E46 (1999 - 2006)
Old 12-29-2012, 05:42 AM
Beltane's Avatar
Beltane Beltane is online now
Yankee
Mein Auto: 2003 325xi 5-spd
Where is all the oil going?????
Hello Folks,
I have a 2003 325xi that just turned over 165K (I’ve had the car since 40K purchased in 2005). All is well with the car except that I seem to be going through quite a bit of oil. I usually have to add a quart every 800 miles or so – about every two weeks with the 80 miles a day or so I drive to work. This has been going on for about 6 months – but now seems to be getting worse. I don't smell any oil or antifreeze burning.
I questioned my indy non-BMW specific mechanic about this and he said there was a slow leak in the oil filter housing gasket. At home I park the same place and my car shows no evidence of leaking anything – same situation at work. From reading this forum I know that these engines will use more oil as they get older, but I wanted to check that this sounds normal to everyone here.
I wanted to get the thoughts with the experts here that a ‘slow’ leak in the oil filter housing gasket was the possible cause of my missing oil. I have no problem having the mechanic change out the gasket for me, but there are a couple of other repairs I need to do as well and I just wanted to prioritize things. I love the car and I plan on it seeing 200K.
Just to answer some of the questions I know I'm going to get asked:
-Indy mechanic quoted $300 for changing out the gasket
-I'm 9 months pregnant and live in NH without a heated garage so the chance of me doing any repairs myself for the foreseeable future is nil. (Although I have really enjoyed fixing small things myself and learning how the car worked in the past thanks to this forum).
Happy New Year to everyone.
Thanks,
Laurie
2003 325xi 5-speed & 2009 Massey 1540 HST
Old 12-29-2012, 07:00 AM
shadow 2 shadow 2 is online now
Mein Auto: 2002 BMW 325xi
Leave it to my more knowledgable colleagues for a detailed response, but I had OFHG oil leak earlier this year, and it was obvious it was leaking from just a casual look. If you see no oil around the oil filter housing, your problem is likely elsewhere.
Old 12-29-2012, 07:05 AM
Vtguy325i Vtguy325i is offline
Mein Auto: 2003 325i sport package
Huh, weird my 325i uses a quart every 800 miles or so too
Old 12-29-2012, 07:10 AM
lgr122 lgr122 is offline
Mein Auto: BMW e46 1,9l M43
There's this cover under the engine which might collect some oil before it gets to the ground.
Old 12-29-2012, 07:31 AM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: 2005 330/2013 F30 M sport
I have changed the oil filter housing gasket.
I have changed the oil separator.
I have changed the valve cover gasket.
I still have to put a quart of oil in every now and then between oil changes.
It is what it is.
Old 12-29-2012, 07:33 AM
Beltane's Avatar
Yankee
I do see that there is oil around the housing - but not THAT much.
Old 12-29-2012, 07:34 AM
Beltane's Avatar
Yankee
Oh - I see - that's probably why I don't see any on the ground. Thanks.
Old 12-29-2012, 09:50 AM
catso's Avatar
catso catso is online now
catso
I had a leaky OFHG that used about a quart every 600-700 miles, changed it and now it doesn't use any significant amount at all. It may LOOK like a small leak, but any leak should be repaired as soon as you detect it.
Don't be gormless; get some gorm!
![/I][/FONT]
Old 12-29-2012, 11:15 AM
Beltane's Avatar
Yankee
Thanks - that must be the case then. I would have never thought it would leak that much.
Thanks to everyone taking the time to respond - I really appreciate it.
Sent from my SAMSUNG-SGH-I747 using Bimmer App
Old 12-29-2012, 11:51 AM
Solidjake's Avatar
Solidjake Solidjake is offline
The one and only
Mein Auto: 2002 330i
I wouldn't pay more than $160 for the gasket to be done. I would also do the CCV as well which I think is the main reason.
_______________Going to Bimmerfest East AND West
Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide
Old 12-29-2012, 02:01 PM
JNMNL52 JNMNL52 is offline
Mein Auto: 2006 X-5 / 2002 330i
For what it is worth I have a 2002 330i with 147k miles. I have no leaks and I add about 1 quart every 800 miles. The engine doesn't smoke at all, just uses the oil.
Old 12-29-2012, 02:24 PM
DPP528 DPP528 is online now
Mein Auto: 2000 528i M-Sport 5Spd
Sounds to me that it's a failing crankcase ventilation valve, leaks usually aren't a quart every 1000 miles. Also the common leak places are likely to leak onto hot areas and smell. When a CCV valve fails the car burns the oil and runs slightly more coarse because it causes the vacuum system to work improperly. It's a gradual transition and is pretty unnoticeable until you address the CCV failure and feel the difference.
Here's my quick diagnosis (and I've written this in a few places on this forum already)
1. Take out the dipstick, examine the bottom (usually plastic and colored red or orange) if it for black sludgy oil residue, this is a sign of a failed CCV.
2. While the engine is idling remove the oil fill cap and then put it back on, make sure it't tight. While you do this listen carefully for changes or surges in the engine idle pitch, especially when putting the cap back on. If there's no change in pitch then the vacuum system may be faulty and it's usually due to a CCV failure. You can also remove the dipstick and listen for a change in the engine pitch.
A mechanic with the proper tools would seal a hose on the dipstick tube with a pressure gauge on it and look for negative pressure, if there's no negative pressure, change the CCV, it's not a particularly fun job but it's a common problem on these engines.
2000 528i M-Sport 5speed
Old 12-29-2012, 02:29 PM
Solidjake's Avatar
The one and only
That's way too much oil use. Change your CCV
Old 12-29-2012, 04:46 PM
SJBimmer SJBimmer is offline
Living Life At The Beach
Replace your CCV first, then the OFHG gasket if needed. The failing CCV may have also caused your valve cover gasket to fail due to the crankcase being pressurized. Feel around the valve cover to see if the gasket is leaking.
Old 12-29-2012, 04:56 PM
catso's Avatar
catso
If you replace the CCV, do the OFHG at the same time. It's very easy, inexepensive (less than $10) and removing the oil filter housing makes it much easier to get to the CCV. The OFHG is a got a limited life expectancy because of its design , so even if it's not leaking now, it will sooner or later. Consider it preventative maintenance.
![/I][/FONT]
Old 12-30-2012, 04:23 AM
Beltane's Avatar
Yankee
I can do that - thanks.
I don't believe the CCV has ever been changed.
Old 12-30-2012, 07:16 AM
That's a good point, and good advice. I must be still hung over from Christmas!
