Old 10-11-2012, 10:28 PM
640GC's Avatar
640GC 640GC is offline
(aharding)ED #1 Sept 2012
Mein Auto: BMW GC & MB SL500
Anyone know the optimum EQ setting for the B&O system in a 640GC? We purchased the B&O but it didn't sound that great. Of course, the dealers source material was the radio. SACD's all the way!
2013 F06 640i Gran Coupe Carbon Black | M Sport Package | Amaro Brown Merino Leather | Fine Line Oak Wood Trim | Driver Assistance Package | Luxury Seating Package | Bang & Olufsen | Ceramic Controls | BMW Apps | Full LED Lighting
ED Trip Report - September 2012
Post your Neuschwanstein Castle photo here
Hawaii Vacation Rentals
Old 10-12-2012, 07:41 AM
preeble preeble is offline
Mein Auto: Cars
I tried the recommended settings on my B&O in my 550 and it sounds great - much better than the initial settings that I tried. The B&O benefits don't really kick in until you turn up the volume. There, you will see that the bass is extremely tight and the highs are crisp. I like it a little on the thumpy side and these settings were perfect for me - if you like less bass, then i would suggest turning the bass level down 1 or 2 notches.
Old 10-27-2012, 12:48 PM
Ace535i's Avatar
Ace535i Ace535i is offline
Mein Auto: I'm still dreaming....
Do note that quality speakers require a 'ripening' period in order to get best from your premium system.
In other words, premium systems get better with time.
Old 11-06-2012, 05:30 AM
Alghouti Alghouti is offline
Mein Auto: Bmw 520d 2013 Touring
Anybody tried these settings in the touring?
I just got my 520d touring (F11) with the professional system and I was wondering if anybody have good settings for this model? I imagine that the larger "room" will be a bit different to the F10 sedan?
Anybody tried some settings in their F11 and be able to comment?
Old 11-06-2012, 01:47 PM
kssod kssod is offline
Mein Auto: Acura RL
Premium does not seem to be able to play DVD Audio discs.
Sat radio is awful, compared to my Acura .
Will try te settings
Old 12-17-2012, 05:46 PM
Hvarsov Hvarsov is offline
Mein Auto: 2011 535xi
After reading that quality speakers require ripening period to get the best...............really?????? Where do you get this from??? Seriously, where would you get the idea that electronics ripen with age???? Enlighten me, please
Old 12-17-2012, 06:03 PM
djsilo djsilo is offline
Mein Auto: 2012 550i xdrive
Speakers can sound great right out of the box. However, they can get less rigid and allow for a 'softer' tone. After a LONG time, they soften to the degree where they wear away, crack, etc. and you lose sound quality.
Overall, I'm trying to say speakers can sound great out of the box, but you get a softer tone after a couple hundred hours (guessing) of use. Really though - It's all subjective. I've used dozens of different professional sound systems from car tweeters to concert rigs - no one will really be able to tell the difference in a fresh speaker vs one that was lightly broken in.
2012 F10 550i M-Sport | Dark Graphite II | Hex Aluminum | Black Interior | Cold Weather | ARS | HUD | Side and Top View Cameras | BMW Apps | Premium Sound | M5 Style Spoiler | Rho-Plate | Dinan Stage 2 Tune | Dinan Suspension| Dinan Shockware | BMWPedals | 70% Crystalline Tint
Old 12-17-2012, 06:13 PM
Ace535i's Avatar
As my brother explained to me:
The run in period for a speaker is largely dependent on it's suspension type + materials. You also need to consider the excursion, but for a system, you probably are not given that info-
When I do final voicing on a system, I normally have a set of drivers to chose from to build the system that meet certain service limits (response, TS and impedance limits). These measurements are taken from drivers that are fresh from the sample or line build and have to be broken in afterwards- otherwise, I am voicing a system that I know for a fact will change.
What changes??
Resonance related parameters are the ones that change the most. When looking at a very low compliance mid-woofer for instance, you may see a significant shift in the overall compliance factors of the model. In general, the speaker will get "warmer" as it breaks in; largely due to the Cms and Qms changes as the suspension breaks in.
What breaks in? Well, the suspension is mainly the damper (spider) and is generally a fabric of some sort with a phenolic impregnation that is formed under a clamped, high temp environment. This is notably stiffer at first deflection and to be honest, you can hear the things creaking, cracking and in general sounding like rice-crispies on the first deflection- particularly on larger woofers or very low thread count dampers. The break in there is generally rapid if you run the driver at or near Xmax. On a midbass or midrange driver, I normally use dedicated signal to run the driver in. Of late, I prefer to use a shaped tone burst at or around estimated Fo. Running this signal at or near Xmech will give you a very nice break in over the course of 45 minutes to an hour with bursts at about 3 to 5 second intervals. Incidentally, a lot of the better companies out there in the woofer business are starting to use shaped tone burst testing as an accelerated life test. 12 to 16 hours on a TBT at Xmech is tough on a woofer, particularly one that is a higher end model and has to really stroke to get the SPL that the customers demand.
