6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
645ci 2005
Hi, a quick question for you guys, whats the approximate cost of replacing a transmission on a 645ci 2005 (automatic)? I have the opportunity to buy one for cheap but the transmission is out. Thanks.
The stupid dealership told me 6,200 but someone on this site told me how to reset my Transmision and it worked.
how do you reset the transmission? could you please provide the link for that post/faq? Thanks.
Most of the time a dealer says the transmission needs to be replaced, they don't know how, or want to fix it. If you had a dealer replace the tranny, I thought I heard 12k!. I would want to see a sample of the fluid before I took the chance of buying it with problems. Have a sample of the fluid tested, then make a good decision. If the current seller changes the fluid & filter before you buy it, the problems might disappear. Then the price would most likely increase dramatically!
It's a tough call without the correct information! ![]() Good Luck! |
Dealers do not actually repair broken transmissions, much easier for them to replace and send back to BMW or whoever to repair. It is much the same with engines, so they cost it accordingly....
Does my bum look good in this ! |
You may want to look into replacing the transmission solenoids in the Mechatronics unit. Very seldomly does an entire transmission need replacement. There is a write-up about this on the bimmerforums. The beauty of it is that you will only spend roughly 500 dollars for the replacement solenoids and a little bit of your time rather than the 6500 dollars that the stealership is attempting to scam you out of. Here is the link:
http://www.bimmerfest.com/forums/sho...d.php?t=654634
Sent from my SAMSUNG-SGH-I747 using Bimmer App
live fast, drive faster 2005 BMW 645ci Coupe (daily driver) 2001 BMW z3 3.0i vert' (TOTALED RIP) 1991 NISSAN 300zx 2+2 (gave to brother) |
