slight throbbing in gear knob
i have an 01 325i 110k miles, put a new clutch in about 5k miles ago but i dont what this is...might be the transmission? my gear knob started slightly pounding whenever im in first gear, the faster i drive the faster it pounds, all other gears seem to be fine, just a little vibration, any thoughts on what this is? thanks
I can't resist......are you sure you had your hand on the shifter and not something else.
Sorry bro I sure hope the tranny is okay. Sent from my Nexus 7 using Bimmer App |
haha would you look at that, you solved my problem
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
Did a spit take with my iced tea when I read that thread title.
ha ha yeah well does anyone know what it is? my shifter vibrate in all gears, ok that sounds just as bad
Did you replace the trans mounts? Is the exhaust properly reattached? Did you replace the rubber bushing the tail of the shifter mount sets in? What about the shifter itself? Is it mounted proper? More info needed.
Could also be bad motor mounts. Sent from my One X using Bimmer App |
yep thats the one...and yes i replaced the pilot bearing as well
I'd double check the trans mounts then. And make sure the exhaust hanger isn't hitting anything. That can transmit vibration to the shifter
trans mounts and exhaust hangers are all good and that clip is still holding good too, but the flex disc is pretty torn up
sweet thanks, i didnt cause i just jacked my car up and looked, didnt take anything off
and i didnt have the part
replaced the flex disc and it fixed the problem everything works perfect thanks guys