Tweeters- My experience is that the tweeter or a dome mid (single suspension device with a very low x-max) will run in best with a composite signal such as white noise. I prefer a white signal as it is not filtered on the top end and gives me a little more content (heat) to soften the suspension and get the fluids balanced if the driver is fresh. These will run in faster- my experience is that 30 minutes at Pmax is more than plenty- I winder if 10 minutes would be adequate in some cases. Interestingly, many of the higher end tweeters typically run in faster- and most do not have any Ferro fluids in the gap which further reinforces the fluid mix / balance concept as part of the response settling out. This is only valid in the first few days of the tweeter assembly as I know it, but others may have different experience.
If you do not have test signals to use, then what- Someone mentioned using classical or jazz with a wide dynamic range. There you go. The nose that the engineer may use is a very wide range of signals all played simultaneously and that is the fast road to run in.
A word of caution though- do not hammer the crap out of the speaker or system during break in. You want to run it in to where the compliance model is settled out but not bash the VC into the bottom of the yoke. As the break in progresses, your compliance will be changing and 10 watts at a given frequency will drive the VC to the same level, but the compliance shift will let the mechanical parts move a greater distance. What is borderline bottoming out at the first of the test will likely be a big problem after an hour if you are running at or near Fo. Use common sense and know that if an hour with a signal does not do it, a few hours of moderate use or one hour more of jamming when the wife is out will do just fine.
With something like this, I encourage people to not bee to picky or get too worried about a break in. This is not like a car engine where you have metal on metal. The speaker has no interference parts that move and in general, you never want to have interference parts. Just do not go too crazy and if you ever hear bad stuff coming form the speaker, turn the volume down a notch.
Old 12-29-2012, 08:05 AM
BigPimp's Avatar
BigPimp BigPimp is offline
Ten2Six
Mein Auto: '11 550i
Good tune!!! T y v m!
'11 550i Ti Ag/Black Dakota Sport/DH/Conv/CW/P2/HeadsUp
Old 03-11-2013, 05:43 PM
cordoor's Avatar
cordoor cordoor is offline
cor door sedan
Mein Auto: 2013 550i xDrive
The thread about B&O got me thinking about tuning the settings on my premium audio.
Sorry guys, I just had to bump this thread to give a shout out to BimmerUKF10. I tried his settings and they are fantastic. Until now, I thought the Logic7 audio in my E60 was better than the premium audio in the F10, but not anymore.
I did make a slight adjustment. I kept his equalizer settings, but bumped the shelving treble down to +1 since the treble was ringing my bell for how loud I was playing music.
But his settings are such a fantastic starting point that I had to bump this thread to give props
If you haven't tried his settings and you have premium audio, doooo it.
Current: 2015 i3 REx | Giga | Ionic Silver Metallic
2013 550i xDrive M Sport DHP | Jet Black | Venetian Beige | Dark Red Sycamore
2008 535xi Sport | Jet Black | Cream Beige | Burl Wood
Old 03-11-2013, 07:10 PM
cordoor's Avatar
cor door sedan
Dupe post
Old 10-11-2013, 02:35 PM
fjacobs1000's Avatar
fjacobs1000 fjacobs1000 is offline
Let's drive!
Mein Auto: '14 F10 550, '14 F31 328d
Professional sound settings
I'll be trying these settings out soon - note to self.
Old 01-15-2014, 02:33 PM
bikenski's Avatar
bikenski bikenski is offline
Mein Auto: '14 550i xDrive
Bumping this 'oldie but goodie' post.
Has anyone with the Harman Kardon system in their LCI tried the OP's settings? Not sure if the system is the same as the pre-LCI with a new name, or if components and/or tuning have changed.
Current: '14 550i xDrive
Past: '11 335i xDrive Coupe - 6MT
Past: '08 335xi Coupe - 6MT
Euro Delivery
bikenski's Avatar
Dupe
Euro Delivery
Old 01-15-2014, 03:53 PM
Sonicendeavor's Avatar
Sonicendeavor Sonicendeavor is offline
Mein Auto: 2014 535i MSport
The OP's settings are almost identical to mine in my LCI except for the 5k and 10k settings. IMO those two produce over boosted highs. Also, the -3 cut at 2k is a bit too much. -1 takes the edge off of snare drum hits that can becoming tiring. Some like their music artificially bright but my background as a musician with many hours in recording studios taught me that less is more when it comes to EQ, so if I have to use it, I use as little as possible, especially when you don't have many EQ bands to work with.
