E46 (1999 - 2006)
Old 12-28-2012, 10:33 AM
anton2718 anton2718 is offline
Mein Auto: 01 325i
slight throbbing in gear knob
i have an 01 325i 110k miles, put a new clutch in about 5k miles ago but i dont what this is...might be the transmission? my gear knob started slightly pounding whenever im in first gear, the faster i drive the faster it pounds, all other gears seem to be fine, just a little vibration, any thoughts on what this is? thanks
Old 12-28-2012, 01:21 PM
BigMotherWheels BigMotherWheels is offline
Mein Auto: 06 325ci Coupe ZSP
I can't resist......are you sure you had your hand on the shifter and not something else.
Sorry bro I sure hope the tranny is okay.
Sent from my Nexus 7 using Bimmer App
Old 12-28-2012, 02:25 PM
Mein Auto: 01 325i
haha would you look at that, you solved my problem
Old 12-28-2012, 03:03 PM
Fast Bob's Avatar
Keeping it surreal
Sorry, I sure hope your bro the tranny is okay.
For the dyslexic among us....
The road goes ever onward....
(R.I.P. Jever)
Old 12-28-2012, 03:25 PM
vandyboy vandyboy is offline
Mein Auto: 01 325i automatikgetriebe
Did a spit take with my iced tea when I read that thread title.
Old 12-28-2012, 06:10 PM
Mein Auto: 01 325i
ha ha yeah well does anyone know what it is? my shifter vibrate in all gears, ok that sounds just as bad
Old 12-28-2012, 06:36 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Did you replace the trans mounts? Is the exhaust properly reattached? Did you replace the rubber bushing the tail of the shifter mount sets in? What about the shifter itself? Is it mounted proper? More info needed.
Could also be bad motor mounts.
Sent from my One X using Bimmer App
Old 12-28-2012, 06:39 PM
Could be any or all of the above, which happened to me with my E30. Probably engine or trans mounts. Also, the drive shaft could cause vibration.
Old 12-28-2012, 06:44 PM
Mein Auto: 01 325i
i didnt replace anything but the clutch and flywheel, also i broke the little clip that held the shifter to the tranny (its on top of the tranny) but i welded it back together
Old 12-28-2012, 06:46 PM
smolck's Avatar
ROLL TIDE!
Are talking about the clip that holds the front of the shift lever arm?
Tell me you replaced the pilot bearing.
Old 12-28-2012, 07:03 PM
Mein Auto: 01 325i
yep thats the one...and yes i replaced the pilot bearing as well
Old 12-28-2012, 08:50 PM
smolck's Avatar
ROLL TIDE!
I'd double check the trans mounts then. And make sure the exhaust hanger isn't hitting anything. That can transmit vibration to the shifter
Old 12-29-2012, 11:10 AM
Mein Auto: 01 325i
trans mounts and exhaust hangers are all good and that clip is still holding good too, but the flex disc is pretty torn up
Old 12-29-2012, 11:36 AM
smolck's Avatar
ROLL TIDE!
That's it then. If it is really beat up it will let your driveshaft beat up the carrier bearing too and that is really bad. Replace asap (should have while you were in there, live and learn )
Old 12-29-2012, 01:37 PM
Mein Auto: 01 325i
sweet thanks, i didnt cause i just jacked my car up and looked, didnt take anything off
Old 12-29-2012, 02:48 PM
Mein Auto: 01 325i
and i didnt have the part
Old 01-03-2013, 05:07 PM
Mein Auto: 01 325i
replaced the flex disc and it fixed the problem everything works perfect thanks guys
