For restoring and personal use. I got them pretty cheap and have experience in restoration. These cars are too electronic so its going to be a challenge. The X5 has damage to front fuse box and the 535 has both front and rear.
Old 12-29-2012, 11:26 AM
maybe you can get what you need from a wrecking yard.
put a dehumidifier in the cars with the windows rolled up for a few days.
Old 12-29-2012, 11:36 AM
NoI4plz NoI4plz is offline
quite the Restoration Project!
Why does this matter?
Old 12-29-2012, 11:54 AM
ard ard is offline
Resident Curmudgeon
For restoring and personal use. .
Post the two VINs.
Old 12-29-2012, 12:33 PM
Mein Auto: 2013 X5
so far changed all the fluids. spark plugs, hand turned the motor. Took the carpets out washed dried with industrial grade fan and of course dehumidifier. Cars were not running at the time and no water visually got into engine, brake, power steering windshield reservoirs. pressure washed the engine bays, undercarriage, air dried them etc.
water was below seat level. Will keep posted how it goes. BTW ordered power distribution units(fuse boxes) from Germany.
Power distribution units will need to be registered with the ecu as per the tech(will deal with it at a later point after replacement).
Any suggestions are always welcome.
Old 12-29-2012, 01:34 PM
ard ard is offline
Resident Curmudgeon
If these flood cars will make it to the market later, I'll hold back on coding/test suggestions until the vins are published.
I am sure the 'tech' gave you the correct suggestions re: 'fuse box needs replacing'....but to educate us, just how did water damage this part?
Old 12-29-2012, 02:57 PM
AutoUnion's Avatar
How much did you pay?
Old 12-29-2012, 04:52 PM
Mein Auto: 2013 X5
5UXZV4C54D0B13609
WBAFU7C51DDU69172
These flood cars will not make it to the public as the title clearly says so. I am not a car dealer. I own a lot of automobiles and motorcycles, and these were bought as a project, and the deal was at a throw away price(15K).
I plan to drive them as long as I can(My cars typically have very few mileage because of the number). BTW I am a physician with hobby in these things. Our cars used to get flooded every year growing up in India!!
Old 12-29-2012, 04:56 PM
AutoUnion's Avatar
5UXZV4C54D0B13609
WBAFU7C51DDU69172
I think a flooded BMW is just slightly more complex than a Maruti Suzuki 800 or Ambassador
Old 12-29-2012, 05:04 PM
Mein Auto: 2013 X5
Still car is a car!! Flooded ambassador is much more painful though!
Old 12-29-2012, 05:09 PM
I bet you can ship them to Russia or Eastern Europe and get a pretty good deal out of them
Old 12-29-2012, 05:16 PM
AutoUnion's Avatar
This is a good point. Once OP gets them working, ship em. You'll make a hefty profit.
Old 12-29-2012, 05:26 PM
Mein Auto: 2013 X5
I will keep them!