2014 LCI 535i /// M-Sport - SAT, Premium pkg, HK Audio, Drivers Assistance, Top/Side/Rear cameras, multi-contour seats.
Mods: Opticoat Pro,v2 coilovers, Michelin PSS, Cyba quad black chrome exhaust tips, coded various features myself.
20/80 Highway/City
Old 01-15-2014, 05:36 PM
joder joder is offline
Mein Auto: '14 535i and '14 x5 35
I thought that you typically don't want to amplify unless you have to as it will introduce noise and distortion. The 1, 5, and 10 all are on the positive side of things.
Old 01-15-2014, 06:58 PM
PeterC4 PeterC4 is offline
Mein Auto: 535xi,328xiC
Originally Posted by BimmerUKF10 View Post
Before my iDrive started rebooting and became unusable (see iDrive rebooting thread), I spent considerable time playing with the graphic settings trying to get the best from the F10's Professional audio system (think it's called 'Premium' in the US). The settings below give the best overall sound (to my ears at least).
Fader +2 towards rear
Treble +4
Bass 0
Surround off!!!
100Hz -2
200Hz -1
500Hz 0
1KHz +2
2KHz -3
5KHz +4
10KHz +6
The surround just seems to add copious amounts of reverb and wrecks the sound IMO.
I initially set everything up using my ears, then used some sine wave test files with a large diaphram mic who's responce I'm familiar with and an oscilloscope (yes - I'm into audio!). Assuming my calculations were correct, the results were suprisingly flat. My preferred settings have a slight boost around 3Khz, but I like it that way. Makes you wonder why they can't equalise the default settings better.
Read it incorrectly first time. Mine is similar where you need to turn down low end frequencies and raise high end frequencies and de-emphasize at about 2k. I don't raise the high end as much. But the general pattern seems consistent.
2012 535xi M-Sport, Carbon Black, Cinnamon-Alum Hex, Exec Pack, Tech Pack, HUD, Damper Control, BMW Apps, Heated Rear Seats, BMS Tune
Old 01-15-2014, 07:23 PM
CGP CGP is offline
Mein Auto: f10 550i
I was not enjoying my system as much as I did in my e60. I tried the OP's suggestions. For a few months I drove around and tried to convince myself that I had improved the tone and quality of the music. Yes, yes I kept telling myself much better, much better. But......I just was not enjoying as much as I did in previous BMWs.
I searched and searched for suggestions. Finally I came across this. I recognize it is subjective but IMO way, way better.
[SIGPIC][/SIGPIC]
Old 01-15-2014, 07:27 PM
Sorry, I missed the bass and treble settings. I leave those flat, so no boost on the treble. My current EQ is slightly different than I thought. It's pretty close to flat.
Treble 0
Bass 0
Surround off
100Hz 0
200Hz -1 slight offset to some minor muddiness
500Hz 0
1KHz +1 or +2 - adds a little presence to vocals
2KHz -1 - cuts some harshness, especially with snare drums
5KHz +1
10KHz +1
Again, it's up to a persons taste, but I like my systems as free from eq as possible, especially with a system like the HK which is already eq'd.
The HK system is pretty clean so I wouldn't worry about any distortion at these minimal levels of eq.
20/80 Highway/City
Old 01-15-2014, 07:44 PM
ahmadddd ahmadddd is offline
Mein Auto: 535Xi M Sport
Agree, I have a similar setting and its much better than the one on this post, I tried it and got high tribble and no base at all. I always wanted to have a rich sound with good base(Real base, not booming base).
Your setting (we call it V setting) is a very well known setting that worked on most sound systems and I use it on parties too
I think combined with +2 towards the rear and 0 Base and 0 Tribble would be awesome
2013 535Xi Alpine White/Brown Cinnamon. M Sport - Premium - Tech - Cold Weather - Driver Assist - Soft Touch Doors - Premium Hi Fi - Auto Rear Sunshade
Old 01-15-2014, 08:37 PM
MERTON MERTON is offline
Mein Auto: '12 535 X-Drive
I just wish there was a 50hz adjustment. Anyone know if it's possible to recode the HK system for this? I'd like to have a 2db cut at 100hz and 2db boost at 50hz.
Jim
Current:
'12 535 XDrive (Blk. Saffire Met. Blk Nappa, Sport, DHP, ARS, Premium Audio, Tech & Cold Pkgs), '05 VW Touareg V8, '13 VW Jetta TDI (wife's) '06 Jetta (daughter's)
Past:
'99 540iT M-Sport, '01 Audi A6 Avant, '01 Audi allroad, '97 540i, '93 Lexus SC300 m, '89 535i, '83 635i, '85 Alfa GTV6, '79 320i, '71 & 69 2002, '69 Alfa Spider, '62 Olds 98 (1st car)
Old 03-13-2014, 01:42 PM
Bmwlvr60 Bmwlvr60 is offline
Mein Auto: BMW 528xi
Treble 0
Bass 0
Surround off
100Hz 0
500Hz 0
5KHz +1
10KHz +1
Sonicendeavor:
Where are your settings these days?
Additionally, I have the Balance to the Driver's side +1 to +2.
I Have tried the OP's settings, but 5KHz and 10KHz suggested settings are a bit too extreme to my liking. Also, I like the Bass cranked up a bit: +2 to +3.
2014 528ix M Sport. Space Gray/Mocha Brown Nappa Leather, Anthracite Wood Trim, ContiProContact SSR RFT's. Packages: ACC Stop & Go + Active Driving Assistant, Driver Assistance, Driver Assistance +, Lighting, Lux & Prem. Options: Paddle Shifters, H-K. S S System, Heated FS's & Power Rear Shade with Man SS's.
2013 X3 28i M Sport. Deep Sea Blue/Sand Beige Nevada Leather, FS Wood Trim, BMW Apps, HG Rails and GY LS All Seasons. Packages: Cold, Conv, DHP, Perform, Prem, Prem Sound and Tech.
Old 03-13-2014, 02:33 PM
BimmerUKF10 BimmerUKF10 is offline
Mein Auto: BMW F10 535D MSport
'Again, it's up to a persons taste, but I like my systems as free from eq as possible, especially with a system like the HK which is already eq'd.
The HK system is pretty clean so I wouldn't worry about any distortion at these minimal lep vels of eq.
EQ in a car in particular is much about correcting problems with the acoustics since the frequency response in that environment is never flat (I've never come across it anyway - regardless of the Bose, harman, B&O, Meridien's of this world or whatever). The settings I posted a while back sounded best to my ears with the system fitted to my F10. I haven't personally heard the HK setup, but I'll eat my hat if it's flat. Car stereo's are usually designed to hype particular frequencies since most listeners prefer that. That coupled with challenging acoustics typically means the use of digital equalisation that you can't adjust. Distortion is another topic completely. Some distortion is pleasing (and actually preferred). As someone who works in the recording industry I can tell you that pretty much all studio recordings are recorded using gear that produces distortion or software that emulates it. The purest (or audiophile) view of leaving EQ flat comes from the concept of leaving the sound as close to how the original engineer intended it. I can understand that to a degree if you listen to classical music where the sound should be true to the instruments and the room they were recorded in, but who is to say you are wrong if you like more bass or treble or whatever? Particularly for any form of modern music. It just never relates to acoustic reality. End of the day - you should set your EQ how you like it and ignore everyone else. My settings were only ever intended as a guide in the right direction.
535d MSport Carbon Black / Black Nappa / Fineline Anthracite | Visability Pack | HUD | ACC | Adaptive Drive | Folding Seats | 4 Zone Climate | Surround View | Pro NAV | USB Audio | Professional Audio | Sun Roof | Comfort Seats | Heated Seats Front / Rear | Professional Rear Seat Entertainment.
Old 03-13-2014, 04:24 PM
richpat69 richpat69 is online now
Mein Auto: '14 535iX, Corvette ZR1
Last week I had my home theater audio and video professionally calibrated (8 hours and don't ask); today I tried the OP's settings. The OP's now legendary settings was a much better deal.
Thanks for posting.
And thank you to the Bimmerfest community. I've owned a 14 535iX for less than two weeks. The amount of information I have learned from this board is incredible, and much appreciated.
Old 03-13-2014, 09:44 PM
My reference to flat concerns the eq settings, not a measurement of frequency response in the vehicle. Over boosting or cutting using limited band graphic equalizers produces unacceptable peaks and valleys in the frequency response which artificially colors the music and sounds far worse than no eq at all. As you stated, everyone has their own tastes, and of course levels of higher frequency hearing damage. Right or wrong is purely subjective but given my background as a musician and working in studios, I have little tolerance for the sound generated by low quality graphic equalization.
20/80 Highway/City
